40PHH Mikuni tune advise
luvemfast
Hi, i've done a search, but can't find the info I need.
I have an L28 (N42 F54) with the following specs.
Ø88mm flat top pistons (2mm oversize, which makes it a 2883cc)
0.49 inch lift 74° cam
balanced bottom end
recurved and mechanical advance dizzy, set to 15°
Extractors to 2.5" exhaust
I am running triple 40PHH Mikunki's, what jets do people you recommend?
Currently running
Choke ø36
Main Jet 160
Air Jet 200
Idle/Pilot 57.5
Pump 45
Block OA
Bleed pipe T
I have a selection of jets to choose from
Choke ø32, ø36
Main Jet 140, 145, 150, 160, 190, 200, 210, 230
Air Jet 180, 200, 210, 230, 240
Idle/Pilot 55, 57.5, 60
Pump 40, 45, 50
I sorted a flat spot down low by going smaller idle/pilot jets (60 to 57.5)
Looking for help at top end, seems like it wants to go, but is lacking fuel or air, or both.
Can someone give me an explaination as to what effects the main and air jets will have on performance?
Thanks, Simon
In a nutshell, mains affect mid-range and top end. Bigger mains make the mixture richer. Air correctors affect top end, where a bigger air corrector makes a leaner mixture. A wideband 02 sensor is very helpful in the tuning process. The Weber sticky has very good info: Linky. There should be some pertinent Mikuni info as well.
normally on tripples (like everything else) you do the same thing to everything since in theory everything should be the same and balanced so they fire the same. Ie 4 cyls running rich and 2 lean...i would start with the same thing in each, and change all 3 little by little untill you get it tuned with the 02, or just take it to an amazing shop like robello or someone that really knows what theyre doing with multiple carbs, austin healeys, mg's, etc race shops that use dual or tripple carb setups.
Since we are tuning triples, how can we adjust them using a single wideband gauge? My point is, one of the triples could be running richer and causing the overall reading to be rich.
How do people adjust them without a wideband gauge or dyno? You do the best you can. Doing everything the same on each carb is a given, but ideally I would love to have an 02 sensor for each cylinder. Using one wideband is not ideal, but it's a lot better than not having one at all. A competent person can get the carbs dialed in pretty well with a WB02. A dyno is even better.
Based on my experiance with your carbs try those 180 airs first and drive it with the mains you have installed.
Next pull the 160 mains and go to the next smaller (150). Drive again.
Repeat with the 145 main.
Repeat with the 140 main.
Let us know. I think you will be going in the right direction.
