NEED HELP WITH WIRING LS1 GAS TANK
I am trying to get my Autometer fuel level to work and not sure how the LS1 sender should be wired. Does anyone have a diagram or pictures they could share. I have looked and looked but could not find anything useful. Its a 2002 Camaro gas tank.
OK, I figured it out. I have a 2002 Camaro V8 gas tank and there are 4 wires to connect (black, red, purple and black with white strip). Black to ground, red to ing (+) purple to fuel lever and the black/white strip is another ground I think for the sender. I am glad to say it is now working.
im jsut getting to this part now. thanks for the heads up. that will save me some time. Im using a 99 doner. I hope is the same. did you have to cut out the rear wheel well? do you have any pictures of your install also. I would like to have some kind of ref point
Spare wheel well must be cut out and a new tank support frame must be welded in into cradle the F body tank. I used 2 x 1 x .120 wall tubing for my support frame (probably overkill). My primary reason for switching tanks was to run dual exhaust with the compatibility(EFI LS2) being a bonus. You can even use the Z filler with the 98-02 tanks using some Gates 90 and 45 degree elbows with some creative splicing. I also used the 2 x 1 tubing to help reinforce my frame where the spare tire well was removed. There are many other's with this swap and there are pics available on this site. I believe I saw this in the fabrication/welding forum....If you can't locate some pics I can get you some of my swap.
