LS1 radiator choices
I have been looking for a radiator and found these that would work. Let me know your thoughts.
http://www.koyoradracing.com/products/radiators.asp?make=Datsun
direct fit and there is some N version where it adds some extra cooling.
http://www.summitracing.com/parts/SUM-380325/
summit version and this would be a very tight fit. the frame rails are 25.5in across. this would require a hammer or some grinding. I would use the JTR bracktes or fab some up.
http://www.jagsthatrun.com/Pages/Parts_DATZ_Radiator_Kit.html
JTR set up looks nice also.
all of these seem to be nice choices.
I'm using the summit radiator#380325 with there shroud / ele. fan kit #sum-csum3800. Price $355 if you buy it all together. My 260 had enough room for a thin rubber shim between the frame rails and with some garage made saddle mounts it looks like it was made for the car. good luck
Does the factory LS1 Coolant hose that runs from the thermostat to the radiator work, or does it have to be customized?
I am running factory hoses that I modified. The lower hose I just shortened. The upper hose I cut a section of the center of the hose and spliced back together using an aluminum coupler (1.5" diameter) with a 1/8" pipe fitting for my steam vent. I got mine iff eBay for $10 shipped.
Awesome! Thanks.
