Engine back plate needed! 1989 Firebird T5 trans,
Hello, I have 1975 280Z with V8 350 (1974 Nova) with 1989 Firebird T5 manual transmission.
I wonder anyone help me find engine back plate where starter goes...
I have a car without that plate.........
JD
Hey im doing almost the exact swap. I have a 78 350 with a 1985 T5 camaro.
Did the camaro flywheel bolt right up to the old 350? I know there are 2 different
rear main seal types, i didnt know if itll bolt right up or if ill need a custom flywheel.
Thanks
Edited by revlis240
revlis240, the small block moved from a 2 piece main seal to a one piece in 86, so you should be fine. Pre 86 all small block bolt patterns are the same using the 2 piece main seal, and from 86 till the LS1 all flywheel bolt patterns are the same using the one piece main seal(yes the LT1 uses a small block flywheel).
