duragg Posted October 30, 2011 Share Posted October 30, 2011 That exhaust is delicious. My 6-1 with MSA Twice Pipes makes my ears ring... That setup will be an attention getter. Quote Link to comment Share on other sites More sharing options...
z-ya Posted April 1, 2015 Author Share Posted April 1, 2015 Currently refreshing this engine. Stay tuned. Quote Link to comment Share on other sites More sharing options...
z-ya Posted May 17, 2015 Author Share Posted May 17, 2015 Putting it back together Putting the head on and timing the cam tomorrow. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 17, 2015 Share Posted May 17, 2015 You didn't bust out the jeweler's rouge and mirror polish the chambers? Clearly you don't want it to make power. Looks great! Quote Link to comment Share on other sites More sharing options...
z-ya Posted May 26, 2015 Author Share Posted May 26, 2015 Update: We went with a new damper on this refresh. We were running an older Datsun Competition unit before. So we ordered a new ATI damper. A few notes on the ATI damper: - Nice unit, beautifully machined pulley, and the damper itself is anodized aluminum with laser etched timing marks. - It's a tight fit to the crank, but that is really what you want for best vibration dampening - Pulley size is much smaller than stock, so keep that in mind when choosing accessory pulley sizes. For a race application you probably want to have a much larger alternator pulley. Not sure on the water pump. We'll find out soon Issues: See the photo below. You can see the washer mating surface is much further from the crank snout than stock. There is about one thread of engagement, so a LONGER BOLT is required! I ordered a few different sizes of 16mm x 1.5 grade 10.6 bolts and found the size that gave me the most thread engagement without bottoming out in the crank. I also used the NISMO bolt washer as it has a groove that allows it to sit inside the pulley hole. See attached image. I used an extra long bolt to in effect press the pulley on to the crank. Like I said it is a tight fit (zero clearance), but it will go on with some antisieze and a long bolt. Lining up the woodruff key is the biggest challenge. Don't install the oil pan until you get the pulley on, Chances are you will knock the woodruff key out at least once like I did. Here is a photo comparing stock to ATI. The pulley lines up find with the water pump pulley. I'll post more photos tomorrow when I get it all together. Quote Link to comment Share on other sites More sharing options...
Project1 Posted May 28, 2015 Share Posted May 28, 2015 (edited) Really really nice job Edited May 28, 2015 by Project1 Quote Link to comment Share on other sites More sharing options...
Xnke Posted May 30, 2015 Share Posted May 30, 2015 Will ATI make the damper with the larger pulley diameter, or is that huge underdrive ratio all they'll do? Quote Link to comment Share on other sites More sharing options...
z-ya Posted June 1, 2015 Author Share Posted June 1, 2015 As far as I can tell, they only make one hub for the L6 that has a V-belt pulley. The other has no accessory drive at all. Here are more pics: It's being mounted on the engine dyno today. Quote Link to comment Share on other sites More sharing options...
