My 2jzge Build
Livin9it2up1
This project stared back in march after i melted Cyl 4 in my l28et from a clogged injector. after talking to a friend who owns a shop for a couple of hours i came to the conclusion that i was gonna do a 2jzge from an sc300 built up, i was eventually going to Na-t it. I'm not looking for big numbers probably around 350 400 HP. I have been taking pictures the Entire way but haven't had the time or patiences to post them up on here. please dont make fun of my stuff, i know some of it probably doesn't look good but i spent a lot of time getting it all right. Thankyou guys for the positive comments but please keep the negative ones to yourself. (unless its something that i overlooked that could probably help me)
The day i got the motor
Head removed for cleaning and Complete check
Block Painted and halfway assembled
EGR Block off plate
Mounted in the car, i know its a little crooked there is not a tranny mount at this point.
Custom intake manifold
Wiring fun
love that intercooler too bad i had to trade if for a new ecu
wiring complete
Thanks guys! it was pretty easy to make the ffim i went to my local metal supplier and bought a piece of sheet metal i believe it was 4ft x 5ft 11 gauge sheet and just went too town on it. took about 2 days i would say a total of 6 hour to complete. it runs great now! i just need an exhaust to complete!
Sweet, dude! Would love to see how you did the mounts and know your method to align everything.
As to my method of aligning everything i just hung the engine in the bay and fine tuned the angle and alignment with jacks until i got it right. I measured from the bolt for the crank pulley to the rails to get it centered in the engine bay.
At first i was going to go with the beta Motorsports kit but i decided against it due to the cost of it. So i went with the idea of fabbing up my own mounts. i had 2 options, first being make a cross member and building mounts off of that, second being coming right off the frame rail in the engine bay. For the sheer cost of things and simplicity i went with coming off the Frame Rails. I can only find picture of them before i boxed them in, but the show the gist of how i made them. By the way i made them out of 11 gauge cold rolled steel.
I went down to my local Napa and went through there catalogs till i could find a rubber mount that fit my needs, needs being as skinny as possible to save room. They Rubber mount is literally 2 millimeters away from the steering shaft.
did you use the beta motorsport mount kit?
I didnt use the Beta motorsports kit
Edited by Livin9it2up1
You measured it right in the center of the frame rails for the crank bolt? It's actually offset a bit to the passenger side about 3/4" inches if I recall.
yeah thats what it seamed like i had to offset it anyways just a little bit to clear steering components...
In your first picture, is that a piece of flat steel bar bent into a U, then welded to the frame? You said you boxed it afterwards? If so, how'd you make that bend?
yeah basically.. i bent it with a lot of force and some heat
Am I the only one that thinks those engine mounts look dangerous? Even if you did box them in, I don't think I would trust them.
That was my concern, and the reason behind my question. Heating and bending metal can leave residual stresses, and cause the metal to become brittle... The boxing in will add strength, but i would worry about those points for fatigue...
less heat more bending, my torch ran out before i even got anywhere with it thats why i said some heat ha. but i guess thats good to know! i guess running out of gas was a good thing!
You all are probably gonna find alot of flaws in this project. There is Probably going to be things that your not going to like. Please remember this car was built on a pretty low budget and im doing what i can with my resources and funds available. I'm not going to be shocked if things break later on, or stuff starts wearing out. This car is strictly a project that i hope one day in the future that i could get back on the road.
I was also shocked when I saw how hybridmotorsports(above yellow pic) did their motor mount. I was a bit concern about it failing on them but then when I really think about it, all the power is delivered out the back, not the sides of the engine, since the side mounts just holds it from rocking side to side. I would think the rear end and the tranny mount will take most of the beating. But I went ahead and over killed my mount anyways.
