280zx alternator....turbo vs na?
IIRC the turbo model was 70amp while the NA was 60amp. That could be a myth though.
Not a myth, I did a turbo alt. Swap. Please say this again? Special connector? You got ripped sorry to tell you. All you need to do is splice 2 wires from the external voltage regulator and your finished. Plug in, bolt on. Get the turbo alternator it gives you more power. Fixed issues I was having with under power for my lights and stereo. I was having a cut off issue where the horn would turn off the radio and such.
Be careful that you actually get a 70 amp, looks like the auto parts store have simplified to 60 amps for everything. Here's a link to O'Reilly's listing for an 83 Turbo and they show 60 amps, with compatibility to other non-turbo cars -
http://www.oreillyauto.com/site/c/search/Alternator/01468/C0330.oap?year=1983&make=Nissan&model=280ZX&vi=1209406&keyword=alternator
The "special connector" just jumps the wires that need jumping, plus comes with the diode installed correctly to prevent the engine from running when the key is turned off. If you're upgrading a 240 (280s don't need the diode). Pretty convenient and clean looking, not too expensive, plus it's reversible if you've got a classic. Doesn't really look like a rip.
http://www.thezstore.com/page/TZS/PROD/12-4067
Edited by NewZed
