GTZ Posted January 17, 2011 Author Share Posted January 17, 2011 On 1/17/2011 at 7:49 AM, garvice said: Must not have explained it correctly, I am only using the mount that the ears attached too, I will build new ears off of this. Check out the following pictures to explain it better. And this is the start of my crossmember ok i see what you mean. well you have almost all of it done. cool looks good. should be easy to now. Quote Link to comment Share on other sites More sharing options...
GTZ Posted January 20, 2011 Author Share Posted January 20, 2011 I was wondering what are people's views between running a pull or a push fan when running a intercooler. Quote Link to comment Share on other sites More sharing options...
GTZ Posted January 24, 2011 Author Share Posted January 24, 2011 Engine bay is getting buttoned up now. Doing the final install on the hood and installing the hood pins. More pics coming soon. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted January 30, 2011 Share Posted January 30, 2011 On 1/20/2011 at 7:46 AM, GTZ said: I was wondering what are people's views between running a pull or a push fan when running a intercooler. pull fans are more effecient, thats what i am installing on my swap, using 11' spal HD puller. i think rb26powered74zcar uses the same one. i am setting up for AC as well so i am hoping that will be enough for the condenser too, but i might have to put a pusher on that. i have a 4" thick intercooler. Quote Link to comment Share on other sites More sharing options...
GTZ Posted January 31, 2011 Author Share Posted January 31, 2011 On 1/30/2011 at 11:48 AM, ZT-R said: pull fans are more effecient, thats what i am installing on my swap, using 11' spal HD puller. i think rb26powered74zcar uses the same one. i am setting up for AC as well so i am hoping that will be enough for the condenser too, but i might have to put a pusher on that. i have a 4" thick intercooler. Thanks for the info ZT-R. I will try it both ways and see which works best. I want to do a pusher setup as that will hide the fan between the IC and rad for a cleaner look. Quote Link to comment Share on other sites More sharing options...
GTZ Posted January 31, 2011 Author Share Posted January 31, 2011 a little up date. I am finally getting my ecm back from AEM after accidentally frying it. Really sad as I had to cough up $600 to get it repaired. AEM put all brand new internals on it so I guess its like new now. AEM ECM 30-1400 which is actually pnp for a 86-93 fox body mustang. It was actually not that hard to make it work for the rb25det. I only have the engine components hooked to the ecm and nothing else. fuel pump and engine fan are all standalone setups. ecm connection break down 3.5 bar MAP TPS AEM water temp sensor AEM AIT sensor precision 1000cc injectors RB25 cas with aem wheel 3 coil output (wasted spark) 2 knock sensors aem wideband (hooked to ecm only for data logging) car is a little rich at idle (12.9-13.4 afr) but I don't mind it as I am not running the air regulator valve. Its normal for cars to run a little rich at idle with big injectors and MAP based tune (words of my tuner). ECM is pretty easy to tune and I can't believe how smooth the engine runs with it. Next I will get some dyno time and see what i can get out of it. I will have JE 86.5 pistons rb26dett pistons and rb26dett N1 crankshaft in the bottom end by the end of this year. Collecting pieces at this point have the N1 crankshaft on order from nismoparts.com so far. Quote Link to comment Share on other sites More sharing options...
GTZ Posted February 3, 2011 Author Share Posted February 3, 2011 Its ALIVE its really ALIVE i can't believe that I got it ALIVE. I am excited aem ecm arrived today. got all the wires squared away and its awesome. it runs smooth. need to set base timing. damn this things is great Quote Link to comment Share on other sites More sharing options...
GTZ Posted February 17, 2012 Author Share Posted February 17, 2012 I got tired of looking at that bulky booster and decided to rip it all out and the pedal assembly was also removed. I went with Wilwood dual master cylinder and dual pedal assembly. I haven't seen it done on a Z yet but it was fairly painless besides converting the metric to standard brake lines. Its fun playing around with the brake bias and I set it semi mild. I made my own on the fly brake bias set up using the stock Z speed cable cut to length and machined shift knob for the adjusting knob. I'll update on the feel and feedback as soon as i get it on the road. Quote Link to comment Share on other sites More sharing options...
5thgenluder Posted February 19, 2012 Share Posted February 19, 2012 Awesome work. We need pics and videos of it running and Id love to see this brake setup. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted February 19, 2012 Share Posted February 19, 2012 Nice brake setup, lets see it. Quote Link to comment Share on other sites More sharing options...
GTZ Posted February 21, 2012 Author Share Posted February 21, 2012 This was before the new tires were installed. This was just trying out the new 3.70 diffs. First official race against a 2jz before changing the wastegate and BOV to snapse. I will post the brake pics really soon. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted February 21, 2012 Share Posted February 21, 2012 Wish i had some slicks. I need to break out my go pro. Quote Link to comment Share on other sites More sharing options...
GTZ Posted February 22, 2012 Author Share Posted February 22, 2012 I would like to try some slicks on my car as well. I haven't seen a set of tail lights yet on street tires. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted February 22, 2012 Share Posted February 22, 2012 I dont know how your getting traction with a gt42... Quote Link to comment Share on other sites More sharing options...
GTZ Posted February 23, 2012 Author Share Posted February 23, 2012 I don't but that's half the fun. lol Quote Link to comment Share on other sites More sharing options...
