CarolinaTZ Posted March 1, 2011 Share Posted March 1, 2011 I know the strut tubes on the 280Z are slightly larger than say, the 240, (mine measured 2.1...") and the typical 2" coilover sleeve ID is too small to fit over it. Is the OD for the 280 coilover sleeve the same OD as the typical 2" ID sleeve? I'm assuming the 280 sleeves are thinner wall (having the same OD and a larger ID). Am I correct? I want to take a typical 2" coilover sleeve and machine it to fit my 280 tubes but wasn't sure if it would make the tbe walls too thin. Has anyone done this? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 1, 2011 Share Posted March 1, 2011 Just buy the right sleeve. I am pretty sure www.colemanracing.com has them, and they are not expensive. Quote Link to comment Share on other sites More sharing options...
johnc Posted March 1, 2011 Share Posted March 1, 2011 There are 2.17" ID coil over sleeves available. I sell them or you can search Coleman or some of the circle track racing sites. Quote Link to comment Share on other sites More sharing options...
CarolinaTZ Posted March 1, 2011 Author Share Posted March 1, 2011 If one of you guys wants to buy me a set feel free I know they're available. I just need someone to measure the OD of a set of 280Z threaded coilover sleeves. I already have a set of sleeves and a lathe. If the OD of the 240 and 280 are the same, then I'll make make these work. Quote Link to comment Share on other sites More sharing options...
johnc Posted March 2, 2011 Share Posted March 2, 2011 If one of you guys wants to buy me a set feel free I know they're available. I just need someone to measure the OD of a set of 280Z threaded coilover sleeves. I already have a set of sleeves and a lathe. If the OD of the 240 and 280 are the same, then I'll make make these work. On the ones I buy the OD is the same, they use the same adjustable lower perch. Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted March 2, 2011 Administrators Share Posted March 2, 2011 Yes, the sleeves commonly available for 280Z's are thinner walled. The set I have here, that came from Ground Control, measure approx. 2.206" ID. If I remember correctly, they could be a smidge smaller and still fit over the tubes. Quote Link to comment Share on other sites More sharing options...
CarolinaTZ Posted March 2, 2011 Author Share Posted March 2, 2011 That's what I needed to know. Thanks a bunch, guys. I should be able to use these. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted March 2, 2011 Share Posted March 2, 2011 I can't find the 2.17in (55mm) sleeves anywhere. It seems that is the common Koni sleeve size. Can I just buy sleeves for Koni's then? Colemanracing doesn't list anything for 55mm or 2.17in sleeves. Quote Link to comment Share on other sites More sharing options...
CarolinaTZ Posted March 2, 2011 Author Share Posted March 2, 2011 Beta Motorsports and Modern Motorsports both carry them. Ground Control carries them too...but with GC, I don't think you can buy at a component level...they'll only sell you a whole kit...springs and all. I couldn't find the larger diameter at Coleman either. Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted March 3, 2011 Share Posted March 3, 2011 Not sure if this'll help, but: From A1 Racing: (http://shop.a1racing.com/) - Threaded Alu sleeves: 4 x COK12452-H @ USD18.80 ea - Lower spring perch/nut: 4 x COK12460-B8 @ USD12.87 ea - Coil-over top: 4 x COK12465 @ USD13.08 ea From: http://forums.hybridz.org/index.php/topic/63506-daily-1978-280z/page__view__findpost__p__674248 (my build thread, '78 280z) Dave Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted March 4, 2011 Share Posted March 4, 2011 Awesome that helps a lot. Any chance you can fix the pictures in your post? Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted March 4, 2011 Share Posted March 4, 2011 Believe me, I would if I could edit the posts. There appears to be something where you can only edit them for a period. I've since reorganized the gallery, but you can get the jist there: http://forums.hybridz.org/index.php/gallery/album/1220/663-280z-coil-overs/ Dave Quote Link to comment Share on other sites More sharing options...
