Dannyh4 Posted March 6, 2011 Share Posted March 6, 2011 (edited) so i bought one of these a while back http://cgi.ebay.com/ebaymotors/RB25DET-SKYLINE-R32-R33-R34-INTAKE-MANIFOLD-POLISHED-_W0QQcmdZViewItemQQhashZitem588ceb227fQQitemZ380321342079QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories . I was wanting to know what people did to get the neck for the radiator hose to stay in the intake manifold. right now it can pull out. Edited March 6, 2011 by Dannyh4 Quote Link to comment Share on other sites More sharing options...
jakeoster Posted March 7, 2011 Share Posted March 7, 2011 Seems like most people use an rtv sealant or similar to get that thing to stay put. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted March 7, 2011 Share Posted March 7, 2011 i would weld it, but i have a tig Quote Link to comment Share on other sites More sharing options...
R33rr Posted March 7, 2011 Share Posted March 7, 2011 you can try JB weld ... rough up a bit on both mating mating surface apply JB weld let it sit and dry for 24 hrs. .. its a shot Quote Link to comment Share on other sites More sharing options...
ZT-R Posted March 7, 2011 Share Posted March 7, 2011 yea im sure jb weld would work. i just like welding Quote Link to comment Share on other sites More sharing options...
Dannyh4 Posted March 7, 2011 Author Share Posted March 7, 2011 yea i think i am just gonna try jb weld first Quote Link to comment Share on other sites More sharing options...
iBang Posted March 8, 2011 Share Posted March 8, 2011 We used JB weld and it worked out fine, but it looked crappy. I plan on either tigging on a aluminum tube or an AN bung depending on which way I go with my radiator hoses in the new car. Quote Link to comment Share on other sites More sharing options...
rayaapp2 Posted March 8, 2011 Share Posted March 8, 2011 RTV isnt a great idea. Epoxy it in there. traditional JB weld not the instant or fast curing stuff should do the trick. I did one manifold that way. Ideally it would be press fit in and epoxy'd like a freeze plug if that gives you a good idea. I ended up buying a Greddy in the end. Well worth it for the quality. Quote Link to comment Share on other sites More sharing options...
iBang Posted March 9, 2011 Share Posted March 9, 2011 Sadly the real greddy manifolds have the same problem, or at least mine did. Quote Link to comment Share on other sites More sharing options...
dizzle Posted March 12, 2011 Share Posted March 12, 2011 I had the same problem, I drilled a hole close to the edge, tapped it. The RTV'd the hose adapter, set it in and tightened the bolt in the tapped hole. Had it in there for 2 years no problems, no one even notices... Quote Link to comment Share on other sites More sharing options...
rayaapp2 Posted March 14, 2011 Share Posted March 14, 2011 My Greddy manifold did not have this issue. It was installed before it was boxed. It was all in original packaging still. It appears to be a simple press fit. Quote Link to comment Share on other sites More sharing options...
