Help Fitting Zg fender flares front
  • Please log in to reply
8 replies to this topic
#1 mark240z
mark240z
    Newbie
  • Members
  • Pip
  • 12 posts
  • Locationengland
Posted 02 November 2016 - 10:51 AM
Hi I'm currently in the process Of fitting my flares, I've cut out the front arches and fitted the flare but I'm unsure if I need to reinforce the front wing to take the flex out where I've taken the lip off or will it be ok ?
#2 cgsheen
cgsheen
    Junior Member
  • Members
  • PipPipPipPipPip
  • 529 posts
  • LocationArizona
Posted 04 November 2016 - 02:40 PM
(Oh, "wing" = "fender".  At first I was scratching my head about "reinforcing the front wing"...  I got the "boot", "bonnet", "propeller shaft" and etc. when I had the Midget and TR6 in my younger years, but never knew "wing" until later in life.  Sorry - that popped into my head when I finally saw your location.  Many of us Yankees won't equate wing with fender...)
1974 "Early" 260Z: '83 L28ET - F31 ECU MAF Coil TPS - T04E - FMIC - 400cc Injectors - MTX-L wideband - NIStune enabled! - '83 5 speed - coilovers - Big Brakes up front - Sakura Garage, Tempe, AZ
#3 seattlejester
seattlejester
    Totally Addicted
  • Donating Members
  • PipPipPipPipPipPip
  • 1827 posts
  • LocationBellevue, WASHINGTON
Posted 04 November 2016 - 04:02 PM
I am pretty sure adding the flare adds rigidity back into it. I haven't seen anyone add anything under the fronts.
#4 88dangerdan
88dangerdan
    Always Here
  • Donating Members
  • PipPipPipPip
  • 254 posts
  • LocationStockton Ca
Posted 05 November 2016 - 10:59 AM
I ended up folding over a 1/4" to add stiffness and lose sharp edge
Attached File  20161103_081351.jpg   84.18KB   6 downloads
#5 seattlejester
seattlejester
    Totally Addicted
  • Donating Members
  • 1827 posts
Posted 05 November 2016 - 04:30 PM
^There you go, the 3 or 4 guides I have seen and the dozen or so cars I have seen don't seem to bother with them. I have always wondered about the edge left over, that is a pretty elegant solution.
#6 88dangerdan
88dangerdan
    Always Here
  • Donating Members
  • PipPipPipPip
  • 254 posts
Posted 05 November 2016 - 06:52 PM
Thanx^^
#7 mark240z
mark240z
    Newbie
  • Members
  • Pip
  • 12 posts
  • Locationengland
Posted 05 November 2016 - 11:23 PM
Hi thanks for all your input I think I'll leave the edge as it is when it's cut
#8 JoeK
JoeK
    Always Here
  • Members
  • PipPipPipPip
  • 188 posts
  • LocationOakland, Ca
Posted 07 November 2016 - 06:52 PM
What did you use to fold the lip like that?
1971 240Z - LS1 swap in progress. Just need to: get wheels, drop the car from the rotiserrie, install the motor and trans, rebuild my dash, put in a new interior plus a few more odds and ends (about $10k in incidentals). Should be on the road before my 5 year old heads off to college.
#9 88dangerdan
88dangerdan
    Always Here
  • Donating Members
  • PipPipPipPip
  • 254 posts
Posted 08 November 2016 - 08:29 AM
I just used a small pair of channel-locks. Didn't try and get it all in one bend,made a couple of passes. Then used a finishing hammer and a wood block to flatten out.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
