Nissan Quest stud question
#1
Posted 30 May 2006 - 10:48 AM
Just bought Nissan Quest studs. Went to put them in and they seem to need to be pressed in. Through searching I found zcarnut said in a post to buy rears, but I found that after buying fronts. But the only reason I bought fronts was because the Napaonline.com showed front and rears both have same part numbers, and the decriptions are the same sizes.
Anybody got any insight on this? The ones I bought seem sooo close its not even funny, but I quickly banged at them for about 20 seconds, then looked at them and figured I'd just press them in, it seems they are the right ones but brand new so a little larger.
#2
Posted 30 May 2006 - 10:55 AM
#3
Posted 30 May 2006 - 11:03 AM
#4
Posted 30 May 2006 - 11:45 AM
#5
Posted 30 May 2006 - 12:13 PM
The correct NAPA part number for the Quest rear stud is 6412785. The front is a 6412786 (different part number).
You can also use studs from Dorman. The Dorman part number is 98363:
Here is the front Quest stud (for comparison):
Huntsville AL
1970 240Z 1974 260Z 1979 810 2008 G37S
"35 years of Z car ownership"
#6
Posted 30 May 2006 - 12:17 PM
#7
Posted 30 May 2006 - 12:47 PM
#8
Posted 30 May 2006 - 03:49 PM
#9
Posted 30 May 2006 - 10:14 PM
#10
Posted 08 May 2012 - 07:14 PM
Z stock front stud : 610-240
13mm knurl
32mm long
10mm shoulder
Z stock rear stud : 610-320
12.83mm knurl
41.5mm long
14mm shoulder
THEN they list 610-403 as the 'overlength stud' for the 610-240!!
12.9mm knurl
45.5 long
15mm shoulder
Detailed Applications for the 610-403
Year Make Model Engine Application Notes
1998 NISSAN QUEST: GXE V6 - 3.0L (2960 CC): GAS: FI: N: VG30E
• Rear
1998 NISSAN QUEST: XE V6 - 3.0L (2960 CC): GAS: FI: N: VG30E
• Rear
1997 NISSAN QUEST: GXE V6 - 3.0L (2960 CC): GAS: FI: N: VG30E
• Rear
1997 NISSAN QUEST: XE V6 - 3.0L (2960 CC): GAS: FI: N: VG30E
• Rear
1996 NISSAN QUEST: GXE V6 - 3.0L (2960 CC): GAS: FI: N: VG30E
• Rear
1996 NISSAN QUEST: XE V6 - 3.0L (2960 CC): GAS: FI: N: VG30E
• Rear
1995 INFINITI J30 V6 - 3.0L (2960 CC): GAS: FI: N: VG30DE
• Front
1995 NISSAN QUEST: GXE V6 - 3.0L (2960 CC): GAS: FI: N: VG30E
• Rear
1995 NISSAN QUEST: XE V6 - 3.0L (2960 CC): GAS: FI: N: VG30E
• Rear
1994 INFINITI J30 V6 - 3.0L (2960 CC): GAS: FI: N: VG30DE
• Front
1994 NISSAN QUEST: GXE V6 - 3.0L (2960 CC): GAS: FI: N: VG30E
• Rear
1994 NISSAN QUEST: XE V6 - 3.0L (2960 CC): GAS: FI: N: VG30E
• Rear
1993 INFINITI J30 V6 - 3.0L (2960 CC): GAS: FI: N: VG30DE
• Front
1993 NISSAN QUEST: GXE V6 - 3.0L (2960 CC): GAS: FI: N: VG30E
• Rear
1993 NISSAN QUEST: XE V6 - 3.0L (2960 CC): GAS: FI: N: VG30E
• Rear
1988 NISSAN VAN L4 - 2.4L (2389 CC): GAS: FI: N: Z24i
• Front; From 1/88
1987 NISSAN VAN L4 - 2.4L (2389 CC): GAS: FI: N: Z24i
• Front; From 1/88
Phil - 1978 280z + 4.6L SOHC Ford
#11
Posted 08 May 2012 - 07:46 PM
383 sbc bit over 400 hp. Arizona z car rear arms and moustach bar. Also diff mount.
#12
Posted 08 May 2012 - 09:02 PM
Take a chill pill. He's adding additional information to the thread.Why do people keep asking stuff or posting on such old threads. Read the date on the last post. When 6 years old it is dead
Edited by mrcheeze36, 08 May 2012 - 09:07 PM.
72' Datsun 510 - RHD
#13
Posted 08 May 2012 - 09:07 PM
I got the rear quest studs if I remember right, I think I just tapped them in and it went perfectly. If your having to smash them in theres is a problem as you have found out.
78 280z Dark Shadow Grey 2+2: L28et, MS2, HX35W, FMIC, Tial WG, Tokicos, Rear Disks, bla, bla, bla.
#14
Posted 09 May 2012 - 09:11 AM
I'm going to give those Rear Quest studs a try, it looks like the rear Z studs would work, but I like the fact that the Quest studs are closer on the knurl diameter. $1.70 at the local parts store. They have 260 in stock. Why would you need so many in stock???
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
