YEH!!!
I got it solved!
- I had short linked to ignition black blue and black yellow, as my "s" on ignition was not getting switched. From the measurements I noticed that via the ignition coil, 12volts is also active back from the black-blue in the "on" setting. Due to the short link, the pump/injection relais switched both relais at the same time, causing a mess in that control circuit.
- I fixed the ignition switch first, and got that sort of solved (bad chinees replica)
- Now still no power in the pump, with the strange things as described before
- I started pulling plugs again, and then I also noticed the seat belt warning light was off. I disconnected the seat belt (which i had locked months ago to avoid the beep), and tried again. Suddenly I got the beep-beep sound again.
- Tried it the ignition again , and it worked!!! I think the seat belt relais was stuck and causing some leak, and that together with the bad switching on the relais from the bad ignition switch, and my short link.
Now I got my fuel pump working, and engine running (after an explosion in my improvised air intake hose, due to starter fluid). Engine starts nice, but drops after 5 seconds. Think my fuel level is too low. Man...! lots of fuel is needed to be put into that tank before the outflow nozzle is reached from totally empty.
Thx for all the help, and I' m sure I will need some more soon:-)
Joost
