Leaderboard
Popular Content
Showing content with the highest reputation on 05/28/23 in all areas
  1. Reapairing Right Side Dashboard Ac Vent Hose- The Right AC Vent 2"Hose was broken off from the Duct Vent. So a method to reconnect that hose would have to be found. I diecided to use a 3' piece of 2" radiator to"splint' the Vent Hose to the plastic Vent Housing. Used the Hot Glue Gun to adhere the Spint to the Vent Housing. Inside View of the Splint The Finished Repair if the AC Vent Hose and Duct I had to fabricate a Micro Phillips Screwdriver to remove the Three Phillips Heas Screws to Chrome Duct Vent. This Micro Phillips Screwdriver also was used in other 'tight spaces" where normal phillips screwdrivers would not fit. Modifying the Dashboard Center Vent- The Original Center Console Vent only had a small piece of foam around the vent tube leading to the Blower Box. I decided to construct a sheet metal Tube that provide a tighter seal to Outlet Vent. Making Template for the Vent Connector Bending the sheet metal with a 5/8" deep socket to match the template shape. Finished AC Vent Connector Next-Heater Blower Fan Replacement
    1 point
