I get this quesiton daily. Assuming you've spent money and time building adjustability into your suspension AND are willing actually adjust then these recommendations make sense. Otherwise, take the car to Pep Boys, tell the tech to "Make it all green", and hope your tires last a long time.
Track/Autocross
For 225 to 245 width radial DOT tires try these alignment settings:
Front
Camber: 3 to 3.25 neg
Caster: 6 to 7 positive (even on both sides)
Toe: 1/8" to 3/16" out
Ride height: 5 1/2" to 6" measured at the front of the rocker outboard of the pinch weld seam.
Rear
Camber: 2.5 to 3 neg
Toe: 1/16" to 1/8" in
Ride height: 5 3/4" to 6 1/4" measured at the front of the rocker outboard of the pinch weld seam.
For tire widths over 245 try these alignment settings:
Front
Camber: 2.75 to 3 neg
Toe: 1/16" to 1/8"" out
Ride height: 6" to 6 1/2" measured at the front of the rocker outboard of the pinch weld seam.
Rear
Camber: 2.25 to 2.5 neg
Ride height: 6 1/4" to 6 3/4" measured at the front of the rocker outboard of the pinch weld seam.
Street
Front
Camber: 1.25 to 1.5 neg
Caster: 4 to 5 positive (even on both sides)
Toe: 1/16" out or 0
Rear
Ride height: 6 1/2" to 7" measured at the front of the rocker outboard of the pinch weld seam.
Front
Toe: 1/16" out or 0
Rear
Ride height: 7" to 7 1/2" measured at the front of the rocker outboard of the pinch weld seam.
Caveat Emptor: These are starting points for you and your car. Be ready and willing to change them based on your preferences and local conditions. These alignment settings might be a bit tricky in the rain and even trickier in snow or ice. Your tires will wear a bit faster then the stock alignment settings. If that's a concern of yours, stay with the stock numbers and don't ask me dumb quesiton like, "Well... how much faster will they wear?" or "How many miles will the tires last with the Track alignment setting?" If you're asking those questions you shouldn't be reading this thread. Go buy a Honda...
