Leaderboard
Popular Content
Showing content with the highest reputation on 07/11/24 in all areas
  1. I just complete the install of the MFactory LSD in my 1978 280z and wanted to share my experience. First, I am a reasonably good shade tree DIYer and I found the installation to be very easy. I did have to purchase a dial indicator on amazon ($60) to check the lash on the ring and pinion as part of the installation but everything else I needed was standard stuff in my toolkit. I also replace the carrier bearing with ones I found on RockAuto ... TIMKEN 30209C (Standard Replacement) for about $95. I don't know if I was lucky, but the ring and pinion lash was well within the specifications using the original factory shims so no changes were needed there. I also found the ring and pinion gears were in excellent condition overall with good mesh pattern. The most time consuming part of the install was getting the differential out. My car's driveline is largely stock with the exception of the 280zx turbo half shafts using with Milkfab adaptors. So far everything appears to be tight and right. Why did I bother to do this? I bought the car online about 4years ago. Of course I did the right thing and purchased it sight unseen (based on description and pics) and found I had a leaky head gasket shortly thereafter. The car had sat for a few years prior to my purchase so I was not completely surprised it needed work. Luckily the coolant only leaked into #1 piston and I caught it very early. As I sorted it out I discovered the engine was a Rebello stroker (3.1) -- lucky me. Once I got things straightened out I found a drive line clunk and so I was off trying to fix the problem. I tried to work through the lower cost items first so I replaced the diff mount, secured a technoversions diff mount snubber, upgraded to zx turbo half shafts (rebuilt junk yard finds) as well as new 1310 ujoints for the prop shaft. Still no joy as the clunking continued. That meant I needed to check the differential center section. What I found was a lot of slop in the center section but the ring and pinion in great shape. I guess I could have gone the route of a rebuild of the open diff but, truth told, I wanted the LSD option and chose the MFactory option. So far, so good. I would also add that the purchase experience was very easy with the unit arriving within a few days after payment and exlifesaver provided advice on the install. Thanks again.
    2 points
