Leaderboard
Popular Content
Showing content with the highest reputation on 09/16/24 in all areas
  1. More pis of it finished up The bottom plate was beat up a bit and bent from floor jacks. So I took off the old one by drilling out the spot welds. I then drew up the shape and had a new one laser cut. The center plate that is welded to this plate, I re-made it as well, but out of 304 stainless steel. This way I can leave it a brushed stainless finish after powder coating and it is a good place to use a floor jack. I then spot welded on the larger plate in the original locations I then tigged the seam between the spot welds Then tigged on the center stainless plate Then blasted the entire cross member and powder coated it in a super black semi gloss powder coat. Powder coated the motor mounts as well I always first do a primer powder coat that is sandable I sand most off this off to fill the small blemeshes Then final coat Finally the brushed stainless plate for the floor jack Next up is getting a new transmission, then finishing the exhaust
    2 points
  2. @manimal We will absolutely be supporting this for the next five years. I personally developed it because I was tired of the alignment shop. and more alignemnt products are to come from the technology we developed to make it work. @fusion We had to take a pause on the Android development to focus on the iOS one. The main concern is many Android phones have substandard sensors that we cannot effectively filter to the resolution required for an alignment (at least 0.05 deg or 1/40 inch). We are working on updating the UI and imrpoving accuracy at the moment though, and expect something to be ready by late October.
    1 point
  3. I just bought one and it should be here in about a week. I'll let you guys know how it ends up working for me.
    1 point
