Leaderboard
Popular Content
Showing content with the highest reputation on 06/08/25 in all areas
06-07-2025. More work on the Z car. Swapped out some fouled plugs for a new set of NGK BPR6ES plugs. Gapped at .032 and I put a daub on anti-seize on the threads to make them easier to take out eventually. Then I swapped out my thermostat, and started the car and it works! After that, a long item waiting project.....drilling a second set of holes in the stainless steel washers I use with my hood pins. They have 6/32 screws holding them in place. After getting everything on the engine sealed up, I started it and it smokes like an old 2 stroke SAAB. The back firing situation that blew my hoses off apparently blew out the carbon seals I had in my turbo, so the turbo had to come off so I can get it fixed. at the same time, I removed the brake master cylinder and booster. Initially I was going to eliminate the booster and enjoy all that space, but results are very mixed on doing that, save for the professional setup made by Chase Bays, that costs $750 for the master Cylinder and then you need flexible fines to go from the master cylinder to the proportioning valve. I have decided to re-drill mounting holes and move the booster and master cylinder over to the right about an inch. This will give me the much needed room to put in a heat shield between the master cylinder and the turbo and exhaust. To keep the pushrod for the brake booster straight, I will take a piece of thick steel and drill 2 holes, 1 inch apart with a hole drilled in one side where the original rod will go through with a nut on the front side that will be welded to the plate and then tack the rod flush with the steel plate. Then the other hole will be 1 inch over and will be where the clevis will hook on to the brake pedal leg. saves me some money, get to keep the nice brakes and look much better etc. in the engine bay. Pics follow. Cheers!1 point
