Been a while since I posted any updates. Been moving along. For the Turbo car I decided to build my own wheels. Ill CNC machine the center sections myself and have the lips and barrels spun for me. I really like the old SSR RS8 wheels but finding them in the correct bolt pattern, offset, and caliper clearance is impossible. I fould a set close, from Japan and had them shipped over. Since this car uses Z31 hubs and such, the spacing is out much more than a standard Z so I need a bit more positive offset.
I dissasembled the wheels and scanned the center section into my computer and reverse engineered the shape.
Next I re-assembled them and had the 245-45-16 tires Im going to use mounted. I test fitted them to the car, and close, but not good enough. This is the fist time this chassis has been rolling on its own wheels in 27 years. Its been on a cart or a lift. Felt good to see some progress now that the suspension, brakes, and cross-memeber are finally complete
Scanned this complete assembly and put it in CAD. Now I have the exact shape of the tire on the rim.
Cool cross section of it.
Finally I scanned the side of the car, put it into CAD. Now I can adjust my wheel center offset for caliper clearance, and adjust it to work with new Lips and Barrels I will order for the proper offset and fit to the car.
Having it in CAD alowed me to look at it from every angle and check all clearances, for calipers, springs wheels lip, ect.
Even compressing the suspension to make sure I have fender clearance at full travel
Final wheel spec is:
Rear - 5 lug = 245-45-16 on 8.5" width rim- 27mm positive offset, 2.25" outer lip on the rim
Front - 5 lug = 245-45-16 on 8.5" width rim - 31mm positive offset 1.75" outer lip on the rim
Next I need to find some time to program the CNC and start cutting chips. But I got distracted on the NA car, so that update is next.
