toolman
    25
Everything posted by toolman
  1. Bottom view of floor after welding and removal or cleco clips and screws. As far as verdict on using structural adhesive is still pending. It works fine for small metal patches without welding. However, using it on parts that will be welded afterwards, there is some burning and smoke when welding. So although they say you weld after it dries, I think there is contamination of the welding with the smoke. I have not had a chance to test the adhesive by prying a glued portion yet. Will get back on that evaluation.
  2. New method of attaching replacement floor pan to car body-two part structural adhesive. After applying adhesive to both sides, the replacement floor pan and body must be held together for 4 hours to cure. Cleco clips and metal screws can be used to hold panels together. Bottom view of floor pan showing screws and cleco clips Using the structural adhesive to repair a small rusted area. Tomorrow, the cleco clips and screwscan removed after welding the seams together. The screw holes will patched using the adhesive with a tooth pick and acid brush.
  3. Thongs are acceptable wear except when welding. Hammer welding was used when both sides are accessible. Must use a dolly on backside to hammer weld flat after welding with steel rod. The advantage is the weld is flat on both sides. Any welding on the Datsun 25 gauge metal requires a lot of patience.
  4. corner opening left front of floor pan using a bench vise slowly pound in circular pattern from inside to out. Open jaws as you increase pounded area. used the vise jaws to bend the top edge of pan after matching the patch, tack weld patch to pan check pan alignment then final weld patch
  5. Decided to strengthen the left side panel because of all of the corrosion. So I added a 16 gauge piece welded to the side panel and firewall. trail fitting the piece in place welding strengthening panel in
  6. toolman
    P1030494
    From the album: PREMATURE RESTORATION
    <br />
