Dp351zcar
About Dp351zcar
  • Birthday December 30
  • Location
    Washington
Dp351zcar's Achievements
Newbie
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
0
  1. Those headers don't fit a 351(I mean it hits the steering shaft) when it's mounted like that but after a slight tweek it should work OK. Mine may be mounted a little lower which may cause more of a problem. Don
  2. You might try summit #SUM-G9063 The are shorties and I bent the right side a little and bolted them on the left side and it clears the steering shaft by just a little. The left side bolted on the right makes it clear the starter and might come out in front of the crossmember motor mount. It's worth a try. Don
  3. I kinda think it would ruin the cornering and would need one heck of a coilover kit. Don
  4. Dp351zcar
    cobra
    What track were you on when you got kicked out? That car sounds great just don't scare yourself to "death".
  5. I test fitted a AOD in my 71, the way my engine fit is with the oil pan behind the cross member. With that placement the back of the engine is right at the firewall and the tranny fit but I cut off the little blocks on each side that hit the firewall and I had removed the Z's stock tranny mounts off the tunnel. I didn't mess with it much as I am going with a T5. Good luck Don
  6. Like most of the things I have done in my life I am doing this alone. The Z is my project and my closest friend thinks I should part the car out. He is into alfa's and has the money to do it. Home and kids take a lot of my time now so if I were to do it again I would have left the six in and just made it a nice car. Don
  7. From Indy. I have tickets I got when F1 came to Indy in 2000 and the seats are so good I just keep renewing them every year even when I know I am not going. A lady bought them off the first year I didn't go and still wants to buy them when I don't use them as they are tickets in the front row of the stands staring straight at turn one. We didn't plan to go this year so there wan't time to really plan it out the way we usually (she is a planner) so we used Expedia.com got the flight, hotel and rental car. Beware of getting a hotel on the internet this time was ok but other times it was not the same place by looking at the pics. The race kinda sucked as the turn one-two crashes happened right in front of me and I was tring to get it all on a new camera which means I didn't get to see clearly and I didn't get much of it recorded. Bummer. It was worth it being there just to be around the people. People from all around the world go there for that race and it's cool to people watch. I think the F1 theme is rich older guys with younger pretty ladys. Then there is the sound of the cars which can only be described as Music Hope Indy continues. Don
  8. Well I have to be at the airport at 4:15am, bummer. On the flip side I am going to watch the US formula one race and just about anything is worth that. Am I the ony F1 fan here? Who do you think will win, as I see it there could be a very good race this year between three diffrent drivers and teams. My seats are in the front row of the stands looking at turn one. It's going to be cool. Don
  9. My 02 civic gets 36-38 MPG. When gas was going up a year and a half ago I bailed out of a 9 month old 4dr toyota tacoma (19mpg) for the civic. When is cheap I regret the lost toyota but when the cost of gas is up I like my honda better. I drive about 400 miles a week between work and getting the kids where they need to go. I agree the price of gas sucks and the only way to make it better is to use less.
  10. Terry I have heard the Weiand Stealth is a very good manifold. I kind of want to get one instead of my Victor JR but it is low on my list at this time. I think it could cut the height down but I don't know the measurements, they can be found on the web. Don
  11. Terry I just measured where the manifold sits flat over the valley (lowest point) on my motors and the 351 is about an inch higher. I used the timming cover as a reference point as they are the same on both motors. My oil pans are both front sump and are the same depth. Ford makes several diffrent pans shapes for these engines but a 351 pan will only fit a 351 because of the increased size of the main bearings. Don
  12. Thats it Terry, nail me to the wall for a slip of the keys (or brain fade). The motors did not have any exhaust on them and the 302 had the stock steel damper, the 351 is a alum Romac unit. The 302 is all stock except for the intake Edelbrock sp2p and a mild comp cam. The flex plate on the 302 only would add a couple of pounds. The 351 has alum heads and a victor jr on it and I hope everything is put back in the engine. If you want to see the the engines as I weighed them PM me with your Email address and tell me if you want small or large pics. I do not have a chev here to weigh so we could use it to use as a comparison. Don
  13. I have a 500lb scale I borrowed from a friend to weigh my motors. I have a rebuilt 302 with a stock iron heads but alum intake and the scale said 430lbs with 25lbs in balance beam and rigging. It was just the complete engine no alt, no carb, no starter but it did have a flex plate. I weighed my 351 with the same rigging but my 351 has lighter pistons (J&E) lighter balancer and alum heads and manifold, no flywheel. The scale said 420. So without the rigging. 351=395lbs ? 302=405lbs The scale is dead on as it has to be as it is used to test loads for small hoists. I know that dosen't sound right but that is what I got. I have pictures of the tests. Don
  14. As said before be carefull when checking for the rust. That motor is mounted way forward and that is one thing to think about because if it isn't exactly where you want it it will take time and effort to move it. It also said it had a C4, would you want a three speed? It was a tight fit but I did a trial fit with AOD and with my engine 1/4" from the firewall so it could work that way. Be sure that everything is just what you want before you buy. Don
  15. I didn't realize Pacific was open yet. When are you going next as I would like to see a V8 Z run. I live so close as I can sometimes hear cars running there. Don
