roller
Everything posted by roller
  1. i'm using 15x3.5 with a 1 3/4 back spacing. i want to use a 11.5 rotor. what size is the stock rotor?
  2. has anyone answered whether the welds clear the toyota calipers?
  3. jon, what does the z run on the 200hp pill?
  4. anyone have the same problem? i bend them to fit one spot then they pull and don't fit another.
  5. i have the horn button, a plastic yellowish ring, and then a round metal piece? i don't know where to put the ground wire either.
  6. i have a z car i may try to get out there. this could be interesting.
  7. is this going to have say ladder bar cars or 4 link cars?
  8. the weights you guys are giving are they with a driver?
  9. goes from the common fuse in the fuse block on a 72 240?
  10. that a lot of good info you just gave me. thanks. i do have the stainless lines but they have straight ends on them can i still use them to get rid of the bridge lines or do i have to have the 90's? also i wonder how far i have to let the pushrod go in the mc? the reason is this is a street/drag car and i had a guy make an adapter plate out of .750 alum. to eliminate the booster all together so i'm kinda fabing from scratch.
  11. should i upgrade to the 15/16 mc? i did buy the stainless braided front lines. i'm running stock calipers.
  12. also would it be a good idea to go with the 79zx mc? if so do i have to change anything? i'm running stock brakes.
  13. i don't think i want a rebuilt one unless you guys suggest a good one.
  14. Project bbz, what did you use to bond the scoop to hood?
  15. i run a f body and went from the 210-224 to the gm 846 and gained nothing.
  16. that's a big cam. i like the gm 846 but if i did it over i would go back to the crane "baby cam" it's 210-224 and it works as good as the bigger cams. i know this from results. don't over look the little cam.
