jimbo5670
Everything posted by jimbo5670
sounds good man, PM sent
My turbo just bit the dust, and I am looking for a replacement, most likely used for cost purposes. It was the stock one from a 82'. msleonard@quinnipiac.edu Thanks for looking, matt
I've got that same IC as well, no complaints, but it does weigh 10-15 lbs or so. On the plus side it is pretty well made, ran for about a year. Also on a 92 deg day at 8lbs of boost, I was only reading 105-110 degrees temp. -Matt
or should i just suck it up and get the stock ignition parts
I am giving temporally on MS and running the factory harness. Sense i don't have the distributor, i was wondering what harm it could do to run my 72' dizzy? Would the ecu still get a tach signal? it runs a crane cams xr700 static timed at 21 deg. thanks guys, matt
clogged injectors huh? I hope mine is something that simple, although im running a fuel filter, so im not sure the plausability of it, but when i get back to jersey, ill give that a shot EDIT: I didnt see that about the time issue, that would make some sense then, thanks again guys EDIT AGAIN: It died when it was running, i first assumed it ran outa gas (those worthless stock 240 guages) then i scratched that because it wouldnt run after i threw 5 gal in the tank. Is is possible I clogged the filter and/or the injectors if/when the pump sucked up all the gunk in the bottom of the tank?
i have having this exact same problem as of late, signal in MS, fuel pump running, megatune says i have a pulsewith etc, just no gas if i pull the plug, just a priming pulse, dont mean to jack the thread, but intrested in the result thanks guys, matt
ok, that does make sence because that same thing as happened my MS box before. in a fit of blind rage last night however i bought a preassembled 3.0 pcb, haha, so hopefully with the voltage protection on the new board will hold up better. take 'er easy, matt
so here is my predicimant, I have a wire running from switchable power to one wire on all of the injectors, and 3 inj hooked up to each INJ wire off of the MS (2.2), every time i switch it on, the injectors open up and dump gas, not closing. They flood the cyl with fuel i thought perhaps it was the wiring, so i pulled on injector and wired it the same way individually, and the same thing happened, the INJ wire is grounding out all of the time. did something in the megasquirt fry, or am i just overlooking something thanks guys, matt
and mattsun, ill take a look at that map too when i get home, sounds like what i was going for
I am pulling that 12x12 table (the jpeg sticky) into an 8x8, if anyone wants me to post it after im done, give me a shout, thought i could save some people ALOT of math. -Matt
even a 4 speed will work, she has held up in mine at bout stock power, and a bit of a beating
evilc- the headgasket blew, coolant everywhere, gonna swap it out friday hopefully when i get back, although im not sure how the north jersey trip would treat her, but i may be willing to try, haha -matt
if it's got a downpipe that isnt stock, and better than 2.5' crushbent, and youve willing to part with it, i am interested
fixing the z this week, id be interested if you guys are doing something
I was hoping that someone could throw up a bone stock file for an l28et, boardkid280z had close to (minus flattops) one in the map sharing thread, but the link is broken. If someone wants to hook a brotha up.. it would be greatly approciated. It's a 2.2 board, runnin fuel only with stock inj and whatnot. thanks, matt
yeah, good point
I was kinda hoping that someone could throw up a bone stock file for an l28et, boardkid280z had close to (minus flattops) one, but the link is broken. If someone wants to hook a brotha up.. it would be greatly approciated. thanks, matt
i had the same white smoke thing happen to me, it was a shorted out ecu, and the head gasket just happed to occur at the same time, you may or may not be as unlucky as me, i dono.
haha, piles of deer jumping all away from a datsun, nice and thanks boys, ill try that hose trick -matt
yeah, that was deffinatly my concern, will it leak off as well as on if i pour water into it? and do they really pop at idle?
ok, allow me to elaberate now that the frustration has subsided a bit. i had not touched the top end of the motor except for for a different valve cover. i pulled the motor to replace the rear main seal, and decided to do the bearings while i was down there. and yes the BANG i had said was deffinatly a bang, about the same loudness and sound as a car backfiring. I think i am going to do a bit of investigating later todaybut when i was looking, i could not see the source of the waterfall. By the way, nice one with the cataclysmic converter, i just wanted to use that word. thanks yall, matt
p.s. base timing is 11 and WOT timing is 20 using a crane cams x700, and it was 93 octane gas, walbro 255 pump, stock inj, Fuel pressure at 35 at idle
yes its another wtf is wrong with the car, so sorry guys in advance, hah ok, just got the engine back together, chucked it in, running stock l28et with fresh bottom end. hooked everything up, started her, running rough, wrong firing order fixed that, started it up, running a little rough, bit rich on startup took the megasquirt startup value at 70 and 80 degrees from 135 % to 132% burned it to ecu started it back up, idled at 600rpm for 1-2 sec then BANG looked at the motor, water/coolant was pouring out of what looked like the head, and it was louder running, turned it off and the rad. emptied out real quick so, everything looks like it points to the head gasket, which i GUESS could be the case, because it has about 80k on it, but it wasnt under any real stress, but i dono, im new at this, if anyone could give me a few things to check, it could greatly reduce the frustration!! by the way, it was working well, running 6lbs for a month, another reason i dont think it was the gasket, dono thanks for reading this, matt
