BirdmanZ
Everything posted by BirdmanZ
  1. Thanks guys. Evan- The core is from TurboXS and is the same one used for their Evo 8 front mount. Joel- Your intercooler was the one i had in the back of my mind when designing mine. Last night i actually got to drive the car for the first time with the RB in it and man this thing is nuts! It was only running 10 psi on a crappy tune but still put the stock L24 to shame. I still have a couple of small things to do before i can REALLY drive it but I can't wait to feel 15 psi on a good tune! Brandon
  2. Just finished up my custom intercooler last night. The core is 24x12x3.5, thought i would share with you guys. Enjoy. Here it is on the car.
  3. Thanks a bunch man! That's the last piece i need to finally get my car back on the road. BTW for those of you looking for the same piece, the spicer part number is 2-3-12461x. The Powertrain Industries number is 3103-30.
  4. Anyone have the part number for the Spicer yoke for the 300zxtt/Rb25 transmission with a 1310 series U-Joint. I can't find a stock 300zx yoke anywhere and my driveshaft shop can't reference by car make and model. Thanks. Brandon
  5. Looks like you've got a small fortune in AN fittings there.
  6. Where did you get those pre cut collector pieces?
  7. If anyone is looking to get a set of 4.10 gears for an R230 I came across this. http://604z.com/php-bin/index.php?showtopic=2151&st=0 I called Richmond Gear and they are not selling these to individuals. They will only make a run of them for this one guy. If there is enough interest i'm sure you could persuade them to make a run for the HybridZ'ers.
  8. Check this out. http://forums.hybridz.org/showthread.php?t=121559&highlight=starter Brandon
  9. If your looking for some high RPM valvetrain components for the SBC you might try giving these guys a call, they deal in used NASCAR parts. http://www.musclemotorsports.com/encom.html
  10. I love it! Seeing this car is what made me choose to go RB in the first place. Don't get discouraged man, you'll find a way to get it done. Brandon
  11. I'm not 100% sure but i believe they are made from mild steel. They are not made from stainless or aluminum because i picked it up with a magnet.
  12. Well i managed to find an oil restrictor here in the U.S. I got it from XS Engineering, only 10 bucks plus shipping! However, if you want to make one, the OUTSIDE diameter is 6.12mm and the height is 5mm. Obviously the INSIDE diamter is going to be 1.5mm. Also, one end has a slight taper to aid in starting it in the block. Thought you guys might want to know. Brandon
  13. I have a set of CRS engine mounts for my RB26. Very nice pieces for sure. If anyone is looking for a set of mounts, i would definetly recommend these guys.
  14. That's the one Stealth. Let me know if you find someone in the U.S. that has them.
  15. http://www.jdmfresh.com/about.html These guys got me mine pretty quick. They are here in Maryland so they're not too far. Ask for Brian. Brandon.
  16. Anyone know the outside diameter of the Tomei oil restrictor. I plan on having my machinist make a couple of them. I know they come with the Tomei head gasket but i already have a head gasket and don't feel like spending hundreds on a Tomei one. Thanks. Brandon
  17. http://www.chrfab.com/Transmissions.htm Look here. There is a complete clutch kit for $670. You can even get the proper bellhousing to mate a T5 transmission behind it.
  18. http://www.chrfab.com/Transmissions.htm These guys have all the answers for the northstar engines. A chevy V6 bellhousing mates up to it with minor modification. I believe Jamie T was thinking about this swap but decided to go RB.
  19. Yes, It is complete minus the bellhousing. Even have the shifter for it. The only catch is, while i was taking the bellhousing off i accidentally dropped a small roll pin down into the open hole where the shifter bolts up. So you would have to pull it apart to get the roll pin out if you wanted to use it.
  20. I don't need anything else off of it. If anyone needs anything other than the bellhousing let me know. Thanks. Brandon
  21. Looks good man, I can't wait to see some vids of this thing. Seeing stuff like this motivates me to get off my butt and finish mine.
  22. Fuel by Metallica. Always makes me drive fast.
