docaam
Everything posted by docaam
  1. Dynamat thing is done, still I need the doors to be done but that will be after I change the window channel and most probably will be at the time of audio install. Dynapad was a smaller piece so just in main three places. Some installed phone pictures was more worried about the the holes next to the fuel cell now all covered up Other areas Firewall area most important Rest all finished Car is off the jack so took some pictures Waiting for intake manifold, fuel rails and 80mm throttle body to finish off the work, parts will be here by Sunday Meanwhile doing some DIY to fit the Autometer guages, Im using the stock guage housing and installing the meters in that, sizes are bit different so gaps will be filled by Bondo and a respray on the whole dash
  2. Thanks man They are great I highly reckon it I am aware of the issue but problem was sourcing the tires which I couuldnt do. Only thing I found was these RE11 and that also need to get from US to dubai. Coming to the updates: Being a huge fan of Chip Foose have watched Overhalling again and again lol, so wanted to do 10% of what he does to the cars. Was waiting till the main work is done to start of heat and sound insulation, only thing came to my mind was Dynamat products. SWISS AUDIO FTW, They did an awesome work on my 370Z and now this they are working now on installation. For those who don't know my audio setup done by them won all the local competitions for straight two years. First they are doing a Dynamat Extreme, which will be stuck on the firewall, full floor, trunk, rear side fenders, doors and even the roof, main purpose was to reduce road noise, engine sound/vibrations and heat from the exhaust. http://www.dynamat.com/products_automotive_dynamat_xtreme.html I love the way Swiss Audio guys work, they removed everything from the car even the brake and accelerator to cover the whole area. I took some phone pics yesterday while they were doing, rest might take today Once its finished it will be covered with DynaPad, which will hopefully eliminate all heat and acoustic issues at all. http://www.dynamat.com/products_automotive_dynapad.html,
  3. Looking forward to the built nice colour choice
  4. Ok fitted the wheels and seems like problem of tire rod end hitting the wheels barrel is gone after tweaking the camber arms and TC rods or maybe because of installation of sway bars WORK CR01 15 X 8.5 and 9.5 with Bridgestone RE11 195 50 15 and 205 50 15 Coilovers are set of high level will lower at time of alignment This is the dropped height as of now Very relieved on the front ones Perfect offsets either to run on slightly negative camber or with fender flares Center cap is not fitting in the front might need some alteration Installed with Kics Neo Chrome long open lugs . I like how the rotors are peeking though the wheels
  5. Loving the work being done on the car, didn't visit them for a week but as per owner of Peak Performance here in Dubai car is almost done and will be ready from his side by this week. I took some pictures week back when they fitted the sway bars. I went with MSA sway bars both front and rear, usually people dont run rear sways on 240Z, but as I worked so much on the suspension so went with these as well. Not sure how the ride will be with coil overs, full front and rear suspension changed and all solid mounts for engine, differential. Front Sway Bar New holes drilled Fits nicely with Techo Toy Tuning TC Rods and Camber arms. Rear ones Drilled in the body and bolted from inside the cabin Oil cooler brackets are finalized Will fit the wheels today so can do the final adjustments on the camber/caster and if the track needs to be widened or not
  6. Thanks man. I am using wilwood maser cylinder. For clearance will use 5mm spacers at the front first then see how it goes.
  7. Sent the car to Peak Performance Garage in Dubai few weeks back and finally they started working on it. I always loved their work Work being done now and will be completed in few week: Intercooler piping, will do weld joints once its finalized Already changed the Radiator to another one ordered from CXRacing, its for 240z with an RB engine along with twin fan shround from flex-A-lite Moving the Intercooler a bit to the front Moving and flipping the oil cooler behind intercooler, as it was touching some body parts Changing all hoses to new silicone hoses Rerun the clutch lines Rerun the brake lines to give a more neater look Rerun the fuel lines from inside the car Relocated the fuel pump inside the car Changing differential mounts Installing MSA front and rear sway bars Installing/replacing all gauges with autometer ones Installing HKS boost controller Rest will update as it goes Removed the stock fuel filter and cleaned up lots of things. Can see the stock fuel line, piping will change now Relocating the air filter near master cylinder New Radiator, now hoses will run like stock RB engine bay, and better cooling, installed the flex-A-Lite twin fans along with shroud as before Moved the intercooler Moved the oilcooler behind the IC now
  8. Finally all mechanical part is done. Very disappointed with the whole experience with the mechanic but what's done is done so time to move on. Final thing was to lay down the fuel lines, got steel braided lines, Walboro external fuel pump 255LPH and Aeromotvie 6 Injected bypass regulator along with the gauge. The lines are not aid nicely but will get some clamps done later on, along with the changing the brake lines. Couldn't take proper pics so just some crappy phone pics. Will run the pipes along the chassis rails. such a mess with all the wires and pipes and the radiator hose needed to be changed as well. Will get the lines clamped to the floor rail on the right, not sure how safe it will be but don't want fuel lines inside the car fuel pump on the opposite side of the exhaust Got these fitting machine pressed Installed 1" brake cylinder works fine. There is some problem in handbrake cable, cant fit the stock ones in maxima callipers, I got this rear kit off ebay from Datsun Store or something, the callipers, brakes and rotors all are fitted nicely but cant seem to make the cable fit, would I need some other cable? please advise if anyone knows? I will sending the car for rest of electrical work might be some clean up and AC installation as well.
  9. Had some issues going on with the mechanic and project stopped for a while. I pushed him to just start the car and then will take the car somewhere else to do fuel lines and cleanup the mess he made with wires inside engine bay whole wiring is done and will start the car tonight I custom orderd full set of gauges which mechanic was supposed to hook up now but again like other things will get it done from somewhere else. It took around 8 weeks to get these done from Autometer, these are Ultralite II series, same like Ultralite but these are LED version, in the morning its sliverish white face and in the night all black with white LED lettering and red pointer. I got Speedo, Tachmeter in 5 inch size (stock is around 4inch) and then three big meters Oil pressure, Oil temp and Water Temp and last three smaller to go in place of audio head unit voltmeter, wideband A/F Ratio and Fuel level. Lightning is something like this and I loved it, took these pics off google from some Chevy Built Same setup comparison Night Close up Light closed Daylight with lights open Light on in dark For Boost there is no meter will just use HKS EVO Boost controller for both reading and adjustments Any head start suggestions for hooking up these gauges I might need?
  10. Sorry man still couldnt get the code as someone else was asking as well, as I bought paint from another city dupont main office, so hardly got time to visit there.But you can get it by name its Grigio Estoque, some google results below and code says 0115. Manufacturer: Lamborghini Colour/Year: GRIGIO ESTOQUE(2009/9999) OEM Colour Code: *0115 Got it from Z store
  11. Awesome thread just read all the posts and your attention to detail is amazing
  12. I love these (WORK) wheels, For flush fitment I was recommended 15 X 8.5 -9 15 x 9.5 -24 Rear on the Left and front on the right Rear with center cap Measured the lip for rear came around 6.9" Side by side
  13. Had time on Thursday to get the wheels installed on the car with tires to find all rubbing or any other issues. Rear ones came out a bit more stretched then front. Rear on the Left and front on the right Rear with center cap Measured the lip for rear came around 6.9" Side by side Got these Kics R40 Neochrome long open end lugs Test fitment, Front looks perfect except the rear problem, might go with 3mm/5mm spacer or trim the bumper steer spacer Rear ones, car is still on the jack at the rear for camber arms fitting, but placement is ok and poke is slightly more, might come out a bit from fender flares. Front brakes and rear brake are done and so was the brake lining, will be installing 1"brake booster. Only problem in the rear was to attached the ebrake/handbrake the clip pattern is different so trying to find a way around it. Front camber arms and TC control rods installed Installed my 19" Row Sterab oil cooler bought from GTM, have to work on some clean brackets.
  14. Got my tires from US Bridgestone RE11, proven to give very nice grip over other tires. I had very limited options when buying tires either these, Yokohama Sdrive or Toyo R1R/R888 so went with these. Size went for 195 50 15 for the front 8.5" wheel and 205 50 15 for rear 9.5" wheel Just managed to install the front ones yesterday Stretch is there but not that much was expecting more
  15. I will check the stamp but im quiet sure its Toyota calipers which one to be exact will find out. So does that mean I wouldnt be able to fix the drilled rotor at all in the caliper which is for stock rotors? The rotor is fitting nicely, its just pads are a bit thick. Please let me know if you can find the part number Thanks As I said up there will check it today once goto the workshop I will check first for the spacers else will trim the bumpsteer. Another question for you guys is, does all the Japanese 15" and 16" wheels have similar issue of center bolt coming out of the wheel. And anyone has any idea where can I get spacers as centerbore size looks really big then standrar 66.1mm or 72mm
  16. Lots of work in progress and then problem coming as well Fitting of stock parts, fitted windscreen, lights, few weatherstrip and all locks Took the car for basic wiring run, lights are ON After wiring done taking the car for engine start, IC and brakes and fuel lines etc As the front brakes are from Toyota with vented rotors, but there is a problem coming, cant fit both the pads, looks like need to shim them a bit, TC and camber arms are installed Test fitted the wheels as well, as sold my previous wheels, problem there again. Wheels are not clearing rear suspension parts, even coilovers are close as well. I think bumpsteer has pushed things a bit down Even the wheel hub seems to be interfering, but one thing for sure wheels are drooling Will check again tomorrow after installing the tires. Most probably need spacers but still trying to find solutions and size recommendation as hub is different here compared to normal cars
  17. I have gone through the FAQ and pinned lists but somehow a bit lost. Please bear with me as we dont get these here easily so I got the stuff shipped from US so when problem comes it seems a bit more. I got this front brake kit of ebay and thought its stage4 from silvermine motors? Now I have following issue, 1. cant fix the brakes pads, even after fitting one pad wheel is stuck? I am thinking of cutting 1mm off both the pads it might fit. One thing I think is the calipers are not for vented rotors? 2. Is the spacer placed right? 3. I have 15 X 8.5 -9mm and seems to be clearing the caliper hardly but doesnt look like fitting the hub properly. The hig core of the wheels is standard 72 or 72.5mm? The wheel is touching the suspension parts as well . Can anyone guide me if there are any specific spacers for sale which clear the whole hub as shape of hub is different Thanks Pictures Cant fit pads, Which calipers are these which clear vented rotors or which doesnt Is spacer placement ok? Back clearance Hub through the wheels seems like wheel is not inline with the hub cant push more
  18. I got some parts for the Z will post details they time they are ready for installation. As of now car has been sanded and polished and fitting of the parts has started. Took it on a recovery truck for a quick wash inside out. Engine looks clean now Even clearcoated underside of the hood Finish is flawless. I got cusco front and rear struts and motorsports sway bars along with some exciting stuff from Techno Toy Tuning. I always felt the lack of camber and caster setting and a weaker stock suspension so got myself these from them, only down point is their parts are a bit heavy but im not that much bothered about weight saving. Rear lower control arms, will allows to adjust toe and camber, and can also move the tire within fender wall about 1/2"and can widen the rear track by 1" Front lower control arms, again widen and shortening along with camber and toe setting, have two setting for sway bars and in total very touch compared to stock ones, come with new ball joints as well. Tension control rods, got these to adjust the caster as thats a priority, even after cutting the fenders wheels is touching on turning got new xenon headlights, side by side car wont be complete without CF, for the start got the rear tail light panel and a rear spoiler CF wrapped at Carbonsignal, result as always amazing
  19. I will check for the code, top of head I remember it was something like 01528 but will cross check. Guys I have to buy tires for my WORK wheels, any suggestions what's available as what I'm getting here in dubai is only kumho in specs of 195 55 15 and 205 50 15. I just want a thick wall and will prefer some stretch.
  20. Thanks man, I did realized that later on. will finalize the drill once paint job is done. You will see that in the formula of the paint, I just changed the silver part rest is all same
