RTz
Administrators
    23
Everything posted by RTz
  1. Could be used as anti-squat? Got it, and I agree. I had assumed your were referring to spherical bearing's. I don't believe there would be any binding with spherical's. Subtle use of toe changes are often desirable. I probably would'nt go far out of my way to have dynamic toe, but I'm not opposed to it if 'comes with the package' and the curve is reasonable. It does say something to that effect, but its related to bushing orientation/durometer, which wouldn't be applicable here. I'm 'arguing' simply becuase I see it as a reasonable alternative and based on similar packaging. Unfortunately, I'm not conviced of the strut side load's being a factor that can be reasoanbly reduced with control arm design, but its outside my ability to either argue or prove. Am I bugging you yet?
  2. No effort to control strut side loading. I'm game, lets talk. If all points where replaced with spherical's, what binding would there be?
  3. Just 'cause I enjoy playing devils advocate from time to time ... These are of the rear suspension in my wife's Subaru sedan. Two lateral links and one longitudinal, completely independent of each other.
  4. Jon, I'm thinking the side loading is caused by the difference between the wheel CL and strut CL. The location of the pick-up point is going to have relativly little effect, I think
  5. Here's a picture of my LT1 powered Z, also with a T56, mounted in the standard JTR position... Its a modified Datsun shift lever, oriented so the offset positions the knob rearward. While its not etched in stone, its looking like the trans will be another 3" farther back. Flipping the shift lever around, I should end up with a knob an inch or two father back than the above picture, which I would welcome.
  6. That makes two of us, my friend. I read your arguments as constructive and I'm hoping that you're doing the same with mine. I think there's value in understanding loads and load paths so this discussion interests me. If I prove to be wrong, so be it. I will walk away with a better understanding. Nope, sorry to give that impression. Getting closer. I thought presenting the case from a lateral perspective would have been easier, but thats not proving true. Allow me to start over from a vertical perspective, from the point of severe bottoming out. To exaggerate, put 20,000 lbs of weight on top of the engine (stock mounted). The suspension will be on its stops and the four vertical bolts through the crossmember will try to tear out (vertically). The lower rail is seeing a lot of focused stress (in tension), but its being held to great degree by the upper rail due to the strut tower. A fairly robust load path. On the other hand, assume the engine is mounted to the lower rail, roughly in the middle. Again, putting the same 20K lbs of weight on the engine. The suspension is still bottomed, but now the lower rail is bowed downward because the only thing attaching it to the upper rail is the inner fender and its not efficiently built for that load. Also, there is no longer ANY stress on the 4 crossmember bolts. In fact, you could remove them and move the crossmember up and down by hand. The load path changed. In both cases the amount of stress is the same, but its re oriented. The loads on the rail changed from tension to compressive and the loads on the crossmember are removed entirely. In retrospect, laterally speaking, its more complex, but still has the same 'issue'... a re-arranged load path. If any of that makes sense, and you agree, I'll take another stab at the lateral scenario.
  7. Another possible way to look at it... Because there is a direct link from the contact patch to the crossmember, when you turn the wheel the crossmember (carrying the engine) moves laterally. The only reason the chassis follows is because of the four crossmember bolts, and to a lesser degree, the TC rods and upper strut mount.
  8. The starter relay, in this case, is integral/synonymous with the starter solenoid. A generic Radio Shack part isn't interchangeable
  9. RTz
    good or bad
    http://forums.hybridz.org/showthread.php?t=123968&highlight=sds
  10. Hi John, I'm not trying to say the loads disappear... just trying to say they get re-arranged. With a crossmember mounted engine, in a lateral load, the load goes from the contact patch, through the spindle, strut housing, BJ, LCA, and into the crossmember, which is directly connected to the engine. The lower frame rail sees no direct lateral loading. Yes, a 'small' amount is feed into the TC bucket via the TC rod, and a smaller amount yet throughout he trans mount. Its dispersed. Obviously, there is a direct load going through the upper spring perch and into the upper rail which shares the load with lower frame rail via the strut tower itself and the inner apron. Again, I see the loads being dispersed, and having no direct impact to the lower rail, except that of being pulled down. Edit: My only point is that frame mounting will produce highly focused loads on the rail (instead of the crossmeber), whereas crossmember mounting disperses the loads over a broad area of the unibody
  11. When the engine is mounted to the frame rails, the frame now sees a localized load point in every direction (lateral, vertical, longitudinal). When crossmember mounted, there are no lateral loads (from the engine) and the remaining loads are dispersed broadly through the upper and lower frame rails and inner fender liners. Additionally, moving the mount 'pedestal's' back 5.5" isn't close enough to the TC bucket area to have any relevance, or so it seems to me. Of lesser importance, an unnamed member has done some compliance testing of the bucket area, and has found, with 'normal' lateral chassis loading, there is quite a bit of flex in the TC bucket. While it may be the strongest part of the front frame rails, it still flex's more than I'd like to see. I'm aware that a number of our members have done 'frame mounts'. Its simply my preference to avoid it if its reasonable.
  12. I ordered... http://www.speedwaymotors.com/p/6725,405_1955-1994-Small-Block-Chevy-Engine-Mount.html?itemNo=chevy%20mounts At only $50.00, its not much of a gamble... we'll see how she fits up
  13. I would prefer to mount the engine to the crossmember. The load paths of frame mounting don't really excite me.
  14. Now I hadn't thought of a front mount. Hmmm... gotta look into that. This one is catching my eye... ... looks to be stout enough longitudinally as well. Thanks!
  15. I hear ya Grumpy... makes sense. Here is part of my concern... If the brackets are completely ridgid, there should not be any rotational forces on the crossmember. But, if the offset brackets were allowed to flex, that would putting a twisting load on the crossmeber, yes?
  16. Hows this for BFH? Thanks for the offer Hugh. I'd hate to see you spend all day on something like this. I'd probably settle for sound advice, for or against 3/8" plate.
  17. Summary... If I wanted to offset the standard JTR mounts an additional 2" rearward, what is the necessary material thickness to achieve equivalent rigidity? Why... Today's EMS's commonly allow us to delete the distributor, which is the principal physical limiting factor with respect to engine location. Deletion allows a more reward location of the drive-train. Nitty Gritty... The JTR brackets offset the drivetrain rearward 3.5". If I wanted to increase that to 5.5", 57% increase center-center, I would need to increase the bracket thickness from .3125" to ??? Knowing that any material, doubled in thickness, results in 8x rigidity (increases with the cube, correct?), increasing the thickness to .375" should more than cover it with a 73% gain in stiffness... 20% greater thickness = 1.2^3 = 1.728. Am I looking at this right? Considering lateral and vertical loads, does it matter that they are mounted on a 45 degree, or is that 'no factor' in this scenario?
  18. Comments like that serve no constructive purpose whatsoever. Please feel free to keep those thoughts to yourself.
