gearheadstik
Everything posted by gearheadstik
  1. From the album: Gearheadstik 280z
    Threw in the blast cab...you can see where all needs to be ported for boost creep upgrade....
  2. From the album: Gearheadstik 280z
    Took apart to powdercoats
  3. gearheadstik
    1978 280z
    Enkei rs-6 with wheel spacers installed with 240sx brakes installed
  4. From the album: Gearheadstik 280z
    wheel spacers for enkei rs6 and toyota brakes
  5. gearheadstik
    1978 280z
    coilover and bushing install + cleanup
  6. gearheadstik
    1978 280z
  7. From the album: Gearheadstik 280z
    Scanned pics of when I started working on my parents old 280z
  8. gearheadstik
    280z
    1978 280z back when it was new...It was bought new by my parents...
  9. Wow 200....I could use another for that..haha...Let me know if you start selling some...
  10. I bought my hy35w on ebay for just under 400...New
  11. I had the same ones on my 78 280z...orig silver but over the years it seems the paint oxidized its way off to leave the off white colored plastic...this is a pic back in the day...kinda hard to tell the color
  12. So if my cars tracking to one side under power...how would you think you could correct this?? Maybe stiffer spring on that side...or use adjustable coilovers to jack one side higher than the other...Open to ideas, thanks
  13. Has anyone heard of using a anti-roll on a stock r200 type diff ??? Not a sway bar but the type of anti-roll bar kit that makes it possible for you to preload the chassis, eliminating body roll during hard launches. This allows the car to drive straighter off the starting line, helping to improve 60 ft. times.... searched but didn't see anything...would it work or is there a better idea besides going to a different rear setup...thanks
  14. Some of the z's have a rubber or plastic stopper that goes in the pedal assy that pushes the switch on and off.. Mine had fell to apart...i glued a penny in its place...please let us know what you figure out..
  15. This is one of the spacers i ordered for my 280. I was happy with the workmanship, but didn't come with any lug nuts to bolt to the hub with...this was not a problem for the rear being 30mm...they were thick enough to use a 16mm high tapered lug nut...the fronts were a 20mm and needed to be 2mm or more shorter. I looked and looked for something to work but ended up machining down a few 16mm to fit...The place I ordered them from was kinda slow to help me, they claimed they had nuts that would work but after a couple weeks of emailing between each other took action....I got these spacers because i thought it would help a wheel wobble i had, ended up being a bad tire...but it makes me feel better to have these than a cheap autozone floating spacer.
