280Z Turbo
Everything posted by 280Z Turbo
  1. Lately I've been spending less time there and more time here at HybridZ and at Z31performance.com (I started posting at Z31performance.com for my Z31 MAF swap and kept posting because of all the knowledgeable members). I get tired of the stupid fights and grumpy bastards at Zcar.com plus all the boring posts about fumes, running rich, passing emmisions, and all that crap. I'd rather talk ECUs, turbos, intercoolers, L28ETs, V8s, VGs, RBs, and cool stuff like that!
  2. First of all, what size piping should I have? 2" or 2.25"? I know 2" is better for response, but 2.25" would flow a larger volume. I am leaning towards 2" because it is easier to work with and because the TB and turbo are both 2". Here's what I have: 70's crash bumper removed for easy access. That pipe seems to be at a bad angle for me, but would a 90 degree coupler be okay? I'm not sure if that would even work, I may have no choice but to mod the end tanks. Where would I go to modify them, though? I don't know anything about welding aluminum so I couldn't do it. How could I make it work? The return pipe to the TB is coming from the passenger side. Notice the aluminum pipe on the end of the J-pipe...I need that 1" bung on there for my Saab recirculation valve. That presents another problem of where can I recirculate it to before the turbo Also going to need to do something about the stock POV (shim it?) and dump valve. How do I curve the return pipe around my radiator hose? Passenger side hole. Kind of a tight space...not sure about brackets yet or where to mount them. Will this be okay for an air cleaner position? It's a lot lower than before and I'll have to wrap the 3" pipe around the frame rail and up to the turbo. I think I may run the oil cooler on the opposite side, but the oil cooler hoses are stiff as hell and I have no way to mount anything. I may go with a custom one, but I can't find a nice small one like the stock 280ZX one. Also, I have been told that I could mount the oil cooler inside the engine bay, but it would reduce efficiency by about 20%. The Evo I/C itself. The fins on this thing are VERY fragile. Is there anyway to protect them?
  3. The Z31 TPS does the same thing as any other TPS, as far as I know. They're all just on/off switches. If you're looking for a potentiometer, use a 240SX TB.
  4. BTW, for those of you with 1981 ZXT motors who want to do the 300ZX MAF swap, check out my "supplement" to Afshin's thread. It really seemed to help wannaBREz with his swap and the guys at Z31performance.com seemed to approve of it. It was a lot of work and I went through and answered many questions that you guys have, so give it a read: http://forums.hybridz.org/showthread.php?t=114687
  5. Actually, I don't think it would be that bad. The Z31 harness would be the hardest part, but several people have used the Z31 harness with L28ETs just for the better connectors. The sensors are the same, assuming it's a 280ZX motor with an O2 sensor. If not, swapping in an O2 sensor from a later car probably wouldn't be hard. Also, while the 280ZXT distributor is needed, see my thread: http://forums.hybridz.org/showthread.php?t=114687 on how I used it WITHOUT changing the oil pump shaft to splined. It's easy and cheap to get the distributor to work. Besides, don't you need that for Megasquirt, anyway? Megasquirt is not cheap and not easy. IMO, a Z31 N/A swap would be much cheaper and easier than Megasquirt.
  6. I recently did the Z31 MAF swap on my 1976 280Z 2+2 with a 1981 280ZXT motor. Afshin’s write-up is on a 1983 harness, so I thought I would do a write-up on the 1981 harness and include a few other helpful hints for Hybrid Z'ers interested in the swap. Like Afshin, I also used a 1984 Turbo ECU, but there are other possibilities. For some information on which year ECU is best for your needs, check out redz31.com: http://www.redz31.com/pages/fuel.html I find it odd that the Z31 MAF swap isn’t more popular. The plugs on the 280ZXT harness fit in the 1984 ECU perfectly, you just need to add a couple pins. Why do this swap? Reliability, for one thing. I never got my 1981 ECCS to work right. It ran pig rich sometimes and ran dangerously lean at other times and I never knew why. I installed the 1984 ECCS and it’s been running great ever since and it always starts quickly. Even when it’s cold. You also get better performance. That silly flapper door AFM is a big restriction and a MAF will flow much better. People have picked up an estimated 15 peak horsepower at the wheels from this swap and say that the throttle response is much better. I can’t verify the estimates, but my car sure does run good now that I swapped it! It seems like everybody on the 1970-83 forum on Zcar.com uses Megasquirt. MS is cool, but it’s a helluva lot more complicated and expensive, IMO. I was told on Zcar.com recently that nobody uses the 300ZX ECCS because it is “untuneableâ€. Certainly not true. Visit www.Z31performance.com or www.redz31.com to dispel that myth. Supposedly, you should use the 300ZX harness instead of using the 280ZXT harness because the ECU connectors are more sealed off from moisture in the air and don't corrode so easily. A lot of people have problems with these. Using a Z31 harness would be a real pain, so just make sure that you clean the 280ZXT contacts every once in a while. Pulling them in and out a few times can help. The first thing you’re going to want to do is read Afshin’s write-up from HybridZ.org. I also have the same disclaimer as Afshin. I also have no formal training. If you fry your ECU, electrocute yourself, or blow your car up, it's your own damn fault. http://forums.hybridz.org/showthread.php?t=91250 --------------------------------- DISCLAIMER: First, electrical shorts can burn out your EFI and/or cause a car fire. I have no interest in anyone doing this and don’t know if it will work for you or not. I have no formal training and am only sharing what I did for myself. There is no guarantee nor should any inference whatsoever be made that anything posted below is correct or safe. PURCHASED PARTS: 1984 Z31 turbo ECU, MAF, any 84-89 300zx crank angle sensor/chopper wheel (the wheel has a top and bottom, do not reverse or car won’t idle properly) and MAF and ECU connectors with several inches of wire attached. Also need wiring diagrams of both cars. NOMENCLATURE: Mass air flow sensor = MAF Air flow meter = AFM Fuel pump relay = FPRz = from 280ZXT zx = from Z31 / 300 ZX Example: zx 30 y/b = # 30 wire/pin which is colored y/b (yellow with black line) on the 300 ZX system Also, I crimped every cut wire to connectors so I could plug and unplug all the changes. CONNECTING THE MAF: Cut the wires to the AFM a few inches back from the clip Take clip and wire from MAF then: 1) Connect MAF Position A/wire 30 y/g to 30 y/b wire from z harness 2) Connect MAF Position B/wire 31 b to 31 y/r wire from z harness 3) Connect MAF Position C/wire black to body ground 4) Connect MAF Position D/wire 26 b to 26 b wire from z harness 5) Connect MAF Position E/wire 27/35 b/w to any ignition activated + powered wire (pin 27 and 35 are + ignition wires on the same circuit, they are b/w (black with white strip) and can be tapped into from either b/w wire going to the 2 V.C.M solenoids that are located under the AFM bracket 6) Connect MAF Position F/wire 12 r/w (for cleaning cycle) to 33 y/l wire from z harness CONNECTING THE Z31 ECU TO THE Z HARNESS: There are a few of the ECU connector pins that are different. I got an ECU connector clip from the junkyard and then cut it open and took out three metal pins with several inches of wire to it so I could plug them into the empty connector slots of the z harness. 1) Insert new pin into slot 12 of ECU connector then cut wire 33 y/l before it goes into ECU connector and attach to new pin #12. So 12 pin from the Z31 ECU thru wire 33 y/l will be connected to the 12 r/w wire on the MAF (marked as F). Now the ECU will be able to go into auto clean mode and keep the MAF filament clean. 2) Insert new pin into slot 34 of ECU connector then connect it to a new wire going to the + coil terminal 3) Insert new pin into slot 3 of ECU connector then connect to a new wire going to the – terminal of your coil. The car seems to run OK without this step, but I still wired it since it was done on the 300zx. I have a MSD and the car is doing well with it. CONNECTING THE FPR TO THE Z31 ECU: This way if the car stalls out, the fuel pump should shut off as it’s supposed to. Now on the 280zx the FPR is always grounded and does not get turned on until the ECU thru pin 16 l/r (blue wire with red line) sends a + signal. On the 300zx it is reversed, the + is on whenever the ignition is on, and the ECU thru the fuel pump modulator sends the – signal to activate the FPR. Hence, I needed to rewire the + and – signal used to turn the FPR on. 1) Black wire (- source used to turn on relay) wire cut right before FPR, connect to new wire and take to pin 108 on the ECU connector 2) 16 l/r ( + source for turning on relay), wire cut right before the ECU connector end and connected to + ignition source (I tapped into the b/w wire going to my 280zxt fuel pump modulator which sits above the ECU). Now the ECU controls the – power that switches the FPR on thru the ECU pin 108, and the 16 l/r wire is ignition + to the FPR. Now I have no explanation for this part, but according to the book, pin 20 from the Z31 ecu should activate the FPR, which then loops back thru the FPR to pin 108. This did not work for me. However, it worked perfect when I connected the new wire going to pin 108. Again I don’t know why pin 108 is working for this and pin 20 did not, but it sure is working well on my car. Also I disconnected the knock sensor and did not switch any of the injector wire. Lastly, to run the air regulator, it was controlled thru pin 108 on the z set up (which control the FPR in the z31 set up) as opposed to pin 16 on the Z31 set up. So I connected the 16 pin/wire coming out of the ECU connector to the 108 z harness wire (black which goes to the air regulator) and now the Z31 ECU will control the air regulator from ECU pin 16 thru the 108 wire. (While ECU pin 108 now controls the FPR) I hope this helps others map out there own swaps (there are many ways to do this). It would be most useful if others who did this could add in their tips, cautions and related experience reguarding this swap such as Z31 maps/ chip burning, adaptations for 370cc injectors, data on actual HP/torque gain and timing/tuning for the set up….. ---------------------------- Okay, now that you've read Afshin's write-up, here's a few more things you're going to want to know. DISTRIBUTOR MODIFICATION: The 1981 ECCS used a magnetic CAS mounted near the crankshaft pulley. As far as I know, this cannot be made to work with 1984 ECCS. So, you need to use an 82-83 distributor with the CAS built in as well as the slotted degree disc from any Z31 distributor. Since I had an entire Z31 distributor, I used the CAS, bearing, degree disc, and some other hardware since it was in better condition than the one I had. The Z31 CAS is also said to be an upgrade from the 82-83 sensor. I’m not sure about that, but it looked a lot cleaner to me and it’s been working great. Just about everybody says that you MUST swap out the oil pump shaft in order to use a 1982-83 distributor. That’s not true, but I did have to have the 82-83 shaft and collar machined to make it work. The 1982-83 distributor has a splined shaft that holds it in place better than the stock slotted shaft which is too sloppy for the 1 degree resolution on the CAS. I had the 82-83 collar machined to the same inner diameter and overall length of the 1981 distributor collar, but I left the splines in on just the top part of the collar so that the collar would stay centered on the distributor shaft. I tried to use the 1981 collar, but it just flopped around too much on the pin and wouldn’t stay centered. If you look at the end of the oil pump shaft in the engine you’ll notice that the slot that fits into the distributor shaft is off center and one side is bigger than the other. The 1982-83 distributor shaft has a half-moon shape. This can be filed down (or milled, I suppose) until it fits perfectly on the larger side of the oil pump shaft. You should have little or no play in the distributor shaft if you did it right. WannaBREz's "half-moon", on the other hand, needed no filing to fit nice. I guess the tolerance was not very precise. Here's some pics of the assembled distributor: Strip out all the guts and swap out bearing if necessary. That pedestal that you see there is pressure fit in there really good! A small vice grips is your friend here! Just grab on to it really good and pull up. You may need to use a vice grips for the old screws too. The shaft and bearing goes in first, then the CAS, then the pedestal, and then there's a thin black spacer, then there is another washer with tabs on it that holds the degree wheel. Remember there is a top and bottom to the degree wheel. Don't mix them up! After you have the Z31 degree wheel on, put the top pedestal thing on and replace the screw. The rotor mounts to this top piece and it's good to go! Here's the modified collar. As you can see the splines were bored out to match the 1981 oil pump shaft on the motor. The collar was also shortened to the same length as the 1981 collar. You only need the splines at the top to keep it centered. DROPPING RESISTOR PACK MODIFICATION: For some reason, the 1981s used a resistor pack on the driver’s side of the engine bay. 1982-83 280ZXTs don’t need this and neither does the 1984 ECCS. To bypass them, I simply cut off the resistors and twisted the remaining wire together. You could just slip some universal connectors into the slots of the male end of the stock plug, but I wanted to take advantage of the female connector that secures the connectors in place. This distributes the positive voltage to all 6 injectors (the ECU controls them through the ground). Make sure that you properly insulate and solder the connection! NOTE: 1988-89 ECUs will require the use of dropping resistors as they were designed for high impedence injectors. I’m not sure if the stock 1981 resistor pack could be used with this ECU, but you will need something to protect the ZXT's low impedence injectors. CLEANING CYCLE FOR MAF: This was originally automatically controlled by the speed sensor on the Z31 and since 76s didn’t have that, I needed to find a manual way to control it. Ignore the part in Afshin's write-up about connecting MAF terminal F to the ECU if, like me, you don't have a speed sensor. I just used a push button ignition switch. I removed the bracket for the hood release and drilled a hole. It was the best place I could think of that didn't require making a hole in the dash or console. I have heard that you just hold the button down for 1-5 seconds and release to clean the filament. You don’t want to burn up the filament, so be careful! This is where I mounted mine. It's convienent and out of the way. OTHER NOTES: If you run an electric fan, I would recommend using a sheilded wire for your MAF signal wire. The electric fan can interfere with the MAF signal. I have heard of people running rich just because the fan is running: http://www.redz31.com/forum/viewtopic.php?t=327 I used a wire that I had on another harness that was for the knock sensor. It had 2 wires on it so I used the black one for the MAF signal wire and the red one I used for the cleaning cycle. The cleaning cycle wire doesn't need to be shielded, but since I had that wire there anyway, I took advantage of it. Notice that the wire shielding is grounded to the body. Do this on both ends of the wire. For the fuel pump, don't move pin 16 to pin 20. I did that and got almost no voltage. Not sure why, but Afshin had the same issue. Use any switched power source to energize the coil in the relay and then run it back to ground through pin 108 (which is used for an air regulator on the 280ZXT harness, I think) The relay has "NO" (normally open), "COMM" (???), and 2 "COIL" (for the signal, not the actual power) prongs. The fuel pump is connected to "NO" Fuel pump power source goes to "COMM" One "COIL" prong is connected to pin 108 The remaining "COIL" prong is connected to that switched power source. TOTAL COST: 1984 300ZX Turbo ECU w/ manual trans: $55 shipped 300ZX MAF w/ MAF harness: $35 1982 280ZX Turbo distributor: $46 shipped Z31 distributor: freebie Machining of distributor collar: freebie Connectors & switch: a couple bucks, probably About $140 invested and it runs SO much better. That's a lot of bang for the buck!
  7. My dad and I just finished up the cat back, mandrel bent Flowmaster 3" exhaust on my dad's '98 3.9L V6 Dakota. He had to replace it because the old muffler was some piece of crap Autozone special was rattling apart. In addition, the old system was all bent to hell because the muffler was banging up against the driveshaft and the pipe was bent out of the way. It was a real mess! Since I love the 3" exhaust on my Turbo 280Z, I somehow convinced him to go 3" on the Dakota. The system was actually meant for the 318 and 360 V8 motors, but it fit just fine. It came with a sturdy Flowmaster welded muffler, mandrel bent 3" pipe after that, and a nice polished stainless steel rolled tip to go with it. I wanted that for my Z! Not a bad deal for just under $200. My butt dyno says he picked up 20 hp from that alone! It's a little bit louder under acceleration and it has a hollow sound to it, but it sounds nice. Reminds me of one of those baja trucks they run out in the desert. Luckily, it's nice and silent while cruising. I couldn't believe how much quicker it would wind out to the 4700 rpm redline. I'm sure his gas mileage will get noticeably better too. It's probably more exhaust than what this thing needs, but I love it!
  8. I just went to U-Wrench-It after work to check it out. It's a gold '86 N/A coupe, so it's pretty much useless for me. A few things that could help in the swap would be the distributor, possibly the MAF sensor (I think the turbo and N/A MAFs are the same, aren't they???), and the engine wiring harness. But you can't use the ECU. I haven't heard of a Z31 trans being used in an S30, but I'm sure it could be done. I just don't think it would be worth all the work.
  9. Nope the 84-85 ECUs and the 88-89 N/A ECUs used the same 22 mm O2 sensor. Read Afshin's sticky in the Turbo forum: http://forums.hybridz.org/showthread.php?t=91250
  10. The Turbo vs. Nitrous argument was stupid. A turbo is a permanent engine part with a never ending supply of boost. Nitrous is only used when racing and the car does not normally run that way.
  11. I keep messing with the fuel pump relay, but I can't seem to get the fuel pump to run in "on". The + signal wire is in pin 20 of the ECU and runs to a terminal marked "COIL" on the relay. The - signal wire also runs to a "COIL" termial and is connected to pin 108. The fuel pump power wire is connected to "NO" and the power wire to the battery is connected to "COMM". I get a small amount of voltage (.62 volts) through the + signal wire and the - signal wire seems to be grounded somehow. I hotwired the pump by touching the battery and fuel pump power wires together and the pump ran fine. How do I get the pump to run in "ON"?I keep messing with the fuel pump relay, but I can't seem to get the fuel pump to run in "on". The + signal wire is in pin 20 of the ECU and runs to a terminal marked "COIL" on the relay. The - signal wire also runs to a "COIL" termial and is connected to pin 108. The fuel pump power wire is connected to "NO" and the power wire to the battery is connected to "COMM". I get a small amount of voltage (.62 volts) through the + signal wire and the - signal wire seems to be grounded somehow. I hotwired the pump by touching the battery and fuel pump power wires together and the pump ran fine. How do I get the pump to run in "ON"? I just tried pin 16 for my + signal, but still, there was no response from the fuel pump.
  12. I have some Kenwood 6 1/2s that I want to put in my Z as well as some 2+2 side panels that I got from the junkyard that already have cutouts for that. The only thing is, I'm not real crazy about cutting sheet metal for speakers, but this is the best/neatest place to install them. I'm wondering if installing the speakers will affect the chasis at all. Would I be making holes in an important structural area? I'm not going to build a speaker box in the backseat area, so don't bother suggesting that. Here are some pics of the proposed speaker holes:
  13. How EXACTLY do you bypass them? As in, what wires go in what terminals on the plug? I asked on Zcar.com, but by the time people figured out that I was right in saying that the 81s have resistors and the 84s don't it was already at the bottom of the page. I HATE that about Zcar.com. Threads disappear before they've run their course. Anyway, the only answers I got were just to run jumper wires. That doesn't tell me much. Where do they go and how does it work?
  14. Aaron, you've gotta do that Z31 MAF swap! You're lucky that your car even runs! I went over to Jason's house tonight to pick up a MAF and ECU from him. It doesn't sound too hard.
  15. I just had to tin snip the line really short, unscrew the block from the engine block, put the block in a vice and I used a vice grips to turn it.
  16. I can't seem to get this thing off of the block that is screwed into the engine. I just keep rounding the nut off. Right now, the day that my car gets out depends on when MSA gets the oil supply line to me, so my car may still be out of commision for much longer than I want. It was stupid...you should never use MSA when time matters!
  17. Thanks guys. I'm still a bit nervous about this after reading crank damper horror stories all over the place, but for now I'll bolt it back up and watch it carefully. I'll probably wait and buy an '82 dizzy and a Euro damper when it comes out again.
  18. A thread over at Zcar.com got me thinking about my crank pulley. It's a rather complicated problem... I recently took it off and noticed that it had some tiny cracks in the rubber, although I've noticed no chunking off or anything of that nature. When I put it back on, I plan to Loctite it, which would make it hard to get off again. I don't typically wind the thing out, but I know that a good damper is important on an L6. I don't want to get a new pulley from Nissan because it's $150 and still has 2 pulleys that I don't need/want and won't fix my clearance problem with my $80 16" electric fan. I have considered chopping the damper (see my previous post), but from everything I've read, modifying a crank damper is a no-no. What makes this even more complicated is that the 81 needs that silly magnetic wheel on the back of the damper for the ECCS to work properly. I could remedy this by getting the 82-83 photoelectric dizzy, but that's even more money dumped into it. Although, I have been considering a Z31 MAF swap anyway. The Euro damper would have worked great with a new dizzy, but Nissan stopped making it. I recently acquired over $1000 at my graduation open house, but I don't really want to spend that much of it on my Z. Well, I do, but I know better. Although, I will be working this summer. Also factor in that I haven't driven my car since October and I'm very tired of waiting. I'm not really sure what I should do.
  19. Nope the 81 turbo crank pulley is kinda dumb that way. The A/C and P/S pulleys ARE the damper and the alternator/water pump pulley is mounted behind. I don't really want to buy a brand new 81 pulley and chop it up. It seems to me that there are better options out there at that price.
  20. I'm looking at buying a new water-cooled center section from Turbo City but I'm not sure that they include the 6 bolt flange that attaches to the exhaust housing. That plate was invariably wrecked by the shop I brought my old turbo to, so I was wondering where I could get a new one to replace it. Is it possible to just buy hardware for the turbo?
  21. I won't run one of those Euro dampers because they are prone to failure and they don't have provisions for a 1981 CAS. What I mean is that the shroud isn't as flat as others I have seen. If it was flatter, there wouldn't be a problem. I already paid $80 for the fan, so I'm not going to just ditch it. It's one from Summit:
  22. How could I move it forward?! It's flush up against the crossmember. It's 4" thick. It's not the thickness of the fan that's the issue, it's the poor design of the shroud. It's tapered to the back of the motor.
  23. I recently got an electric fan, but I didn't have very much clearance between the P/S pulley and the shroud. I want to remove the P/S pulley, but on the 1981 turbo, the P/S pulley and A/C pulley together make up the damper itself. Could I shave off the P/S pulley or would that comprimise the damping ability of the damper too much?
  24. I have a 1976 280Z/1981 280ZXT hybrid, so maybe I can help a little bit. That trans will bolt up just fine and the ECU will work fine too. I have a 1978 5 speed and 1981 ZXT Auto ECU on my car. The only difference I notice with the Auto ECU is that the revs stay up a little longer between shifts which is actually nice because it makes it smoother. You probably will need to use a different driveshaft and you may have to swap the differential flange (which is a PITA). I've never done an auto to manual swap, so I can't tell you much more.
  25. I have an '81 L28et and I was wondering if it matters which wire goes on each side of the plug. I think that the red wire goes on the right side, but I can't remember.
