340ZXTTAZ
Everything posted by 340ZXTTAZ
  1. Interested if it's the CAS dizzy and it works. Cap and rotor is no big deal. What do you want for it? 85044 is the zip for shipping.
  2. Like the tiltle says. I'm looking for the 280zx turbo distributor with the dizzy cas for use in a jim wolf 450HP upgrade. Thanks
  3. There are some tubes that actually reduce with a smaller 90 deg. tube off of the main tube. u could use that, those tubes are only pressed into the block.
  4. Well if the engine is out or if you have access to the block. You can buy a weldable fitting to it and reduce it that way. Plus it will look trick and function really well.
  5. Here are some soild lifters I removed from an E88 head to transplant into my P90A head and ones that were received in a purchase of converted P90A head. After cleaning both sets I noticed that some of the pivot ends were diffrently shaped. So my questions are were there diffrent types/ styles pivots. If no, and the answer is excessive wear, then what are the ill affects of a badly worn pivot besides binding. http://s495.photobucket.com/albums/rr318/340zxttaz/?albumview=grid&fullsize=Zlifters001.jpg http://s495.photobucket.com/albums/rr318/340zxttaz/?albumview=grid&fullsize=Zlifters002.jpg http://s495.photobucket.com/albums/rr318/340zxttaz/?albumview=grid&fullsize=Zlifters003.jpg http://s495.photobucket.com/albums/rr318/340zxttaz/?albumview=grid&fullsize=Zlifters004.jpg
  6. Does anyone know the Time-sert part # for converting to solid lifters on a P90A head. I know the solid lifter outside diameter is an M18 x 1.5mm threads what is the outer diameter of the hydraulic lifter M20 x 1.5 mm? I got a part # of 18175 from a distributor for time-sert. Don't know if thats the right treads.
  7. Chanllenger I still working on getting the runner material but plan on starting pretty soon.
  8. Justin whats the name of the machinist that made the parts? I was talking to some local z guys and they mentioned about a z fan that was also a machinist that moved to Oregon not too long ago. It would be cool if it was the same guy.
  9. Yes, yes it did! The parts look great! Can't wait to see how they perform for me. Thanks for checking in.
  10. Hey Justin, That shipping # doesn't come up at the DHL website. Would you please check that # and repost is it is wrong. Thanks. Why did you decide to send it DHL instead of UPS?
  11. Still waiting for a reply at least. Can everyone that has received their parts please chime in just curious. I'm done waiting.
  12. Yeah I read that in my MSD manual but it didn't think it would work the same for the Crane unit. Glad you got it figured out.
  13. Well Justin? How mant people have received their parts already? Just curious as it has been literally a year now for me. I guess you can say I'm getting a little impatient.
  14. now the stock coil wires were disconnected right other wise everything is right in the wiring. if you left the coil wires connected you could of blown the IC module and would need a new one or new distributor. Did you check the distributor per the FSM? If it still not working did you contact Crane.
  15. Justin when can i expect those parts?
  16. If it's anything like the MSD it's the pick ups are just making and breaking contact. That signal is used to fire the coil. if you were to do it manually (touch and break the Crane pick up wires) does the coil fire or the light flicker. It's possible that maybe some thing is shorting through the distributor? Edit: I guess I should ask which distibutor type you have? The standard magnetic pick-up or the one with the IC module? If it's the one with the IC module then the above statements will not apply. If you are using the IC dist. I know there are seperate wires to use than the pick-up ones. It's possible that the module whent bad or the crane unit did. Check the distributor like in the manual and if it's fine call Crane.
  17. I sent you the Shipping address in a PM. Please get those shipped out ASAP. Thanks.
  18. Well Miami I've made it down to Mia. and will be here thru the 13th of May. I was hoping you could give me the low down on a couple of hang outs and dates for this week.
  19. Wait how did you get it already? Justin are these things ready to go? If so let me know what my balance is with shipping to 85044. Thanks for all the work you've put in.
