Akira
  • Gender
    Male
  • Location
    Los Angeles, CA
Recent Profile Visitors
Akira's Achievements
Newbie
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
0
  1. check his Facebook album: https://www.facebook.com/pg/hokeperformance/photos/?tab=album&album_id=855705011215074
  2. Impulse buy. Just ordered a pair of the 74-76 door cards.
  3. Hello - Someone out there must have an unused clock that they took out for an aftermarket gauge. Looking for a 240z, 260z, or 280z clock for parts. Don't want to spend a fortune. What I'm really looking for is the black metal retaining ring that sits between the front bezel and and clock face. Thanks!
  4. Unable to PM you, says you're unable to receive messages for some reason. I have the Maxima calipers, brackets, rotors, lines, and hawk pads. I'll let it go for $300. I was going to use them, but I need something bigger for my LS setup. I'm local if you're still in Burbank.
  5. http://www.4moores.com/280z/files/JCI%20Install%20Update%202.pdf http://forums.hybridz.org/topic/48731-jci-ls1-mounts-need-help/ http://forums.hybridz.org/topic/81313-jci-mount-pics-bolt-question/ https://slownrusty.wordpress.com/category/engine/
  6. The threaded bolt at the rear is a coolant drain plug.
  7. This link should answer your question http://forums.hybridz.org/topic/73972-megasquirt-ii-on-l28et-need-some-help/ If you're not using the stock ignitor or a GM HEI module to fire your coil, then you'll need to solder in the BIP373. Make sure JS10 is going to IGBTIN.
  8. Scratching my head, just trying to help. I provided one link earlier, which is this one http://www.chequeredflagracing.net/Datsun.html, if you scroll down to the bottom of the page, you'll the see companion flanges listed.
  9. Billet Z31 CV/Companion Flange Adaptors! Pair of billet 4340 precision CNC machined steel CV/Companion flange adaptors, heat treated, cryogenically treated, and double tempered! $ 440.00 27 spline $490.00 39 spilne
