Z-Noob
Everything posted by Z-Noob
I'm picking up the car from the media blaster Monday. The blaster called me Monday to tell me it was the cleanest z he had ever seen. No rust or cancer 100% solid! So the frame rails should be good to go for the bd frame rails. Thanks
Thank you, thats what Ill do.
First and foremost I have searched! Are the Bad Dog Frame Rails for a 240z supposed to be welded OVER the old frame rails? I have seen people remove the old ones and weld over the old ones. Their webiste does not specify for the 240z, but does for the 280z. THANKS ALOT!!
You might want to look more into soda blasting. When something is soda blasted it is left with a coating that many times cannot be primered or painted over. Whatever is soda blasted has to have a neutralizer wash prior to applying coatings. As far as $250 for media blasting, that is SUPER CHEAP. Make sure they are using a media that will not damage/warp your panels. Also make sure the technician doing the work is skilled.
What is under the boost controller? Wideband?
I left mine on for about 20 minutes. The longer the better. When the cold penetrates through the deadening matierial it spreads through the rest of the metal, which makes it easier to bust up surrounding areas that did not actually have the ice on it. Also get some strong trash bags and make a saddle told hold the ice on the trans tunnel. Have fun.
the start of the B.customs Z has begun..2jz 1000hp
Z-Noob replied to Overkill Z's topic in Toyota L6 Forum
Yeah, it is expensive. I would guess that if you do hit 1k HP (reliably) , you are probably doing it for as cheap as you can do it, besides doing all the work/tuning yourself. -
HP=$$, Are you surprised? -
I am almost 100% those are Audi B5 S4 seats.
No cheap out and end there...Of course have them do a tune:shock: -
Im going to need an auto rotisserie in a couple weeks, so if you have one for sale lmk. I know I can build one fairly easily but if I could buy one that would save me some time. Thanks
Vehicle History Report™ Vehicle Highlights™ Safety & Reliability Ratings™ Buyback Guarantee™ Certificate Consumer Ratings & Comments™ For Personal Use Only Print This Page • Print All Pages Loading... For Personal Use Only Rebuilt/Reconstructed Title A Rebuilt/Reconstructed vehicle is a salvage vehicle that has been repaired and restored to operation. These vehicles are often severely damaged before they are rebuilt and refurbished parts are typically used during reconstruction. In most states, an inspection of the vehicle is required before the vehicle is allowed to return to the road. Manufacturer Buyback or Lemon A DMV or a state agency marks an official document or issues a Manufacturer Buyback/Lemon title when a vehicle has been repurchased by the manufacturer. Not all states issue manufacturer buyback titles and the specific requirements for a lemon law vehicle varies by state. Odometer Rollback If a more recent odometer reading is less than an older reading, then the odometer may have been tampered with and "rolled back". Manufacturer Recall Automobile manufacturers issue recall notices to inform owners of car defects that have come to the manufacturer's attention. Recalls also suggest improvements that can be made to improve the safety of a particular vehicle. Most manufacturer recalls can be repaired at no cost to you. Basic Warranty Most manufacturers offer a basic warranty for new vehicles. These warranties vary by manufacturer and typically last for a certain amount of time and/or a set number of miles. Not Actual Mileage Title When the seller certifies, under the Federal Odometer Act, that the odometer reading does not reflect the vehicle's actual mileage. This may occur because the odometer was tampered with, broken, or replaced. Junk Title A Junk Title is issued on a vehicle damaged to the extent that the cost of repairing the vehicle exceeds ~ 75% of its pre-damage value. This damage threshold may vary by state. The majority of states use this title to indicate that a vehicle is not road worthy and cannot be titled again. Some states treat Junk titles the same as Salvage. Loss Due To Fire Title The vehicle sustained major damage due to fire. In most states, fire damage titles are issued when the cost of repairing the vehicle for safe operation exceeds its fair market value. Exceeds Mechanical Limits A vehicle with a 5-digit odometer cannot accurately track mileage after 99,999 miles because the odometer rolls over. This title is the result of a seller certifying under the Federal Odometer Act, that the odometer reading EXCEEDS MECHANICAL LIMITS of the odometer. Structural / Frame Damage In most cases, a vehicle is inspected for structural or frame damage, depending on the body design, after an accident or other incident. All levels of accidents from minor to severe can cause structural / frame damage and in most cases it can be repaired. Airbag Deployment Occurs when the driver, passenger or side airbag has been used or deployed during a crash or other incident. If an airbag has been deployed, it must be replaced by a qualified technician. Have this car inspected by a mechanic prior to purchase. Salvage Title A Salvage Title is issued on a vehicle damaged to the extent that the cost of repairing the vehicle exceeds ~ 75% of its pre-damage value. This damage threshold may vary by state. Some states treat Junk titles the same as Salvage but the majority use this title to indicate that a vehicle is not road worthy and cannot be titled again in that state. The following eleven States also use Salvage titles to identify stolen vehicles - AZ, FL, GA, IL, MD, MN, NJ, NM, NY, OK and OR. Total Loss An insurance or fleet company declares a vehicle a total loss when a claim exceeds ~ 75% of its pre-damage value or if the vehicle is stolen and not recovered. This damage threshold varies by company. These companies typically take possession and obtain the title. Not all total loss vehicles result in a DMV-reported branded title, like a Salvage or Junk title. See the glossary for more information. Accident / Damage Indicator Various events could indicate an accident or damage in a vehicle's history, such as: salvage auction, fire damage, police-reported accident, crash test vehicle, damage disclosure, collision repair facility and automotive recycler records. See the glossary for more information. Hail Damage Title The vehicle sustained major damage due to hail. In most states, hail damage titles are issued when the cost of repairing the vehicle for safe operation exceeds its fair market value. Flood Damage Title States issue flood titles when a vehicle has been in a flood or has received extensive water damage. Standard Equipment Power Windows, Power Steering, Air Conditioning, AM / FM Cassette, Power Brakes, Tilt Wheel, 6-digit Odometer Safety Options 4 wheel ABS, Dual front air bags/active (manual) belts Vehicle Information: 1993 MERCEDES-BENZ 500E WDBEA36E4PB974052 SEDAN 4 DR 5.0L V8 FI REAR WHEEL DRIVE Standard Equipment | Safety Options Search for other 1993 MERCEDES-BENZ 500 SERIES vehicles in Elk Grove, CA Accident / Damage reported 8 Service records available 21 Detailed records available 94,911 Last reported odometer reading A CARFAX Vehicle History Report is based only on information supplied to CARFAX. Other information about this vehicle, including problems, may not have been reported to CARFAX. Use this report as one important tool, along with a vehicle inspection and test drive, to make a better decision about your next used car. CARFAX guarantees the information in this section Salvage | Junk | Rebuilt Guaranteed No Problem Fire/Flood | Hail Damage | Buyback/Lemon Guaranteed No Problem Not Actual Mileage | Exceeds Mechanical Limits Guaranteed No Problem GUARANTEED - None of these major title problems were reported by a state Department of Motor Vehicles (DMV). If you find that any of these title problems were reported by a DMV and not included in this report, CARFAX will buy this vehicle back. Register | View Terms Not all accidents or other issues are reported to CARFAX Total Loss Check No total loss reported to CARFAX. No Issues Reported Structural / Frame Damage Check No structural / frame damage reported to CARFAX. No Issues Reported Airbag Deployment Check No airbag deployment reported to CARFAX. No Issues Reported Odometer Rollback Check No indication of an odometer rollback. No Issues Indicated Accident / Damage Check Accident reported on 12/02/2002. Accident Reported Manufacturer Recall Check No recalls still require repair. No Recalls Reported Basic Warranty Check No data reported to CARFAX. No Data Reported Tell us what you know about this vehicle Still looking? Find similar cars just listed for sale in your area. Let us do the work! Get daily updates of MERCEDES-BENZ 500 SERIES vehicles for sale in your area. Email: Zip: 1992 MERCEDES-BENZ 500SEL Body Style: Sedan 4 DR Engine Type: 5.0L V8 FI Free CARFAX Report Sacramento European LTD Distance: 16.07 mi Contact Dealer 1992 MERCEDES-BENZ 500SEL Body Style: Sedan 4 DR Engine Type: 5.0L V8 FI Free CARFAX Report Acura of Stockton Distance: 23.6 mi Contact Dealer A CARFAX Vehicle History Report is based only on information supplied to CARFAX. CARFAX checked over 6 billion vehicle history events and found 21 record(s) for this 1993 MERCEDES-BENZ 500E (WDBEA36E4PB974052). Date: Mileage: Source: Comments: 08/30/1993 Georgia Motor Vehicle Dept. Roanoke, TX Title #26157108 Title or registration issued 01/28/1995 15,051 Georgia Inspection Station Atlanta, GA Passed emissions inspection 02/24/1996 31,998 Georgia Inspection Station Atlanta, GA Passed emissions inspection 12/18/1996 40,331 Georgia Inspection Station Avondale Estates, GA Passed emissions inspection 07/22/1998 48,028 Auto Auction Southeast Region Vehicle sold Dealers routinely buy and sell millions of used vehicles at auction each year. 11/18/1998 48,564 Service Facility Oil and filter changed chassis lubricated 12/07/1998 Tennessee Motor Vehicle Dept. Knoxville, TN Title #57397003 Title or registration issued New owner reported Loan or lien reported 01/18/1999 48,854 Service Facility Vehicle serviced 10/31/2000 59,713 Service Facility Oil and filter changed chassis lubricated Manufacturer's recommended maintenance performed Maintenance inspection completed Fuel filter replaced 02/09/2001 Tennessee Motor Vehicle Dept. Knoxville, TN Title #62099964 Title issued or updated Registration issued or renewed 04/05/2001 61,334 Service Facility Coolant level sensor replaced 06/21/2001 62,753 Service Facility Vehicle serviced 08/29/2001 69,369 Service Facility Cooling system checked 01/15/2002 Georgia Inspection Station Passed emissions inspection 05/01/2002 84,223 North Carolina Motor Vehicle Dept. Fayetteville, NC Title #774584021218106 Registration issued or renewed New owner reported 12/02/2002 North Carolina Police Report Accident reported in Cumberland County Involving right front impact with another motor vehicle Moderate/Severe damage reported 02/24/2003 89,771 Fowler Motors Conway, SC 843-347-4271 www.fowler.mercedescenter.com ww.fowler.mercedesc enter.com Vehicle serviced 07/21/2003 91,312 Fowler Motors Conway, SC 843-347-4271 www.fowler.mercedescenter.com ww.fowler.mercedesc enter.com Brakes checked 04/11/2007 North Carolina Motor Vehicle Dept. North Myrtle Beach, SC Registration updated when owner moved the vehicle to a new location 08/08/2008 94,911 South Carolina Motor Vehicle Dept. North Myrtle Beach, SC Title #770740195270104 Title issued or updated 05/03/2009 Mercedes-Benz USA, Inc. No recalls open for repair Print this CARFAX Report and take it to your pre-purchase inspection . Tell us what you know about this vehicle Have Questions? Please visit our Help Center at www.carfax.com Accident / Damage Indicator CARFAX receives information about accidents in all 50 states, the District of Columbia and Canada. Different information in a vehicle's history can indicate an accident or damage, such as: salvage auction, fire damage, police-reported accident, crash test vehicle, damage disclosure, collision repair facility and automotive recycler records. Not every accident or damage event is reported and not all reported are provided to CARFAX. Details about the accident or damage event when reported to CARFAX (e.g. severity, impact location, airbag deployment) are included on the Vehicle History Report. CARFAX recommends you obtain a vehicle inspection from your dealer or an independent mechanic. According to the National Safety Council, Injury Facts, 2007 edition, 7% of the 245 million registered vehicles in the U.S. were involved in an accident in 2005. Over 75% of these were considered minor or moderate. CARFAX depends on many sources for its accident / damage data. CARFAX can only report what is in our database on 03.May.2009 13:33:02. New data will result in a change to this report. North Carolina Police Reports: Provide an estimate of the extent of damage in its accident reports for the following: SEVERE: The vehicle cannot be driven from the accident scene due to severe damage or an injury. This level of damage often results in a Salvage or Junk title. MODERATE: The accident damage affects the operation of the vehicle and/or its parts. Examples include broken windows, trunk lids, doors, bumpers and tires. MINOR: The accident damage does not affect the operation of the vehicle. Examples include dented bumpers, fenders, grills and body panels. This level of accident should not compromise vehicle safety. NO DAMAGE: The vehicle was not damaged. [*]Are required if the estimated damage exceeds $1000 [*]Are released annually to CARFAX in August [*]New Owner Reported When a vehicle is sold to a new owner, the Title must be transferred to the new owner(s) at a Department of Motor Vehicles. [*]Ownership History CARFAX defines an owner as an individual or business that possesses and uses a vehicle. Not all title transactions represent changes in ownership. To provide estimated number of owners, CARFAX proprietary technology analyzes all the events in a vehicle history. Estimated ownership is available for vehicles manufactured after 1994 and titled solely in the US including Puerto Rico. Dealers sometimes opt to take ownership of a vehicle and are required to in the following states: Maine, Massachusetts, New Jersey, Ohio, Oklahoma, Pennsylvania and South Dakota. Please consider this as you review a vehicle's estimated ownership history. [*]Title Issued A state issues a title to provide a vehicle owner with proof of ownership. Each title has a unique number. Each title or registration record on a CARFAX report does not necessarily indicate a change in ownership. In Canada, a registration and bill of sale are used as proof of ownership. CARFAX DEPENDS ON ITS SOURCES FOR THE ACCURACY AND RELIABILITY OF ITS INFORMATION. THEREFORE, NO RESPONSIBILITY IS ASSUMED BY CARFAX OR ITS AGENTS FOR ERRORS OR OMISSIONS IN THIS REPORT. CARFAX FURTHER EXPRESSLY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. CARFAX® © 2009 CARFAX, Inc., an R.L. Polk & Co. company. All rights reserved. Patents pending. 03.May.2009 13:33:02 1993 Mercedes-Benz 500E VIN: WDBEA36E4PB974052 Body Style: SEDAN 4 DR Engine Size: 5.0L V8 FI Drivetrain: Rear Wheel Drive Information excerpted from the CARFAX Vehicle History Report and/or Safety & Reliability Ratings; see full reports for additional information, glossary of terms, source attributions,disclaimers & limitations. Go to carfax.com for complete Buyback Guarantee terms and conditions. Last owned in the following state/province: South Carolina Annual average mileage: 6,205 *Below industry annual average of 15,000 miles None of these major title problems were reported by a state Department of Motor Vehicles: Salvage, Junk, Rebuilt Guaranteed No Problem Fire / Flood, Hail damage, Buyback / Lemon Guaranteed No Problem Not Actual Mileage, Exceeds Mechanical Limits Guaranteed No Problem No issues reported to CARFAX on the following: Total Loss No Issues Reported Structural / Frame Damage No Issues Reported Airbag Deployment No Issues Reported Odometer Rollback No Issues Reported Accident reported on this vehicle. Please see the full CARFAX Vehicle History Report for more details. © 2009 CARFAX, Inc., an R.L. Polk & Co. company. All rights reserved. Patents pending. 03.May.2009 13:33:02 http://www.carfax.com/cfm/SRRDisplay.cfm?vin=WDBEA36E4PB974052&rptDate=1241375582403&suppressWss=Y http://www.carfax.com/manifest/bbg/viewPrintCertificate.cfx?vin=WDBEA36E4PB974052&make=MERZ&model=500E&year=1993&engineInfo=+5.0L+V8++FI&drivelineDescription=REAR+WHEEL+DRIVE&bodyTypeDescription=SEDAN+4+DR&coveragePeriod=05%2F03%2F2009+-+05%2F03%2F2010&tabbed=true&tabbed=true http://www.carfax.com/notes/vehicle_ratings.cfx?vin=WDBEA36E4PB974052&email=UDUNGCA@GMAIL.COM&consumerID=12527081&partnerCode=CDM&permutationName=STDCFX_UCP&lid=CRAC&lpos=first&closeWindow=false&suppressWss=Y
Thanks!!!! I just ran an autocheck as well. The car Im buying still checks out. The autocheck prices are MUCH better also. Thanks again!
Safety Options 4 wheel ABS, Running Lights, Dual air bags front, head, and sides/active (manual) belts Vehicle Information: 2008 VOLKSWAGEN GTI WVWHV71K68W093743 HATCHBACK 4 DR 2.0L L4 SFI DOHC 16V FRONT WHEEL DRIVE Standard Equipment | Safety Options Volkswagen Certified Pre-Owned - 04/10/2009 Search for other 2008 VOLKSWAGEN GTI vehicles in Elk Grove, CA No accident / damage reported to CARFAX CARFAX 1-Owner vehicle Corporate fleet lease vehicle 1 Service record available 7 Detailed records available 23,177 Last reported odometer reading The number of owners is estimated by CARFAX Year purchased 2007 Type of owner Corporate fleet lease Estimated length of ownership 1 yr. 6 mo. Owned in the following states/provinces Illinois Estimated miles driven per year --- Last reported odometer reading 23,177 CARFAX guarantees the information in this section Salvage | Junk | Rebuilt Guaranteed No Problem Fire/Flood | Hail Damage | Buyback/Lemon Guaranteed No Problem Not Actual Mileage | Exceeds Mechanical Limits Guaranteed No Problem GUARANTEED - None of these major title problems were reported by a state Department of Motor Vehicles (DMV). If you find that any of these title problems were reported by a DMV and not included in this report, CARFAX will buy this vehicle back. Register | View Terms Not all accidents or other issues are reported to CARFAX Total Loss Check No total loss reported to CARFAX. No Issues Reported Structural / Frame Damage Check No structural / frame damage reported to CARFAX. No Issues Reported Airbag Deployment Check No airbag deployment reported to CARFAX. No Issues Reported Odometer Rollback Check No indication of an odometer rollback. No Issues Indicated Accident / Damage Check No accidents or damage reported to CARFAX. No Issues Reported Manufacturer Recall Check Check with an authorized Volkswagen dealer for any open recalls. No Recalls Reported Basic Warranty Check Estimated to have 30 months or 26,823 miles remaining. Recalculate warranty Interested in an extended warranty? Warranty Active Still looking? Find similar cars just listed for sale in your area. Let us do the work! Get daily updates of VOLKSWAGEN GTI vehicles for sale in your area. Email: Zip: 2007 VOLKSWAGEN NEW GTI/GTI FAHRENHEIT Listed 3 days ago Body Style: Hatchback 2 DR Engine Type: 2.0L L4 FI Free CARFAX Report Niello Acura Distance: 21.33 mi Contact Dealer 2007 VOLKSWAGEN NEW GTI Listed 3 days ago Body Style: Hatchback 2 DR Engine Type: 2.0L L4 FI Free CARFAX Report Dirito Brothers Volkswagen Distance: 41.02 mi Contact Dealer 2008 VOLKSWAGEN GTI Body Style: Hatchback 2 DR Engine Type: 2.0L L4 SFI DOHC 16V Free CARFAX Report Niello BMW Distance: 16.07 mi Contact Dealer A CARFAX Vehicle History Report is based only on information supplied to CARFAX. CARFAX checked over 6 billion vehicle history events and found 7 record(s) for this 2008 VOLKSWAGEN GTI (WVWHV71K68W093743). Purchased: 2007 Type: Corporate fleet lease Where: Illinois Est. miles/year: --- Est. length owned: 10/9/07 - 4/10/09 (1 yr. 6 mo.) Date: Mileage: Source: Comments: 10/09/2007 Illinois Motor Vehicle Dept. Libertyville, IL Registered as corporate fleet vehicle 12/07/2007 8 Illinois Motor Vehicle Dept. Libertyville, IL Title #X7341641141 Title issued or updated First owner reported Registered as lease vehicle 04/09/2009 23,123 Fox Valley Volkswagen West Chicago, IL 630-231-9900 www.myfoxvalleyvw.com ww.myfoxvalleyvw.co m Vehicle serviced 04/10/2009 Volkswagen Certified Dealer Glenview, IL Offered for sale as a Volkswagen Certified Pre-Owned vehicle 04/11/2009 Online Listing Vehicle offered for sale 04/13/2009 23,177 Volkswagen Certified Dealer Sold as a Volkswagen Certified Pre-Owned vehicle 04/23/2009 Dealer Inventory Vehicle offered for sale Print this CARFAX Report and take it to your pre-purchase inspection . CARFAX 1-Owner vehicle! 1-owner 2008 Volkswagen GTI vehicles are worth an average of $1,737 more to consumers because 1-owner vehicles tend to be consistently driven and maintained. Use this as a guide when comparing vehicles. Learn More Tell us what you know about this vehicle Have Questions? Please visit our Help Center at www.carfax.com First Owner When the first owner(s) obtains a title from a Department of Motor Vehicles as proof of ownership. Fleet Vehicle Vehicle was registered or sold to a company that manages vehicle fleets. Lease When someone leases a car from a dealer, the dealer actually sells the vehicle to a leasing company. The leasing company then collects payments for the vehicle from the new owner for 24, 36, 48 or more months. A leasing company can be an independent car dealer or a car manufacturer. Ownership History CARFAX defines an owner as an individual or business that possesses and uses a vehicle. Not all title transactions represent changes in ownership. To provide estimated number of owners, CARFAX proprietary technology analyzes all the events in a vehicle history. Estimated ownership is available for vehicles manufactured after 1994 and titled solely in the US including Puerto Rico. Dealers sometimes opt to take ownership of a vehicle and are required to in the following states: Maine, Massachusetts, New Jersey, Ohio, Oklahoma, Pennsylvania and South Dakota. Please consider this as you review a vehicle's estimated ownership history. Title Issued A state issues a title to provide a vehicle owner with proof of ownership. Each title has a unique number. Each title or registration record on a CARFAX report does not necessarily indicate a change in ownership. In Canada, a registration and bill of sale are used as proof of ownership. CARFAX DEPENDS ON ITS SOURCES FOR THE ACCURACY AND RELIABILITY OF ITS INFORMATION. THEREFORE, NO RESPONSIBILITY IS ASSUMED BY CARFAX OR ITS AGENTS FOR ERRORS OR OMISSIONS IN THIS REPORT. CARFAX FURTHER EXPRESSLY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. CARFAX® © 2009 CARFAX, Inc., an R.L. Polk & Co. company. All rights reserved. Patents pending. 02.May.2009 13:39:09
Well I am purchasing a new car and purchased unlimited carfax reports. First 10 people to post can get a check...Just post up the VIN here.. If ya got a dollar or two laying around you can paypal me a donation at udungca@surewest.net If not, no problem. First 10 get it..
Im guessing 8k installed...
Got my cage all buttoned up, tell me what you think!
Z-Noob replied to ihatejoefitz's topic in Non Tech Board
Im not a cage expert, but I do know that those welds need some work. Im curious as to how much penetration you got...If those pictures are of the finished welds, it is FAR from complete. -
I actually own an xd as well, I did not mention it being it was not one of your options. I like the xd alot (5"). It has never had a "ftf" in over 3k rounds. It will fire any ammo you put in it, its cheap, has good ergo, light, and fairly accurate. Great firearm for the $$ Get one.
Im partial to 1911's as well. I would have suggested that but getting 1911's in "off calibers" gets expensive and .45 is getting expensive.
Glock: German--Cheap, eats any ammo, will go BANG EVERY TIME....PERIOD. People either LOVE the grip or HATE it. Decent fit and finish. SIG: German--More $$, bit more accurate, de-cocker, nice ergo grip. Nice fit and finish. It comes down to $$ and accuracy. If $$$ is not a big issue and you want "better" groups go with the SIG. If you want a cheap gun that will "GO BANG EVERY TIME" and will put good groupings, go with the glock. Go the the gun store and handle both. Buy the one that feels better in your hands. Have fun.
Where can you get it for $40k and with how many miles?
Although your car is beautiful, selling it in this market for approx. 70% of the c63 amg ($45,000) would be VERY difficult. Good luck on your goal.
How much does the fuel cell frame weight?
