Well, the gauges are in and I'll post pics soon, but in the meanwhile, heres how the rest went...
The autometer angle rings were excellent and I recommend them over using the stock bezel rings. You don't need to cut them and they make the end job look VERY professional. After doing a trial fit and checking the angles, I ascertained that the rings need to be fixed with their inner edge flush with the dash material, which leaves them sufficiently protruding so the instruments can be read but will be secure. Next I mixed up some two part epoxy and applied a bead about 1/8" wide right on the back part of the ring on the outside, then inserted them into the holes from the rear. Any epoxy that made it onto the ring that could be seen from the front was cleaned off with acetone.
Once the epoxy was dry I cut about 3/4" off just one leg of the supplied aluminum retainer brackets and put these on the back securing them with the aluminum machined thum screws. Job done. The rest of my dash customization includes adding more gauges where the heater controls used to be, adding a custom switch panel with ignition switch and starter button plus some other controls for wipers, heater etc.
