Bob_D
  • Gender
    Male
  • Location
    California
Bob_D's Achievements
Newbie
0
  1. I also took my clock apart ('73 240Z), cleaned and oiled it (very carefully) and it worked great for about a year keeping perfect time, but now it's losing about 10 minutes a week, so I think it's due for another cleaning. That clock had not worked at all for close to 15 years when I pulled it, cleaned and lubed it, so it's possible to revive these things, assuming the electric motor still runs.
  2. Hi Joe, so after I cleaned out the crud in that hole I did indeed discover it to be a blank. No threads at all, but it has the appearance that it might be able to be drilled out and threaded, which perhaps they did for a different market or application, since that tail casting could have ended up in a different car or truck when mated to a different bellhousing. So yeah, kind of weird that the 5 speed ONLY has a reverse sensor, where as my old 4-speed had both the reverse and neutral sensors. In the end I think I just left the neutral wires in the chassis harness unconnected, but the car will still start in neutral. I'd have to crawl under there to be sure... maybe I connected those neutral wires together? The memory is fuzzy now. FWIW having the 5 speed is GREAT, especially when everyone around you on the freeway wants to be doing 80MPH. I can keep up with traffic and stay below 3000 RPM (stock rear gears).
  3. Thanks for the quick reply NewZed. So it looks like my original flywheel, plus the new '73 clutch, Pressure Plate, Throwout Bearing AND '73 sleeve/collar mated to the 5-speed should work fine. Motorsport Auto only has 1 slave cylinder for '73-'83 Z & ZX (non turbo) cars, so that answers that question (which is great since I replaced both the master and slave cylinders not too long ago). Thanks for the heads up regarding the use of the original 4 speed shifter in the 5 speed, that tidbit wasn't mentioned in any of the discussions I have (so far) come across. Now, I "just" have to finish putting my engine back together in order to find out just how well the 5-speed works out for me.
  4. I recently acquired a late model FS5W71B 5-speed that supposedly came out of a 280ZX. It definitely has the right bellhousing bolt pattern, the single ear exhaust hanger, the reverse check plate, and the tall ears for the shifter. I've put it in 5th and counted input shaft to output shaft ratios, and confirmed it's the .745:1 5th gear. Based on the research I've done on this site and others it sounds like it should bolt in just fine, but I need to make sure I use the pressure plate and throw-out bearing out of either one or the other and not "mix and match". I have a completely new clutch/PP/TOB (Exedy) that I had bought for my 4 speed, and am guessing that it should be OK in the 5 speed? Can anyone confirm this? Also, the breather has broken off flush with the case. Any advice on removing the stub? The 5-speed came with a slave cylinder, should I use that one or my 4-speed's, or is there no difference? Looking at this web link http://www.atlanticz.ca/zclub/techtips/shifterbushing/index.html I do have the weird oblong shifter (bottom picture, right side) from the 5 speed. Does anyone have any idea what that internal spring is supposed to do in relation to the bushings? Is it one of those push-down to engage reverse features? Finally, this transmission only has one electronic sensor installed, up near the front (Reverse switch I believe), and nothing else. There looks like maybe something should be in the rear, and possibly got broken off. I need to do more cleanup in that area to be sure. I downloaded a copy of the '83 FSM from Xenon and the MT chapter shows 4 sensors! (Reverse switch, Top Gear Switch, O.D. Gear Switch, and Neutral switch.) In all the pictures of these transmissions I have found on line I have never seen 4 switches installed on the side of these transmissions. Does anyone know what the deal is on what reality appears to be VS what the FSM is calling out? In my picture the 5-speed is on the left, the 4-speed is on the right, The shifter with all the tape around it is the oblong one out of the 5-speed. The boss that is up from the tailshaft on the right of the center casting part line (red arrow pointing to it) is full of crud and I suspect where the neutral switch should be installed. Is there ANYTHING that anyone can advise me on in regards to making this swap successful? Pitfalls? "Gotchyas"? "As long as you are doing this you may want to..."? Thanks!
  5. Lorenzo, sorry for the late post reply, hopefully you have fixed the issue by now, but just in case you are still hunting for the trouble, I had a charging issue on my '73 very much as you are describing, and it turned out to be a corroded wire in my VR connector. It looked just fine, and I had plugged and unplugged that connector maybe 1/2 dozen times, but it wasn't until I really got in to every connector, cleaning out all the debris and crap that collects in those things, that I discovered the yellow wire was not actually connected! I purchased a new connector from http://vintageconnections.com/ and rebuilt that connection. Everything works great now. Good Luck!
  6. Hi P-Funk, I put the Pertronix Ignitor II and Flamethrower II in my '73. I kept the ballast resister, as the instructions indicated this was the way to go with an otherwise stock engine. My tach works fine, but where I really noticed an improvement is when I ditched the old 40 Amp alternator and upgraded to the internally regulated 60 Amp set-up, as detailed on this site in other posts. Open up your plug gap to the max suggested gap (.038 if my memory serves correctly) once you have the higher output Alt. I noticed that it's easier to start cold and seems to rev up a bit more "snappier". But as NewZed points out, you do have options for electronic ignition, but not all are compatible with a stock '71 tachometer.
  7. I realize this is a long-overdue answer, but in order to help out the community and anyone else who may be curious, here is your answer. On my stock 1973 240Z exhaust system, the resonator has a round body with "bullet" shaped ends. From where the end meets the pipe to the other end where it meets the pipe, it's 12" long. The body is 3-9/16" in diameter. The muffler is constructed in a manner not unlike a soup can, resulting in raised edges at both ends. From the end of those raised edges to the other end it is 14" long. The muffler body is 6-1/4" in diameter (the lip-edges are slightly bigger around). Where the exhaust pipe enters the muffler, the muffler has a little bit of pipe that protrudes to accept the exhaust pipe. The protrusion is 2-1/4" from the raised edge. The tail pipe that exits the muffler extends 8-13/16 beyond the lip of the raised edge. It flares out to a 2-1/4" outside diameter tip. The exhaust pipe itself is a puny 1-11/16" outside diameter.
  8. Yeah, they have a point. On my 73 the electric pump would not work with the alternator upgrade plug, using the stock Datsun "ADD-ON" harness. And by that I mean the short "extension" pigtail at the voltage regulator that adds a yellow wire back to the interior along with an extra wire from the starter solenoid also going into the interior. These two wires, along with additional wires from under the dash, feed into 2 relays in the passenger foot-well area. I ended up removing all that added-on wiring and 2 relays, and connected the connectors behind the radio but spliced in a fuel inertia cut-off switch for safety sake. Pump comes on when the key is in the run position (still using the stock wiring back at the pump). Seems like a bit of a pain, but the alternator upgrade is well worth it, and removing all the excess harness and relays helps to clean things up in the engine bay and in the passenger area. At some point in the future I plan on adding a hidden anti-theft switch and a relay to the system so the pump won't activate unless a hidden switch is turned on, but for now this works.
  9. Hi Rick, I know this is going to be an apples and oranges thing here, but I one had a '87 Ford Escort that had the ignition module mounted to the side of the distributor, and it would do the same thing. Allowing it to cool down, and it would work fine... for a while. Eventually I had to replace it. In fact I ended up replacing it about 3 times in the 300,000 miles I drove it, but the symptoms were always exactly as you describe. Good luck!
  10. Hi Dylan, I just fixed a similar problem on my 240. I have a '73 but with '71 SU dome-top style carbs. In my case there were several steps to fix this issue. 1st was my spark plug gap was way too large (even thought the plug color looked fine). I had put in a Pertonix electronic system and eliminated my points, and at the advice of a friend had opened up the gap on the plugs to .040. Turns out this wasn't the right thing to do for this particular engine. It really likes .035 (running NGK "stock" plugs). Second, my damper oil was low in both carbs. I removed my domes, cleaned everything, reassembled and used actual SU damper oil that I purchased from Black Dragon. It seemed a tad thicker than the 10W30 I had been using. Finally while I had the carbs synced fine at idle it turned out they weren't synced properly at 2500RPM, and required some adjustment of the balance screw (page EF 20 of the '72 factory service manual - if you don't have one you can find one here http://www.xenonzcar.com/s30/fsm.html HIGHLY RECOMMENDED). After doing these things my car came alive like it has never been in the 3 years I have had it. Idles smooth, accelerates strong, and the rich smell out of my tail pipe is gone. In addition it purrs on the freeway where as before it seemed to surge a bit. Finally my annoying 4500 RPM "wall" that the car seemed to hit has vanished, and it will rev all the way up to 6K no problem.(I don't have the guts to go any higher than that!) Hopefully this helps you out.
  11. Thanks for the feedback, that helps to put my mind at ease in regards to getting one of these body kits.
  12. FWIW, I ended up mounting it sideways, and when the window is rolled all the way down the top of the glass is flush with the top of the outside rubber and inside "fuzzy" at the top of the door panel, so in my case I think side to side was the way to go.
  13. I like that red you have, and would lose the stripe as others have mentioned. A gunmetal grey would look pretty bad ass, but I'd change out the interior to all black if you went that route. Add the LS1 in black on the side fender just below the body line. I am curious how that body kit has held up for you. Any regrets, "lessons learned" or wish you had picked a different style? Any issues with using a jack to get under the car? I am seriously considering going with either the one you have or the "stage 3" version from here http://www.thezstore.com/page/TZS/CTGY/classic02a01a since both my bumpers are shot, and replacing them would be about the same cost as the body kit.
  14. I am the 4th owner, but the previous 2 were family members, and none of us have worked on the door or window (the car has been in the family since 1984). The first owner opened up the door to install some speakers, but other than that I don't think he messed with anything else. I did find a lock washer at the bottom of the door, so I will double-check everything (the window frame seems real solid though, so perhaps that washer was an "oops" from the factory).
