53
Everything posted by Derek
Twin cam head for the L6 from Derek at Datsunworks
Derek replied to Derek's topic in Nissan L6 Forum
Now that's what I call commitment:) Update time. It didn't break yet. So my routine is bring it up to temp with varying RPMs, turn on the auto tune function in Tuner Studio and then hold it in a RPM range while it does it's thing. I turn it off and let it cool down then pull the valve cover to look for problems. So far things are surprisingly nice. Looks like I'm getting decent lube. No wear on the lobes. No "grey oil" seeping from the rotating surfaces. I did this three times today. The last time I held it at 4000 RPM for 3 or 4 minutes and it was smooth as silk. I probably have about an hour and a half on it all told. I'm feeling pretty good so far but we all know that can change in the blink of an eye. Work is picking up a bit so it will be a few days before I can make any major moves towards driving it. -
Thanks for the kind words everyone. Feeling better about it every time I run it. Ran it up to operating temp twice today without any hiccups. Got the idle area of my fuel dialed in a lot better so I'm no longer dumping copious amounts of gas in there. It reduced the loping quite a bit. Things are starting to settle in nicely. I'm in a industrial complex and naturally most of my neighbors know what I'm up to. I was talking to one of them who has a classic car resto shop. He was commenting on how good it sounded from his place. I mentioned that I hope it wasn't as noisy when I get it on the road and he replied " it will be better when it's not an open header" To which I said it's running through a resonator and a muffler already. Between the exhaust and the induction noise it's really loud at 5000 rpm:) But it's a good loud. -
Well if there is a will....And enough money. I'm not going to drive it until I have everything dialed in. I want that first run to be as stress free as it can be. I'm going to take the time to rewire the Megasquirt relay board like I have been meaning to do for the last 4 or 5 years. Moving the intake to the right side made space over there a premium. I also have to work out the throttle cable and vacuum system. At least a week but probably two. -
That's the one. Seems like a decent unit. -
Thanks for the words of encouragement everyone. Yea it is really growley. I have a pretty good mike. I'll try and get a Wave file recorded. The Iphone doesn't do it justice. I ended up milling the flange. As soon as I saw it would fit with the doors closed it was a no brainer. Took 6 hours or so because it was not a rigid setup at all so I had to nibble. Made for a nice fit. Thanks for the thought. Donate to Hybridz if you like. The transmission will not be long for this world. The 6 speed is a tasty looking conversion. Hoke needs to make it happen or others might:) I don't need a 6 speed but I'm a sucker for the "These go to 11" mentality. Which is why I built a twin cam head. I didn't need one of those either. -
Thanks. The valvetrain noise is not as loud as it is in the video. I have about 30 min. of run time on it. Pulled the valve cover a few times checking things with no surprises. The revs in the video are up to around 5000. Now comes the long process of getting everything dialed in. There are a lot of loose ends. I'll probably start sleeping better:) -
I'll just leave this here https://youtu.be/70FC_Zh8ufk -
Yea me too. Unfortunately it's usually in the same state I left it in when I left the night before:) Making progress. Lot's of little things to take care of. Probably fire it off next week some time. -
Actually Bill and rich came down to the shop on Friday to check it out. I'm hoping to get Bill to start up the garage parties again. I knew money would be tight at this point so I wanted to stick with the exhaust I had. And that was 2.5". -
2.5" Dry fitted the induction system yesterday. No surprises. And at this point in the project that's a good thing:) Since I have a large audience on this I thought I would pass along a tip I did. I normally glass bead aluminum parts to clean them up. These were really ratty so I knew they would only come out marginally well. But then I tried something extra. I threw them in my vibratory finisher with ceramic media. Almost brought them back to original die cast look. So there is derek's tech tip for the day:) -
I'm not familiar with that block. If it's the same as a L series except for bore then yes it will fit. I don't think you could move enough air though. ITB's fit with about 1.5" between the shock tower and the velocity stack. The black box is moving forward and the battery is staying put. Got enough on my plate already:) -
Speaking of chains, just realized I never posted these. Cams timed and final lubrication test complete. Everything looked great. Here are the finished hubs. This was taken when I was doing the initial cam timing. -
I hope you all are as supportive if it throws a chain in the first five minutes:) -
Probably will do a few events. I'll post here. There is a strong group in Tampa. Thanks And yes it is February. But I didn't say what year:) -
A couple of beauty shots: And it's in:) Hood clears no problem. The gyrations I have to go through to get the valve cover on qualify as performance art. It just clears the hood latch bracket. I think most of the problem is with the oil supply plate that I added. It won't be on the production heads so I hope it won't be an issue going forward. Yes I know the wiring is a mess. It's on the list:) -
The problem is the cams on the K20 are too close together to run a 3/8 pitch or 06B chain in a 2:1 configuration. That's why the KA24 works well. To do a single chain you would need to drop down to 1/4" pitch and probably run duplex. Now we are talking custom gears and custom chain guides as the lead from the cams down to the crank will need to be wrestled into alignment to still use the stock lower timing cover. As always. Is it worth it? -
Made some progress on the cam gear adapters. Each one is a 2 piece affair. The inner hub is keyed to the cam and the outer hub holds the gear. The back side of the inner hub holds a thrust bearing. This way I can shim the bearing if I want to decrease the clearance. There will be 5) 5mm bolts in the outer flange to lock the 2 hubs together. Assembled hub. With gear. I had to turn the gear around to get it to line up with the idler gear. And the best part is it fits! Tomorrow I'll do the slots and the bolt holes. I'm going to see if I can get the cams close degree wise before I key the hubs. This way I'll be able to utilize the full travel of the slots. I'm already working on simpler solutions for the next ones. -
Look for delivery next week. I'd wait by the door if I were you:) -
Just got the word from Xnke. The headers are boxed and shipping tomorrow. I started on the cam adapters today. I don't know how long it will take to get them finished. They may have to go in and out of the lathe a few times to get the chains tracking properly. I've never setup a DOHC head before so there is going to be a learning curve. If everything stays on track I should be ready to start the install next week. I have no plans to engine dyno. I may put it on a chassis dyno if I feel that it's putting out decent power. Don't forget it's only 8.5:1 compression ratio so it's not going to be a power house. This is more about longevity and proving the systems work. -
They do now. As I said earlier they were a tiny bit tight. I worked them in a bit and I can spin both by hand. I think it was one of the caps had enough galling that it was causing the problem. All is well....carry on.. -
Don't know the clearance. They are the same diameter as the stock cams I have. Keep in mind my hand is 56 years a tradesman so my grip on it isn't that great anymore. A couple of the cam towers have a tiny bit of galling up in the caps so I'll polish them out and see if it helps. -
Camshafts are in the house! Or rather the shop. They look great and everything measures out. I stripped the rockers from the towers and mounted the cams up in the head. It was snug but I could turn them. Not by hand but with a wrench on the flats it moved very easily. This was a big concern of mine from the beginning but I think it's going to be ok. Now I can start on the cam gear adapters. -
Got my plug wires from Magnecore. Great work as usual. Made some custom looms out of grey type 1 pvc. The EDIS coil mounts up under the front intake manifold so for the most part it should be hidden. -
Oh it will work....For how long? That's the question:)
