Derek
    53
Everything posted by Derek
  1. I'm not sure. Part of the process is me locating victims willing participants with different years to participate in the beta. Looks like you have a 78....Interested?
  2. Yes tweeters in the pillar would be nice. But these are in the kick panels:) Not getting a lot of feedback on fuse box access. In the mean time I figured that like the drivers side there is only one place for the speaker. You will have to remove the panel to change a fuse. I use industrial velcro on mine with good results so that probably will be the plan. Stay tuned
  3. Does Chrome offer a TonyD translation plugin? I sure could use one)
  4. I use it a bit and it's rugged. It will melt through nitrile gloves with a quickness. Use good ventilation.
  5. Well it looks even better in person! The acorn hold down nuts are a little small. I'm going to have to work on that. I'm really happy with the quality of the powder coating. Ivan at http://www.powder-coated.com/ did an amazing job. Fast turnaround and great communication. Well now that I have it back I can measure up and order the plug wires. Getting down to the nitty gritty at this point.
  6. Got some pics from the powder coater. It looks like they did a great job. I used http://www.powder-coated.com in Orlando. I'll post more when I get it back but I'm really happy with the look. I want this in my car right now:)
  7. I'm going to try this again. Hi everyone. Over the years I’ve gotten quite a few requests for kick panel speaker pods for the 280Z. What was holding me back was uninterrupted access to a 280 for measuring and fitting. I finally found one that was close enough and cheap enough for me to buy. One thing that is very apparent is there isn’t a lot of room to work with. Especially on the drivers side. At this point I’ve completed a working prototype for the drivers side and wanted to get input from interested buyers as to the layout on the passengers side. The bad news is there really isn’t any room for a high end 5 1/4” speaker. I designed it around these Pyle PLS502 slim speakers. I also believe the retro sound R525N will fit as well. There is 1.9” available right now for top mount clearance. Most of the higher end speakers require 2 3/16” and that’s not going to work. I found a few models that had a 1 7/8” top mount clearance. The tricky part is how far the grill sticks out beyond the speaker. None of the manufacturers listed grill height. Here is a few shots of the drivers side. Keep in mind this is a rough prototype and the cuts are crude. I have the speaker as far up and as far back as I can get it. There is reasonable room to get your foot over to the dead pedal. It may take a bit of retraining but it’s doable. Clutch pedal just clears grill Dead pedal is accessible. Remember the cuts are really rough on the prototype. Before I start the passengers side I wanted some input as to whether to angle the speaker to improve acoustics or keep it flat to match the drivers side. And how to handle fuse box access. The pricing should be around $100.00 - 125.00 for the pair. The CNC router work is much more complicated than my regular panels requiring multiple setups. So if you think you may be in the market for a set and want to have some input either post here or PM me Thanks Derek
  8. I don't know what's up but I can't seem to get my content to post. Not sure why I keep getting a database error.
  9. Actually it's amazing how restrictions on racing will seed innovation. I still want something like the freevalve rig. That would be so slick to build around.
  10. Wahoooo! I may have to eventually get this in my car soon!
  11. Finishing up the last little bits I need. Made the filter housings today. They use the same wire mesh and oiled foam filters that I use on my other manifold. I've been very happy with the filtration from the foam and saw no reason to do anything different. The housing probably isn't the best choice for power as it will disturb the air flow around the bell. Meh who cares. I like the look. They still need finishing so the tooling marks from a well used CNC mill are visible. I have a little boss on either side that will hold a set screw to hold them in place. this started out as a 4"X8"X.75" piece of 6061. Word from Crane is I'll have my cams by the end of next week. Did an oil flow test and I'm getting excellent results up through the towers to the cam journals. The upper chain tensioner is getting plenty of flow as well. I won't know beyond that until I get the cams installed. Closer every day!
  12. Is it time to start on a custom block:) Mazworxs can machine the casting. Man I wish I had a lot of money.
  13. That's what TonyD and Xnke are advocating. V2 is going on a friends car and he's gravitating towards a high revver. I think it would be worth it for the sound alone:)
  14. I personally would rather put my money in the bottom end. 3.0 stroker that can pull some RPMs would probably be a pretty nice mix. Now if I had a butt ton of money to spend I'd love to have it all. Right now I'd settle for cams and a header...
  15. Actually I saw that Dorman makes them for different models so there my be something out there that will work. Anyone lurking with access to variable hubs and a caliper
  16. Out of everything, the variable sprocket is what would be the deal breaker. Unless the K20 could be adapted. That's a pretty precise piece I'm sure.
  17. I will say from a manufacturing stand point adding VCL or VCT is going to cost plenty. Right off the bat double the price of the cams and double the price of machining. Then there will need to be a custom variable timing gear hub made and custom cam towers as well since the stock ones won't work. Vtec looks less less attractive when the head is now going cost you and additional $8000.00. Edit: Had my VTLCLTC all jumbled:)
  18. I've come to the conclusion that anyone that want's to make power with a NA motor should plan on custom pistons. They really will be the variable that makes everything work together. The Turbo guys will have an easier time for sure. Bolt it on and blow. Especially people who are already at the flow limit with their L head. The V2 version won't have a combustion chamber cast in like the prototype. There will be plenty of meat to machine whatever style you want. I want to have a A2 combustion chamber in my library so that people who wan't a "stock" chamber can get it. It will also make communicating with piston companies easier. I believe the A3 chamber is asymmetrical to accommodate the economy version of the vtec that it uses. One of the intake valves are "lazy" and only opens a slight amount during normal operation and then opens fully at higher RPMs. This is for milage reasons and not performance. At least that's what I deducted from my research.
  19. I had the Spahl system for a while and it gave up the ghost. I went to replace it and ran into the same issue with the NLA thing. I opted for this Pyle unit http://www.pyleaudio.com/sku/PWD701/4-Button-Car-Remote-Door-Lock-Vehicle-Security-System It worked for me as I already had the door lock solenoids installed. The black dragon kit looks pretty nice.
  20. Not sure if there are any K20 lurkers following this thread but I'm trying to get my hands on a A2 head. The heads I have are A3 and the combustion chamber is different. My preference would be a cheap junker that they weren't going to use. As long as one chamber is good. After that would be a loaner as I have no use for it after I scan the combustion chamber. I would pay shipping both ways Just throwing out a few feelers. PM me or email at "kick at red240 dot com" Thanks Derek
  21. Too late. I'm already too attached to my artisanal hand crafted knurled cap:) Thanks for the thought though. But since you're feeling generous PM me your parts inventory and I'll pick a few things out:)
  22. I'm sure you noticed how fast I said yes when you offered to do it for the price of materials:) I'm no dummy. If you hadn't offered I would have stuck with plan A which was manipulating a set of stock headers to fit. I knew money was going to start getting tight at the end and I was right.
  23. That Jeep sensor that Madkaw is playing with looks promising. Cheap too.
  24. Looking good Xnke. Who knows, you may finish before Crane:) Thanks Derek
  25. Thanks for the visuals. I'll double check them tomorrow but I'm sure we have plenty of clearance.
