Hey_Allen
Everything posted by Hey_Allen
Key sparks when touching door handle
Hey_Allen replied to markib85's topic in S30 Series - 240z, 260z, 280z
Regarding the gasoline smell, one thing I found caused it in my Z was the fuel filler vent hose. Once I found the hose where it was routed into the rear of the hatch area, I found that it was BADLY dry rotted and cracked. I replaced it (which was a bear, just fishing it through all the little nooks and openings) and fixed that issue, surprisingly easily.- 16 replies
- wiring
- wiring short
(and 2 more)
Tagged with:
I'd been kicking around linking my MSII to my car-pc for data logging as well as tunability. All it'd take to tune inside would be to map it's serial port remotely, or to remote desktop onto that computer from a remote machine. I wouldn't want to be doing any engine-running tuning from a relayed machine, just on the off chance of any latency or dropped connection issues, but then again, why would you have the engine running when you're not at the car in the first place?
From what I've heard about it, it's acceptable within it's design limits, but those limits are partially caused by the sound card hardware that it's running on. That being said, for probing EFI components, it shouldn't be an issue. I have no personal experience with it, and was searching for info on it when I saw it installed with the DIYAutotune software package as well. Then I went ahead and ordered a set of standard probes to hook up the $20 o-scope that I'd found at a surplus and used equipment vendor. Best of luck, and happy tuning!
Your Buick might have a PWM dimmer circuit, rather than a simple potentiometer. By pulsing the power at varying rates, you can get the appearance of different light levels from a LED or incandescent bulb, and with less wasted power through heat in the resistor of a potentiometer based dimmer.
Cheap TIG welder-converting from robotic to manual use??
Hey_Allen replied to OlderThanMe's topic in Fabrication / Welding
I'm fairly certain that the 1 (/) ahead of the voltage ranges indicates single phase, but I could be wrong on that. What got me was the amperage requirements! 109A at 230V, 54.5 @ 460, and 43.5 @ 575... That's a lot of juice at any voltage! Happy sparking! -
I've heard from one military police officer I know about a problem that cropped up with AFFF, when it comes to car applications. After they soaked one of their squad cars due to it just being too near a burning aircraft, they found that the paint would not stay on the car. After three cleanings and repaintings with different methods, they gave up on it. As far as carrying an extinguisher, I got started carrying a 5# CO2 years ago when I was first driving a diesel car. Good way to stop a runaway diesel engine.
That's my car, and it does have battery and frame rail damage, as shown in the pictures. Somebody in the past decided that urethane sealant was a proper rust "repair" and painted the underside of the wheel well below the battery with it. The acid apparently ran down into the frame rail, and the pictures show the rest. I am looking to sell as I don't have the facilities to fix it in an apartment complex, and for all the reading I did here before buying this project, didn't pick up on that as a possibility. As the CL posting says, I'm just looking to recoup most of what's in the engine. If someone was motivated to repair it, more power to them. On the other hand, it would be a prime donor car to transplant into another body.
From the commentary on the video, it looks like the owner had some ignition wiring backward, causing some backfiring. Now that being said, I wouldn't think that just backfiring would cause that much damage so quickly, so who knows what else these idiots got up to when assembling the thing. Bounce the cats off the ground a couple of times while mounting the cat-back exhaust, possibly?
Here are a few links to options from the motorcycle side of the house. http://www.shopcycle-parts.com/productdetail.htm?productId=4008988&browse=77192&shopBy=4108&catalogId=652 There are a few options among those, and there are other sources that are cheaper by far, for some of that stuff. The advantage with buying from a company like Drag Specialties is that you can either get them direct, or through any local motorcycle shop. (and as usual, prices vary widely between vendors...) Hmm.. I posted them, then checked them only to find that they all now directed to the same product, even though they were different links. Wierd. Try looking on the list at Drag Specialties directly: http://www.dragspecialties.com/fatbook/21/240 http://www.dragspecialties.com/fatbook/21/240/3896677 http://www.dragspecialties.com/fatbook/21/240/3896705 http://www.dragspecialties.com/fatbook/21/240/3896722 http://www.dragspecialties.com/fatbook/21/240/3896650 http://www.dragspecialties.com/fatbook/21/240/3896794 A slightly different take on it, these are flush mount welded bungs, with a pop-up plug that blends flush with the surface around your fuel opening. http://www.dragspecialties.com/fatbook/21/240/3896406 http://www.dragspecialties.com/fatbook/21/240/3896384
I've had good luck with the Deka battery that I'm currently using, and was referred to them by a friend who also uses them. AGM battery like the Optima, but not in spirals. http://www.eastpenn-deka.com/
On my car, the only holes I see are drain holes (and the hole from someone running over something, but that's another matter...) I'm going to have to find a few rubber floor plugs to cap those holes once I get the car back on the road!
When I was shopping for some replacement heads for my 1st gen SBC, I ended up getting a set of Summit branded heads. In the size I got, (and in cast iron, not aluminum) they were just small intake runner versions of the Dart Iron Eagle heads. I don't know if they offer the aluminum versions, but if you're not looking for peak HP, and a little better torque curve for daily driving, you might look at the Summit house branded offerings.
I have to ask. How well do they suit taller people? Also, how high are they at the seat? I like the look, and for the price, they look like a steal, but I am 6'4", so... Oh, in doing a little searching about the F1Spec seats, I found that F1Spec is a sponsor over on the HondaTech forum, and that they are doing a Holiday special pricing on them... I'm not sure just yet what the special is, as it requires a PM to get a price, but the base price offered to the members there is a bit lower than the prices on the site above.
Runs good until it warms up, then
Hey_Allen replied to GLSHLE's topic in Gen I & II Chevy V8 Tech Board
Any chance that the choke is messing up, opening early? On my 350, it gets really temperamental just as it's starting to come off the choke, due to the choke opening up a bit before the engine is ready for it to. When it's doing this, it doesn't want to rev up, and will sometimes stumble and sputter. -
Heh. Yeah, I noticed your reply just ahead of mine once the browser refreshed after I posted. Being at work meant I had to post and run. I've heard something about minds that think alike, but I wonder about the great part, considering at what level I'm usually working!
Another option would be to put something around it that keeps it from deforming under vacuum. I seem to remember having seen a few hoses with a tightly wound spring around them, when it couldn't be on the inside for one reason or another.
Need advice on what Wide Band O2 tester to get.
Hey_Allen replied to chrism's topic in Fuel Delivery
There's a link to a comparison test around here somewhere, that I suspect would show up on a search. The general gist of the test was that the Innovate was a good value, and if I remember correctly, was the only one that allowed easy recalibration. -
I know that at least some people do buy cars from CL, and that I've purchased two from it, including my Z. That being said, I've had relatively poor luck selling stuff on CL.
One other option that is mentioned in the JTR book was to just use the Moroso upper radiator hose radiator cap splice. Putting it near the thermostat housing puts it high enough, in my car, that it's just a little higher than the top of the radiator. I ended up putting a 20lb cap on the radiator, and a 16 or 18 on the upper radiator hose. I also capped off the lower bleed/overflow hose, as I want it to fill back into the system at the high point, getting rid of possible bubbles. Another thing that I found helped prevent bubbles being trapped was to open the heater core all the way when purging the system, as I seemed to get some trapped air in that area if I didn't do that. I suspect most of this was already common knowledge, but since I found other's talking about it, and it eventually worked for me, I suppose it can't hurt to restate it. Thanks again to all those who originally suggested the solutions, as well!
What model year car do you have, Yehghua? If I'm reading it correctly, you have a 75 280z? If so, as I understand it, you should be able to use something from any of the later 70's z cars, but I may be off track there. Actually, see post five here: http://forums.hybridz.org/showthread.php?t=123516
Heh, I've heard a few interesting stories about the camel spiders from a couple of the other soldiers around here. One involved a GI attempting to use a trench latrine, only to end up hoofing it away from a camel spider, trying to hold up his pants, while his buddy tried to stop laughing long enough to put a round in the spider that was hot on his trail. Keep safe, and definitely stay hydrated!
GOOSE HORN coming from the engine.. WTF
Hey_Allen replied to proxlamus©'s topic in Trouble Shooting / General Engine
Could the heat relation be something expanding as it warms up, causing a leak? With the comment about the squealing and under vacuum, I am thinking of vacuum being drawn across a gasket somewhere. As a kid, I was shown how to make an obnoxious squeal with a folded piece of grass or paper that you could blow across. Could this be happening in your intake system somewhere? -
I don't know how much it might affect your plumbing decisions, but some of the factory turbo cars work around the BOV and MAF metered air issue by redirecting the outlet of the BOV back into the intake system ahead of the turbo, but after the MAF. Again, I don't know that it would make any difference for your project, but I thought to mention it, as it came up often when Subaru WRX owners kept deleting the connecting tube on the factory systems, chasing the "pshhhh" from an atmospheric venting BOV. Happy wrenching, and I hope it keeps going together as well as it looks currently!
For those of us building on a slightly lower scale, I found that the Summit branded 165 runner heads are a fairly good quality product, and apparently manufactured for them by Dart. I think one of the stud threads was a little stiffer than the others, but I had NO issues with any truely binding, or being crooked. They're cast iron, so a little on the heavy side, but for my application, that's fine. For me, I was just looking for a fun level of performance, and good torque. The $650 price tag for a loaded pair helped though! http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D152123&N=700+115&autoview=sku
While I don't know anything about the twin disk clutches personally, you might find a bit of information on the Subaru forums. When I was driving a STI, there were a number of guys who were burning out the clutches on them, and one of the more common upgrades was to go to a multi disk setup. I had managed to fry my clutch, but was babying it along still when the car got totaled.
