Content Count
114 -
1 -
Feedback
0%
Samurai7one last won the day on November 6 2014
Samurai7one had the most liked content!
Community Reputation
1 NeutralAbout Samurai7one
Rank
Always Here
Contact Methods
Website URL
None
Gender
Not Telling
Location
Louisiana
Recent Profile Visitors
Recently I saw the Nissan concept 370Z with the Q50 VR30DDTT 400HP motor mated to a 370Z 6 speed manual. Has anyone put this engine in an S30? If not, who will be first?
Can anyone ID these wheels on this Z?
Samurai7one replied to luke87gt's topic in Brakes, Wheels, Suspension and Chassis
15x9 0 offset SPD line Zuka wheels. I am pretty sure I have the same. Mine are bronze. Your pic shows gunmetal. I bought mine from JPNgarage but I think they are closed down now. I did see some on ebay though. Supposedly, these where made by Atara Racing as mentioned here: https://dailydatsun.wordpress.com/2016/03/31/watanabes-panasports-and-other-8-spoke-rims/ Also, I have T3 control arms pulled in as much as possible in the rear, to make them fit. -
So many questions (L28, California Datsun, Build options)
Samurai7one replied to Stokked240z's topic in Nissan L6 Forum
Just do an RB25DET swap, it will cost as much or more to build a L-series stroker and put high performance parts on it. With the RB, you will get reliable performance and you can always turn up the boost. Plus, you keep the Nissan family straight six- 27 replies
- l28
- california datsun
(and 1 more)
Tagged with:
Twin cam head for the L6 from Derek at Datsunworks
Samurai7one replied to Derek's topic in Nissan L6 Forum
Mind blown! -
I found this rubber elbow fits nicely. I thought I was being smart, sticking the PCV valve in there but, lol, I realized its not protecting the top vent from backfire. so I got to re think my set up, but the black rubber elbow works as a simple solution for making a connection for the lower fitting. I found it in the "help" section at AUTO-ZONE, It's DORMAN part number 46035. Its actually the second one I have had. The first one developed surface cracks after 3 years. That's to be expected I guess, next next to that header. No big deal, just picked up another one $10. I'll
LED Headlight Bulbs, anyone tried them?
Samurai7one replied to Samurai7one's topic in S30 Series - 240z, 260z, 280z
Wow😃- 15 replies
I want to swap in some H4 lights and add LED bulbs. I see many types and cooling device configurations of led bulbs available, has anyone tried them? What mods were necessary? Results? IF YOU CAN PLEASE, mention the brand /type bulb you used. Thanks in advance!
- 15 replies
I'm pretty sure those air-dams are supposed to bolt to the outside of the buckets, not the inside. Makes a difference. Maybe you can do a search on here, pretty sure it's been discussed.
Looking for New Steering Rack Feedback
Rack installed. Feels good to me but my perspective is skewed because I have always had steering issues. So, I don't know what normal feels like, but this feels good to me. -No more feeling that the steering wheel is trying to jerk out of my hand everytime I hit any slight bump. -No more play - zero NOW, let me add this, I found an isssue while installing the new rack. Turns out where the steering shaft coupler slips onto the steering-gear box input-shaft, the bolt was not properly torqued. I put the new rack in and felt steering, it felt exactly the same as before. I thou -
Samurai7one started following IMG 0105, IMG 0107, IMG 0114 and 4 others
Forgive the delay, I'm finally feeling better after a bit of food poisoning. Here's what I have to report: -ratio is the same as my 77 280z rack -stroke is 1/16" more in both directions -stock rack was 3 turns lock to lock / new rack was about 3.15 turns (probably due to slightly longer stroke) -splines appear to be the same on input shaft. -gear housing is cast aluminum on new rack vs cast iron on stock rack (checked with magnet) -new rack weighs less (4.5kg vs 5.5) -the rack gear itself on the old unit is flat on the side opposite of the gear teeth. It's round on the new
