Everything posted by brokebolt
The pattern is a bit goofy but they should fit. All the VLSD shafts I've seen have the splines cut all the way along the shaft. Looks like those were machined excessively for no real gain. If you look into the carrier on the passenger side you will see that the splines have a "dead" spot where the unsplined portion of that shaft would be when installed. Have you worked out a solution to install CV on the ends of those differential stub shafts? Would be interesting to see what comes out of this. Mike
I've seen a post or two on this topic: http://hybridz.org/phpBB2/viewtopic.php?t=19426&highlight=lsd As stated in the topic above, the unit you out bid me on is the 30 spline version. You will need to find some S15 shafts or have input shafts made as your stuff is 29 spline, and everyone elses. This unit should bolt into a R-200 easily enough and you will need to use a 12mm bolt ring gear. The other option is have bushings made or find some so that this carrier will work with the 10mm ring gear bolt. I got pricing from MM and was considering the bushing method but decided against it. Keep us posted on your findings about the spline issue and R-200 transplant, well I would be interested to see what comes out. Side note: The VLSD input shafts are different in length but not in spline count. All R-200 stuff is 29 spline count. The difference between the LSD and/or open carrier vs. the VLSD is the length of the differential stub shafts. The passenger side is long where as the drivers side is shorter and a bit different. All LSD and/or open carrier units use the same pattern on the differential stub shafts. On those units the passenger side is longer and the drivers side is shorter. The 200SXT is reversed with the 4.11 ring and pinion. The longer side is on the passenger side and the shorter one is on the drivers side. Mike
Rear five lug is not such a bolt on item, there are ways to do it though. Easiest is have the old five lub stub axle modified to five lug. MM does this work or you may find a machinest that is willing to do the work for you. You could machine the five lug stub axle to fit the four lug bearings but the stub axle is hardened steel so you may have issues with that. Also the companion flange spline pattern may be different. Some here have posted solution on the five lug conversion you may want to do a search and see what you can find. As for the LSD, swapping the guts I think is easiest. If you go and buy an LSD that is what you would have to do anyway. There is no difference between the carrier and the LSD as far as dimentional measurements, bearing diameter and ring gear dimentions for example. The only difference is in the ring gear bolt size and the hole for the bolts, either 10mm or 12mm bolts are used to attache the ring gear to the carrier. Again if you run into this 12mm carrier with 10mm ring gear get some bushings made. Anything after 1984 in the Z car version is 12mm and 1986 in other Nissan products (that I've seen).The only other consideration is the ratio which hasen't been addressed here yet. Ratio Stamp Speedo Gear Tooth count R-200 3.364 37:11 Yellow 16 280Z 2+2 (4 sp) 3.545 39:11 Black 17 280Z (M) 3.700 37:10 Blue 18 280ZX 6/78-6/79 2+2 (M) 3.900 39:10 White 19 280ZX (M) 80-83 200SXT 84 4.111 37:9 Red 20 200SXT 85-86 Hope this helps a bit, not 100% complete but a good start. Mike
I've e-mailed Tim concerning his adpaters, a group buy would be the way to go. As for the other issue of welding, I like to modify or make cheap items to adapt stock parts. Just one mans opinion. Mike
My take is this, pull your guts out of the R-200 you are currently running and install the LSD unit from the R-200 300ZX. This would eliminate the need for major mod work. Using a five point scale determination of difficulty, personnaly I would rank this level of mod that top fuel ZX lists as difficult (4) as it requires more than a basic set of hand tools, but requires drilling, presicion measuring, welding, and such. For his skill level that may be medium (3 or 2) for the rest of us bone heads that is would be much higher. Your R-200 ring gear is most likely a 10mm bolt where as the 300ZX is 12mm. Contact MM for bushing or your local machists, for installig the LSD carrier with the smaller bolt hole ring gear. Installing the LSD carrier would be in the medium to moderate range (2 or 3) as you do need to set the gear backlash and bearing preload, which requires a dial indicator and magnetic base. Still not easy. BUT what is easy is taking both differentials to your local differential shop and pay them to do the hard work, leaving the easy work for you...Remove, replace, and reinstall. Mike
Again looks good. I posted a few pics in my album here. Mine might be overkill but I was concerned about strieght. I needed a firm platform to mount fuel pump, filters, and exhaust pipe as my original one was modified for such items. 80 M.P.H., twin 2.5" pipe, 2" lowered car, 14" wheels on 60 series tires doesn't leave much room for rodents. I am always draggin' pipe! Had to weld skid plates on the bottom of the pipe, believe it or not! Mike
I e-mailed SSS510 a few times, he did mention cutting and trimming the tunnel, that made me think twice. The concept sounds dynomite though, if anyone does this conversion, it sure would be nice to get a detailed description for future project seekers. Does the T-56 mate up to the stock T-5 Nissan bell housing or would that need to be a custom job like Mr. SSS510's? Mike
Go here for a nice pic http://hybridz.org/phpBB2/viewtopic.php?t=20387 This is a VLSD unit with side stubs, all VLSD units are alike and use the same side stubs. Don't know where you can get NEW ones but used might be found at recycle yards, rare but they do exist. Use the national parts locator service, most machine shops and recycle yards should be helpful for this. Mike
I have a VLSD from a Z32 and had a VLSD from this year car your questioning, both are the same. The differential stubs on the Z32 has one short and one long, and bolt on like the 240sx but they have five bolt pattern not the six bolts that the 240sx uses. The 1988zxt ss uses the same cv EXCEPT for the right side (or maybe the left don't recall off hand) as the other variety of half shaft, and again that odd ball longer splined end is opposite of it. Don't know if they are available, if so maybe only a dealer item, as I have tried to find a supplier for the half shafts with no sucess. Hope this helps. Mike
Here is an exert from my notes, hope it helps with the swap question. As for the durability, the R-200 is roughly the same dimentions as a Dana 44, which a lot of 4X4 guys are using in their Jeeps and such. Not a Dana 60 but than again you can fit the entire R-200 ring gear into the Dana 60 ring gear. Some guy here on this board has a mount that fits the R230 inplace of the R-200. The "guts" are the same, only the case is a little larger, actually more squattier, and they used a different ring gear and pinion gear. It has a shorter snout that the R-180 and R-200. The guts usually get torn up before the case does, so in my opinion the case is not that large of a consideration. Parts Swappin’: R-200: The R-180 to R-200 swap is fairly straight forward for 240 Z’s. First get the parts together, R-200 with selected rear end gear ratio, 240 Z drive line, transmission of selected year for ratios, R-200 mustache bar, R-200 rear transverse link, stock 1970-78 Z U-joint half shafts with R-200 side flange. Now install the R-200 mustache bar so the bar is behind the transverse link vertical support on 1972-78 models. All R-180 mustache bars are mounted in front of the transverse link vertical supports. Doing this may require a bit of angling it around and cursing but it should fit without removing the fuel tank strap. Next install the R-200 rear transverse link support in it’s stock location with bend facing the rear of the car. Now install the front isolator mount, R-180 and R-200 are the same and now your new R-200 should bolt up with out any other issue. If you use a 5-speed or 4-speed, you can use your stock 240 drive line without modifying it at all and this drive line has serviceable U-joionts too boot. I ran a 1977 280 Z 5-speed, 1977 280 Z R-200, stock 1973 240 Z drive line, and stock 1973 240 Z U-joint half shafts for years without problems on a 3.1 L motor that was camed and stock twin SU’s. Mike
Go here for some good general information. http://auto.howstuffworks.com/differential.htm An open differential has one tire called the "drive tire". In short, moving forward is accomplished by the left tire turning as result of the right tire not being able to spin the in the reverse direction. The drive tire will always have the spider gear that turns in the direction of the carier and the opposite tire will have to spin the reverse direction as the carrier to accomplish slipping (turning a corner for example). Hope this helps. Mike This is why you often only get the left tire to "light up", resulting in smoke and all that fun stuff.
Don't mean to step on toes, but if you look at my album you will see the VLSD and LSD still in the R-200. Note that they look very similiar in shape and size. As I stated both have the finned rear cover, and I'm sure as this topic has been covered before so have others stated the same. With differential out of the car (the part being on the shelf of some guys garage or recycle yard) a quick glance at the R-200 the only real noticable difference is the casting shape of the carrier. If the end opposite of the ring gear is squared off (but not a hard 90 degree angle) than it is LSD if it is more rounded than it is VLSD. No other marking that I am aware of. The open differential is easy to spot, four spider gears clearly visable and nothing else. Haven't seen a Helical drive but I don't think I would be comming accross one anytime soon. But if so I'll post pics. Mike
Yes it will fit, and do remember that speedo pinion as stated earler. On a side note, a good idea is to get a note book to list parts that you have changed and list new parts installed. List new make, model year and miles as well as dates of swap. This will alow you to keep better records for service reasons and make parts purchaseing easier. My old heap has parts ranging from 1970-89. Lot's of parts are interchangable but some are specific to year and model. Just my $0.02. Mike
The R-200 mustache bar was no longer used after the 280Z in 1978. It used a different bushing mount, the original mustache bar looks more stable in my opionion. If you need an R-200 mustache bar I have a few in my pile or parts, just let me know. Mike
Log into my personal album, I have posted a few pics of interest concerning the VLSD and LSD unit. Both came stock with the finned rear cover, Nissan motorsports catalog has a good picture. This cover is available from motorsports as are the LSD units. As others have stated, rear end gear ratio should be 3.700 with a stamp on the ring and pinion that reads 37:10, and a bunch of other stuff as well. The transmission speedometer pinion gear should be blue in color and have a tooth count of 18, on all 300ZX 1984-89. Only the 1987-89 300ZXT has the LSD units and the 1988 white colored car model SS used a VLSD. If you pull the VLSD unit GET THE CV SHAFTS. This unit used a very special shaft to connect the Viscous clutch from left to right, I have pics of that as well in my album. If you pull the LSD unit no issues on the input shafts, as they are the same as everyother carrier made by Nissan for the R-200 that I can recall. Hope this helps. Mike
240Z Turbo, Thanks for the response with descriptions and part numbers. This make the process of understanding much easier, and easier in trying to find parts and assemble. Your aces in my book. 11.2 @130 ehh, buddies BBC in a Chevelle had trouble mustering 13 flat @110 in the quater, your stuff must be dialed in. Mike
The recommended welding class at a local community college is good advice. Reading about the techniques is good but until you are in an enviroment that you can practice them your still in a green situation. You can mig SS (GMAW) and get same results as solid wire steel. There are advantages to SS but usually cost is greater. If you do use SS use solid wire with a sutable gas, as SS flux cored wire is about 100 times greater in cost. Mike
Welders are like fine German sports cars, the more you spend the more you get. Look at what you intend on welding, tubeing for exhaust and small hobby stuff...or structural H-beams. Sure you can spend the cash and get a good Tig unit or multi-process unit from any of the big names. My angle is this, if your only concern is basic hobby stuff look at the CHEAP harbor-frieght.com welders. Most units from Chicago Electric will run you under $300.00 and allow wire of 0.035 solid or flux cored. Wire is the best for fast fab and you'll get enough penetration for tube and such. The duty cycle is only 10% at best and you pay for duty cycle. I have a 250 lincwelder that I use at work (it has to be older than my father) and the duty cycle is only rated at: 140 amps 100%, 200 amps 50%, and 250 amps 30%. The cost vs. benifit factor should allow the H-F unit to run for several years without fault. I use one for tacking and small quick jobs. Just one mans opinion. Mike
I understand where we are loosing communication. I am describing the CV bolt pattern as 4-bolt and you are addressing the companion flange as 4-bolt pattern. The adapter your selling pictured on your website shows a six bolt pattern CV. The VLSD companion flange uses a reverse of what is pictured where the circle is on the inside not the outside so custom machining "could" be the solution. It would need to look something resembleing the stock companion flange. You state that others have used this unit on VLSD and had no issues? Ok this is them here. Mike I'm assuming that this pic is just a red circle and an X in it, I have this image linked from my album. You should be able to view it their, I hope. Mike
The 300ZXT is a ball and cage and yes it is stronger. The 300ZXT CV's I have on the bench are same length (roughly) as the 280ZXT tripod shafts. Don't know about the N/A 300ZX stuff. Mike
Length is good but the bolt pattern is different on the other R-200 CV's verses the VLSD version. Does your bolt-on bad boy adapt a four bolt pattern if so than no issues. All other Nissan CV's of this vintage I've seen use a six bolt pattern, grouped in three sets of two. Again, thanks for responding Ross. Mike
Seen them bad boys, I was hoping you had a toy up your sleeve you hadn't unvailed yet. The issue with useing those units is that the differential/CV combo uses a differenet spline pattern on the clip and one is longer by a lot. The companion side is a four bolt pattern that surounds a circle. I was looking into using the Z32 differential stub axles and my old U-joint half shafts with an adapter plate on the differential side. If I could post pics (don't know how) I would put one up that looked real nice. Thanks for the info and help in this matter. I guess I will attempt to contact James and see if he is willing to share his findings as Joel stated. Mike
Ross, Maybe I'm dumb as a post but I am confused. What is the part you are addressing? Does it mount the old U-joint halfshafts to the differential??? That was an other option I was considering...although not the end result I was looking for or wanting. Easy enough to have a plate made that would adapt the old fourbolt halfshaft with u-joints to the five bolt differential stub like that used on the 240SX. Haven't looked into it too much for dimentions I really would like to use the CV shaft rather than a U-joint. Mike
Thinking about what I have written, "Now the dirve shaft is the 280ZXT shaft and at the other end use the 1984-89 Eagle 6 cylinder spider assembly in the 280ZXT slide joint housing". I would assume I am wrong, and that you need the 1984-89 Eagle shaft not the 280ZXT else why would you be concerned with the other side of the CV. Looks like more parts hunting for me. Mike
Joel, I've seen James 240TT page that describes the conversion you speak of, I'm a bit confused :. As far as I can understand you use the 300ZXT double offset-Birfield joint assembly on the differential side. Then you use the inner race that has splines for the drive shaft from a 1984-86 Eagle 6 cylinder, and using the remainder from the 300ZXT differential joint, assemble as normal. Now the dirve shaft is the 280ZXT shaft and at the other end use the 1984-89 Eagle 6 cylinder spider assembly in the 280ZXT slide joint housing. Do I have this correct? Mike
