Corzette
Everything posted by Corzette
  1. Scottie, here is a place that has ANYTHING you need regarding body parts. He is in Canada but ships anywhere. Web Site: www.showcars-bodyparts.com Email: showcars@idirect.com CorZette Terry
  2. Frank, if the gauge is not at zero when it is not running, there is air in it. there should be a little rubber cap on the back that you can open to let it out. Then it will go back to zero. At least Holley does this.
  3. Thanks guys. I DO want to get a cell and will but I don't have the money or time right now. My engine was running fine with the stock motor and Holley 600 but after I Bored it 40 over and put a 510 lift cam etc...it just dies if and sputters if I floor it for too long. I am sure the engine sucks alot more gas than before. Its around 350 HP or so. What is a good cell to buy that has the sender built in? Around 12 or 15 gallons. CorZette ------------------ CorZette 73 240Z/357 SBC WITH L88 COWL INDUCTION HOOD
  4. Glen, I think the coupe 280 Z tanks are the same with the 3/8 pickup. I am gonna buy the tank today from the junk yard. I will have it vatted and also on the bottom of the tank in back of the drain plug, I am gonna have them weld on a fitting for a 3/8 inch fitting. That way if the line up top is still too small. I can attach a hose from the bottom of the tank, (like a fuel cell). These fittings come in 3/8 to 3/8 and 3/8 to 1/2. You can get them for about $1.00 each at a hose shop. Then you have to find a filter with 1/2 in and out if you have the 1/2 line. I plummed my fuel line before when I put my rebuilt engine in. I have 1/2 line from the pump to the regulator and then 3/8 to the carbs. I'll let you know how this works. I have a 73 as well...the pain ohh the pain...by the way...does your car cut out at the top of second or third gear after it has ran awhile? Do you lose fuel pressure after it warms up? It acts like the tank doesn't vent right. There is an apparent vacuum in the tank....I would think about checking the venting on the new tank as well or installing a rollover valve from JEGS etc...about $20.00. Well more later..... CorZette ------------------ CorZette 73 240Z/357 SBC WITH L88 COWL INDUCTION HOOD
  5. Guys, how do I replum the gas tank on a stock 240? Do I have the guy at the VAT shop cut out the existing fuel pick ups and just have him weld a 1/2 inch steel tube down into it? I am having the same probs that Mikelly was having BUT I still have the stock lines coming out of the tank which are smaller than 3/8. I hear a hissing sound when the pump is on and the clear fuel filter up front will bubble when the pump is shut off. does the tank vent line supposed to stay connected to the neck by the fuel cap or repositioned? Any help is appreciated. CorZette
  6. Guys, I am rebuilding the CorZette engine and Tranny. What should I do to the Tranny (700 R4) to bring it up to handling around 350 to 400HP or so with a good shift kit? What would be the best thing to add or upgrade? I'll tell my mechanic when he does it if I can get some good advice! Thanks! CorZette
  7. O.K. guys, who out there has the MSD 6A etc on their Z? I understand the diagram. I have the Mallory unilite 9000 series distributor (Three wires coming out of the unit, brown, green, red) when all the wires are placed as in the diagram, I still have the Ballistic Resisitor with the Z's green wire on one side and Black/white strip on the other, then the tach wire going to the coil plus side. When the MSD is hooped up, ONLY two wires from the MSD or supposed to be hooked up. O.K. how do I hookup the remaining wires on the resistor? Do I leave them there and put the tach wire into the tach slot on the MSD unit? Do I need a tach adapter or does it work with the stock tach? Isn't that wjat the resisitor is for? ANYONE PLEEEEAASE help and say you know exactly what I am talking about!!!L.O.L Thanks in advance.... CorZette
  8. Guys, i was driving my 240 V8 today and the engine started cutting out bad. I checked the fuel pressure and it was only 3...I turned off the car and kept the pump running and checked the rear near the tank. I heard a SSSSSSSSS sound like a tire going flat. I turned off the pump and that was it. Sounds like I have a vapor lock somewhere. I took off the gas cap but no change. Does anyone know how the stock 240 Z's vent system works? Did anyone have this problem before? I am having 1/2 inch pickups put in and replummed next week....any help is appreciated. CorZette
  9. I am in...I will take two sets as well.... let me know when, where, how much etc... hrb4life@iglobal.net CorZette ------------------ CorZette 73 240Z/350 SBC WITH L88 COWL INDUCTION HOOD
  10. If your interested in knowing what my Stock 350 with the 700 R4 and street tires/no converter, Holley 750 VAC , block huggers, mild mild cam ran, it was 13.9's at 98 MPH. I figure only about 260HP or so. I can't wait to get the engine done &*%$#@. I am doing the new 1/2 inch fuel lines and getting the tank replummed for the new lines as well. Up front is almost done. What does amyone think of the new ZZ5 motor from scoggin? 385 HP with quick burn heads. CorZette
  11. Guys, I have a 350 with headers and Holley 600 and a mild CAM. What timing should I use at 800 RPM idle? also, what should my IDLE RPM be? Any help is appreciated. CorZette
  12. Pete, I had this problem and I took out my thermostat, it runs real cool now and much better when at idle.
  13. Guys, I just upgraded my fuel system to the Holley Blue pump. I now run at 7 PSI at idle vice the measley 4PSI from the mechanical pump. I notice now that my carb hiccups when I floor it off the line and when I punch it rolling at 5 MPH or so It jumps but the engine almost dies then comes back. I am pissed and confussed...anyone ever have that problem? Do I need to adjust the bowl levels? I have a Holley 600 vacuum secondary. Any help is appreciated. I am about ready to throw the carb away and get an Edelbrock carb!!!! HELP!!! CorZette
  14. I want to thank everyone for their input. Looks like we have a real tight board and I am proud to be a part of it. I spent 12 years in Japan and raced FairLady Z's for quite awhile. You become a part of this Datsun Z thing after so many years. My first one was a 73 Fairlady. Strangly enough my current car is a 73 as well. I will going back to Japan soon and will get the Steering and Dash parts to convert my car back to a Fairlady style when I come back. I was just throwing out questions on rear end setups as I haven't a clue on how to do it. Can anybody give me some places to check where to get the 4 link setup at a reasonable price with a Ford 9 inch???? Also, do you all think a 383 stroker with VORTEX heads is a good deal? I am considering buying a crate motor since mine is over 25 years old and stock. Mikes setup is awesome and I wish I knew as much about it because I like to do things myself but I want to be safe. By the way, I am in Lubbock TX and I don't want to pay $10,000 FOR THE SETUP....ANY IDEAS GUYS??? Thanks again and lets remember, we are a TEAM out here in Z land, no matter what engines we have. This Z thing is a VERY special thing and please lets none of us forget that. This is what sets us apart from all the other cut throat so called clubs out there! CorZette...
  15. According to NISSAN, you have to use 140Weight gear oil in the rear and only 1 quart for the R200.
  16. Guys, here is the place for the Ford 9 inch setup. A little spendy but will solve all the drive train problems. DUTCHMAN M/SPORTS "9"" FORD IRS" DUTCHMAN INDEPENDENT REAR SUSPENSION http://www.hotrodheaven.com/ $3995 Your Price $3995.00 WEBSITE:
  17. Can anybody tell me if the Leaf Spring and straight axle setup is O.K. on the 240 Z. If not, why and woulod I need to put a SUB FRAME in the rear to weld the Spring mounts to, or can I attach to the existing frame? Somebody please help. I can't afford the custom setup...too expensive. HELP!!! CorZette
  18. John, just put mine on today...I don't see a problem...it squats a little more but nothing drastic. Feels tight around corners but you don't lean as much. Once your used to that I think its a better deal. CorZette 570Z
  19. Guys, Motorsports sells the factory replacement Floor Pans for About $300 or just standard stiffer replacements for $169.00. Just trying to help. CorZette
  20. Thanks John, my best trap speed was 98.4 with the 3:90 but into 4th gear. Average around 96 or so. My secondaries aren't opening either...gotta get that fixed. I still have the mechanical fuel pump too. Changing that soon. Thanks for the input. Were going to a 383 stroker motor soon bored 30 over with some good heads...ANYONE have a suggestion on what heads to get. I have DART II heads now...should I keep them/ Also, anybody know what I should run in the 1/4 with the 383 bored 30 over? SPEED? Now stock 13.9 at 98MPH....Awaiting your replys! CorZette...
  21. Your right about the 1st 60 feet. I have a stock 350 with headers and a Holley 600. It takes me 9.1 secs to 1/8 mile and only another 4.9 to the 1/4....running 13.9. Do you think this will help by changing to the 3.54? It spins off the line and into second gear as well. Thanks CorZette ------------------ CorZette
  22. Hey guys, what is a good timing setting? Mine is advanced 46 degrees at 2500 RPM...no knocks. What do you suggest? CorZette Lubbock Hey Stan! ------------------ CorZette
  23. Guys, gotta question. I have the 700 R4 and love it. I have a R200 3:90 rearend. I also have a 3:54. Which one is better for the Quarter Mile? With the 3:90 it shifts into 4th before the end....any help is appreciated.... CorZette Lubbock
