Corzette
Everything posted by Corzette
  1. Well I posted a few more painted pics with the Airdam attached...man its looking good... CZ
  2. Hey I have the 3970010 block 4 bolt .o4o over. Nice to know. Its 1975 block. CZ
  3. James, just sent you my Business Plan as an example of what they look like....good luck.. Corzette
  4. Read this about management. Its good stuff, I live by it. I have a degree in management and one in public relations. People have to feel like a part of the vision, not just a customer or employee. You should focus on giving a balance of 1/3 to customer, 1/3 to employee and 1/3 to management. They are all equally important. The command and control days are over. Well maybe not for the military but you know what I mean. I have been in management for 22 years as a Marine and learned one thing if not more, and that is you have to inspire first and foremost. People should says things like "Man I wish I was that guy/gal, or "Those guys are locked on and really give a Damn about me as a customer". Me and my wife got involved with Herbalife 6 years ago and have amassed a fortune on people's results with weight loss and health etc. My favorite saying is " I don't want your money, I want your results". Its the results that make you successful. You can apply that to any business. The question is, what results will make a difference in your field. Just food for thought. I have the utmost repect for Entrepreneurs because we make the world go round. Never stop dreaming or being creative. I have sent you a great article by Michael Hammer that explains Control and Complexity. You must have a Business Plan first as well. Don't make the mistake I initially did. If you know where you wanna go but don't plan on how to get there, you may never find your way. Ever hear of "Lost in Space" lol. Im just here to help. Enjoy.
  5. That gasket is part# 375-1094 Embossed shim out of Jegs (Felpro)...would that work? That is a head gasket and not just a shim right? CZ
  6. Grumpy, I found a gasket that is .015 compressed and has a bore of 4.100. Plugging into the chart gives me a 8.11 SCR. Provided my valves dont hit the pistons, is .015 quench OK? CZ
  7. Man Grumpy thanks for taking the time to post that...sounds like the secret ingredients to a winning combo. My next engine will be a 383 or 406 for sure. Ill see if they can mill the heads .015 before shipping and use a .038 with 4.150 or so bore gasket.... CZ
  8. Roger that, I understand. I used the calculator and I get around 7:7:1 ratio. You said I was slightly off....what would be a good target to shoot for? Say 8:1:1 or so? If I go with what I have now would I be giving up alot of power? Sorry so many questions but I want to do it right the first time. You are the motor GOD you know! I was thinking about maybe 64 cc heads to be in between but AFR doesnt make those I dont think.... Terry
  9. Thanks guys! Makes my day! Yes I will have her home (IN OKINAWA OFCOARSE) next weekend. Then I will start reassembly of the interior and outside etc. The engine will be dropped sometime in April maybe (BOOO HOOO). The heads are are expensive. Not to mention a million trips to the bolt store Im sure... Ill post pics as I go along. Can you believe this car is worth over 20 grand to the right buyer. Well I wont sell...no..no..no.. CZ
  10. By the way I have a few new paint pics of the car...more to come.
  11. This is what I get with the calculator: Cylinder Head Volume (cc) 68 Piston Head Volume (cc) 7 Gasket Thickness (in.) .038 Gasket Bore (in.) 4.060 Cylinder Bore Diameter (in.) 4.040 Deck Clearance (in.) 0.00 Stroke (in.) 3.48 COMPRESSION RATIO 09.804 If I use the Gasket bore of 4.060 vice 4.125 I get a little higher CR as well. How do these numbers look Grumpy? I think I will stay with the AFR 190s. Do you think this build would put out anything close to 450HP? Seems a little high to me... CZ
  12. Grumpy, I am a little confused. The book says the Compression Ratio should be around 9:5:1. When you say dynamic are you talking about the actual CR? Man 7:6:1 would be a dog. Do you think AFR makes a 62CC Head? Do you know any others that flow as well as AFR that may have a 64CC chamber? I am looking for around 9:5:1 - 10:1 ratio. Man its a good thing I asked you about....My pistons are the KB106 flattop type. My cam is a retrofit so cam rod clearances are not a problem. It all rotates freely.. CZ
  13. Grumpy if you are out there can you please help out a distant friend! I have finally got my car out of paint and it can be seen under the paint album below. I plan on building the 450 HP setup on AFRs site. This is what I have so far... 350 .040 over Scat 350 crank 3.48 5.7 Eagle rods KB106 Flat Tops Comp Cams XR282HR-10 Part Number 12-432-8 Grind Number CS XR282HR-10 Description Intake Exhaust Valve Adjustment 0 0 Gross Valve Lift 0.51 0.52 Duration At 0.006 Tappet Lift 282 288 Valve Timing At 0.006 Open Close Intake 35 67 Exhaust 78 30 These Specs Are For The Cam Installed At 106 Intake CL Intake Exhaust Duration At 0.05 230 236 Lobe Lift 0.34 0.347 Lobe Separation 110 I want to run a holley 750 DP Hooker Block Huggers 2 1/2 Duals to X pipe and out etc. I want to get the AFR intake that they recommend I want to get the AFR 190 heads I will have 3:54 rear gears 700R4 with 2800 stall Do you think the AFR 195s will do a better job or should I stay with the 190s. Is there a better intake selection? I have already bought everything except the heads, intake, and carb. Grumpy I need your advice before I buy the rest of these parts...which would be the best bet. Afr says 450HP from their specs?????? CorZette
  14. Well fellow Zers my ride is finally out of paint and will be coming home next friday. I have posted some initial pics before wet sandinging at my site. Click on the paint album and let me know what ya all think so far! By the way I get my heads next week! AFR 190s... CorZette
  15. Got a Certificate in Japanese Studies with emphasis on foriegn language (Japanese), an AA Degree in Liberal Arts, a BS Degree from University of Maryland in Management Studies/Environmental Management/Asian Studies, and am currently working on my Masters in Public Relations. All from U of M CorZette (The Educated Killer) LOL.... USMC
  16. Ross, no body mentioned bearings...what bearings do we need in order to reassemble the 280 stubs back into the 240 housing? CZ
  17. I dont think anyone said this but I had the same prob. My pulleys were wrong. My pully on the crank was way to big and made the water pump turn way to fast causing the flow to circulate to fast etc...once I changed the pulley to under drive it works fine...just a thought! CorZette
  18. If you do go with that Tranny it is a 27 Spline and lockup type. I have a brand new in the box 2800 stall lockup I will sell ya for $175. Let me know what happens!! CorZette
  19. I have a crazy question...some of us were worried about upgrading our stub axles on the 240s to the 280 type but had problems with the bearings fitting etc. My question is...can't we just swap out the entire strut assy/traverse links etc from a 280Z? If so , what are the differences? Are the struts different only? Will it bolt up to the 240? If it does, then I am in the market for the left and right sides as of NOW! Ross, I need some adapters....can someone shed some light on this? By the way I will be in Texas (San Angelo) from the 8th to the 19th, then over to Nashville till the 26th...then back to this god forsaken place (Okinawa)... Thanks CorZette
  20. Well I did make my 26X19 Griffin fit but I wouldnt recommend it to anyone. I had the tabs welded on as well as the bottom pet **** . I had to tap in the lower sides a bit on each side to make it fit, but lucky for me everything works well...Ill post pics later at my site once I get the thing out of paint... CZ
  21. Z YA, is your 700R4 a 27 or 30 spline?
  22. Luckydawg. I will be retiring in Angelo in 2004. I plan on going to WALL alot to drag. I will have a 73 240Z V8...keep an eye out! Maybe we can meet some day! Nice car! www.picturetrails.com/corzette
  23. ZFAN, you out there? I think I know why our trannys lazily shift to third now when they used to pop into third. I found that my 12volt wire running to the electric coupling is missing. This wire enable the tranny to lock the converter in third.Well now it doesnt so it slips alot more before going into gear....read these links, it will help bunches: http://www.highperformancecars.com/crosley/700id.htm
  24. HELP!!! I JUST BOUGHT A NEW 2800 STALL SPEED CONVERTER. I asked for a 27 Spline and got a fricken 30 spline 2800 stall for the 700R4.Can anyone tell me where to a place to look up a serial number to determine the make of my Tranny? The serial number is 8683549.?Does anyone want to buy this one before I send it back...$325 includes shipping. Good to 450 HP. CZ
