Ruiz Racing
Everything posted by Ruiz Racing
  1. thank you chicken man. i'm looking for a wiring diagram for every wire that come out of the ms ecu. have you seen something like that?
  2. I am looking for a wiring diagram to install MS on a 280zx turbo. I get an error code when I look for mobythevan's thread on the subject. seem to be the go to thread but I can't find it.
  3. can it be done with the power steering cross member?
  4. or does anyone know of someone parting out a manual steering 280zx?
  5. I am converting my car to manual steering. so I need the shaft that goes from the steering wheel shaft to the steering rack.
  6. my car runs better without oxygen sensor plugged in. try that. my problem sounds similar.
  7. I have a 1981 turbo. It runs better without the oxygen sensor plugged it. If I plug it in it runs super rich.
  8. That's my plan now. I met a friend that is going to make one for me.
  9. That was my first thought. The bolts are off set. A universal 4 bolt flange will not work.
  10. I want to build a custom down pipe for my 1981 280zx. I need a flange that will fit the stock turbo. Does anyone have a flange for sale? Or know where to get one?
  11. Ruiz Racing
    My Z
  12. Ruiz Racing
    injectors
    From the album: My Z
    injectors
  13. Ruiz Racing
    engine
    engine
  14. Ruiz Racing
    hood
    hood
  15. Ruiz Racing
    new paint
    new paint
  16. Just out of the paint shop
  17. I hope someone answers soon. I have the same problem. My hose has a nasty hole. I was thinking that all one would need was a threaded spline to stick in there. I don't know where to buy them or how to make one. you should also try the l6 forum.
  18. how in the the hell did you do that?
  19. I would check the injectors. that's what my car was doing. the wiring harness on injector 3 and 5 was faulty.
  20. Think of the tape as like a gasket. It can handle the heat. It is the easiest and cheapest fix to get you down the road. if you want to use the oil catch can, it goes from your valve cover to PVC hole on the block. Take your PVC valve to Ace and get a bolt with the same thread size to plug the hole. You will also have to plug the hole on your intake from the hose that goes to your valve cover. It is a can that catches oil. You have to empty it. Read this... http://forums.nasioc.com/forums/showthread.php?t=754710
