Contact Methods
Website URL
http://cincinnatistreetstyle.com/
Location
Cincinnati
zmnap's Achievements
0
I have recently acquired a driver side quarter panel and door skin that are NOS nissan parts with VIN numbers. The quarter panel even has the original delivery tag on it which is pretty neat. The quarter panel is for a late 260z or 280z. I know these are pretty rare but wasn't sure where a good starting point on price would be so input would be greatly appreciated. Thanks!
PM Sent about the whole car.
The Rears weren't so forgiving... The spindle pin did not want to cooperate so I sent it to a shop to have them press it out, sandblast the rear hubs, and press some new wheel bearings. I also changed out my rear studs for Nissan Quest studs as a cheap way of getting a few extra MM for my lugs to bite onto. With the rear spindle removed, the threads had to be cleaned up as well. A big thanks to MWorks garage who did a killer job on the parts for me! Finished Products:
Hey guys, This is the journey of my 1974 Datsun 260z to where it currently stands and where it is headed. I hope you enjoy! This was the car when I first got it... It was a good running car that was fairly "clean" with the exception of some hidden rust. I drove the car like this for a couple of years before I really got the itch to modify it. To start things off, my carbs started leaking so I rebuilt the round top already on the car. The outcome: Nice new carbs and a sad looking engine bay. (Ignore the wheel in the background, we will get to those later...) With the production of the BC Racing coilovers, I decided it was time to pull the car apart for a few updates in the winter of 2014/2015. It would share a space with an old Austin Healey Mini for the winter. With it up on Jack stands, the intentions were to go through the bushings, suspension and address the rear brakes. Along the Way I also picked up a set of Wilwoods for the front which are still having brackets fabricated. I acquired a Silvermine rear disc brake conversion, BC Racing coilovers, & some Prothane Bushings and work began. With all of the parts acquired that I wanted/needed for the winter ahead, I came across a pretty rair set of wheels that I would snatch up: 15x9 3-Piece Revolution RFX's that the previous owner had painted the faces of a House of Kolors Green. At first, I hated the color of the wheels but they have since grown on me a bit. With everything ready for the winter project, I started tearing the car apart... [/url With all of the suspension pulled off and the struts sectioned, I started assembling the front coilovers. The shop I had weld them had some pretty ugly welds that I ended up having to grind down. I also wire-wheeled the knuckle assembly and painted it for a nice finished look. I also went on ahead and wire-wheeled and painted the brake dust shields while I was at it... Finished Products:
Hey guys, I figured I may as well start a build thread for my late model 260Z. I am currently in the process of installing the new BC racing coilovers as well as working on a few areas of the brakes while I'm in there. I will also be installing flares this winter after my new 3-piece Revolution RFX wheels in 16x9. Below are a few pictures to get you up to date: Pictures of the coilovers right out of the box: Car on Jack Stands preparing to be disassembled for coilover install: Dirty Front Assembly Removed: Disassembling: Sectioned a bit (Not all the way. Correct cut is 45mm up from the bottom.): Rear Assembly Removed: Sectioned down a bit: Test Fit on front assemble before cutting to the correct height: My 3 Piece Revolution RFX's (Soon to be refinished to Matte Black Faces with Gloss Bronze Lips):
zmnap replied to k3werra's topic in Brakes, Wheels, Suspension and Chassis
My 3 Piece Revolution RFX wheels. Getting refinished this winter. Gloss Bronze Lips with Matte Black faces. -
I recently received a set of the new coilovers BC Racing has developed with JPN Garage. I know a few of you are anxiously awaiting yours so here are a few pictures of mine. Please note: I received mine as part of a sponsorship with the website I run which is why I have mine a bit earlier. Enjoy!
I am looking to buy a ground control coilover kit (Pre-fabbed to struts or not), Mckinney motorsports, T3, or or Sakura Garage Stance Coilovers prefereably used.
- Coilovers
- Mckinney Motorsports
- (and 5 more)
