It all began with a perfectly functional 73 240z which I planned to drive while I put a turbocharged LY6 in my Camaro. Time went on, the Camaro got sold and the juiced up V8 needed a home. Being that it was a truck motor and I wanted to keep the stock accessories and utilize AC I went the CX Racing route (cause I really didn't want to chop a corner off my block for that passenger side motor mount).
The kit came with motor mounts, trans mount, full length headers, header gaskets, and full exhaust with v-bands.
Things needed are motor mount bolts (the ones to the engine block), 2x bolt and nut to fasten the motor mounts to the motor mount towers, 2x bolt and nut to mount tranny mount to the tranny mount connection point, 2x bolt and nut to mount tranny mount through the tranny tunnel.
Who needs a 2.4 when you have a 6.0
First thing to do for the swap is to remove the factory motor mounts, secured by one bolt underneath them. Mine both rounded out after a few turns which resulted in one of my fingers getting sliced really deep, had to saw out the old rubber mounts and grind the bolt out from above. In the end you get this:
Next step is to grind the crap out of the stock transmission mounting tabs. This part was by far the most annoying part of getting the motor in. The tranny will collide with these if you don't grind enough. Check out CXRacings youtube video and look VERY close to get a feel for just how much metal you need to remove. Another thing that needs to be removed on the TR6060 is the CAGS solenoid which otherwise collides with the stock tranny mounting tabs (Dorman part 090-040 will plug this hole). You can see the CAGS solenoid hitting below, also note that I had to take a good bit more metal off the tabs before I got the tranny to fit.
Heres a shot of where the tranny lines up with the shifter hole, it looks like I will need to shorten the stock TR6060 linkage an inch to get it to fit, 2 inches to get it centered (stock shifter pokes out from the back of the tranny about 1.5")
A note on the engine mounting plates the kit provides, I ended up with mine using the 2nd from the back mounting hole. Seems you can't use many that bring the engine farther forward because then the tr6060 case hits the tranny mounting tabs. As you can see with the picture showing the CAGS when the tailhousing portion of the tranny bolts on it protrudes a good bit, to get the tranny in you have to put it far back enough to get that protrusion in front of the tranny mounting tabs which equated to the 2nd bolt hole back on the motor mounting plates. You could also move the tranny forward an extra 2" or so to put it in front of these tabs, but then you lose some weight distribution (but can utilize stock TR6060 shifter).
Heres how it sits now, will try to get tranny crossmember mounted soon (seems it will work with TR6060 if I drill new holes that bolt to the transmission's rubber mount) and also set the headers in.
