So I had bought an S30 air dam from Japan this past summer but never got around to mounting them to the car until this past winter. I originally got air dam with turn signal cutouts because I was planning on doing front turn signal swap and going for a 240z set, now I'm not so sure. Anyway, upon install I realized that the air dam doesn't come close to the sitting flush against the mounting points near the headlight buckets.
At first, I figured it might be because there's extra material on bottom of the mouth of the air dam but I assume that even after cutting it it still wouldn't sit flush on the mounting surface anyway. Additionally it seems as if the vertical faces on the inside of the turn signal cut outs aren't long enough to sit flush with the inner most edge of the mounting surface. Also when you have one side of the air dam seated flush along the fender lip, the other side is pushed away from it, which leads me to believe that the air dam's overall size is too narrow.
Am I wrong in assuming that the 240z and late 280z air dams are similar in nature? I'm very close to just purchasing a fiberglass 280z air dam and redoing it in carbon.
Apologies for the lack of light in the photos, I was doing this at about 11 at night.
