gmac708
Everything posted by gmac708
  1. 90 Toyota 4-runner calipers and Z-31 rotor, purchased hub and rotor from Modernmotorsports.
  2. I just installed the GC front camber plates. Piece of cake! I don't like the hardware supplied with it. Hex bolts OK for camber adjustment but I am still looking for a more finished looking fastener for the plate/tower. Otherwise...
  3. I am using the McKinney mounts and found the fittings were very close to the hood catch. Not much room if you ever want to remove rocker cover. I tried to remove and could not do it so.... ... I removed old fittings (they are just pressed in), sawed off old boss and had them welded closed, and had a new set of "bungs" welded on. Then I filed flat and had them powder coated. I plan on using union with 90 degree elbow on hose running to catch can, but you could use "T" and link them back to original config.
  4. I just got an e-mail from them today as well. They say you can send them in your older 3-3/8 or 4" for small "upgrade charge" and have indicators installed. I'm going to call tomorrow.
  5. I liked it! You'll get it running better!
  6. If you call standing on them re-shaping, yes. I did have to do that . The seat supports did not follow the floor either. Floor ended up flat where it needed to be.
  7. The floors are Zedd Findings and the frame rails are Bad dog. Here are some more pictures around tunnel. C'mon BlairJJ....doooo eeeet:mrgreen:
  8. I just replaced the floors in my 70 240Z. The multiple layers are where seams connect the floor to the front, rear, and frame rail. The frame rail only goes part way back. Here are some pictures. Start on R/H side Drill spot weld and remove seat brackets. Remove old floor (this shows new Bad Dog rail being installed) cut fit install floor Repeat if necessary.. View of installed Bad dog rails (they extend all the way to rear suspension supports). Hope this helps. Gord
  9. I weighed my '70 Z before the swap as follows... LF 578 RF 644 LR 530 RR 500 Total 2252 lbs distribution calculator Should be interresting to see how much it changes.
  10. I like the turbo return/scavange fittings on left side. Very nice!
  11. Doesn't it get too hot on firewall for the glue on the Dynamat? Isn't there something else that should be used in a high heat area?
  12. 1970 240Z w/Mckinny mounts, RB26DETT engine and RB25DET Trany. Overall... plenty of room. Like you said, need to make some room for the speedo pickup. I am working the floor pans and frame rails at this moment, I will get around to that later.
  13. I'm giving this one a try. http://www.randysracemart.com/prcdopara.html 24X19 P/N PRC 2111100 Not installed yet, but it does fit between frame rails. Price is reasonable. $244.45 delivered.
  14. Here are some pictures. Think of everything upstream (intake manifold) of ITB's as boost and everything downstream (balance tube, vacuum chamber) of ITB's as vacuum. This shows the two lower boost lines. (green and blue on your diagram). Green is boost. Goes to wastgate and prex control solonoid. Do not use for BOV. This remains boosted when lifting throttle because it is upstream of ITB's.VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV This shows the two vacuum lines that are in air chamber. (brown, yellow)These are downstream of ITB's and provide vacuum when lifting throttle. VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV They get their vacuum inside the chamber from the two big hoses on either side of chamber, which are connected to the balance tube. This is for BOV -Fuel canister. Fuel vapors from fuel tank get put here and sucked in engine. Don't need it.
  15. I ordered from Fish Creek Nissan. 403-256-6900 I talked to Jeremy in parts. He will quote shipping to your Zipcode. My shipping was around $60 CDN.
  16. I ordered the following H0901 N3300 ($184.48 CDN) H0900 E4100 ($192.90 CDN) From Nissan dealer in Calgary Alberta Canada. They came in today and look fantastic! Thanks for your help guys
  17. The pan got here and this thing is awsome! Like a glove! OOOOH ya New dip stick! Thanks Rob! What else can I say? p.s. Thanks for the hat
  18. I think there is more to this pan than a pretty face. It looks like it has a bunch of performance options. Even has a breather adapter on right side. This is cool
  19. Price was posted in page 1. I was hoping a group of us could get together and get a group buy going, but no real interest materialized. I just went ahead and got the pan. Now I don't have to worry about it, problem solved. Nice looking pan!
  20. Ordered mine a couple weeks ago from Rob at Rips. Here are a couple photos showing the progress. comes with surge tank, baffles, breathers, custom-pickup, custom dip stick:mrgreen:
