Everything posted by Jboogsthethug
From the album: Jboogsthethug's 1971 240z build
Jboogsthethug replied to Jboogsthethug's topic in S30 Series - 240z, 260z, 280z
Thanks mate! Yeah I'm debating on whether to do just a flat dash or to do a fiberglass/CB dash. Regardless I plan on using a digital gauge rather than gauge pods but for now I'll probably just clamp an iPad to the bar or something ha. And all the tubes connect through except the triangulated dash portion. I wanted that to make the firewall a bit more rigid to help with my dual master cylinder setup. Who knows if it will actually help but I like to think it will ha.- 168 replies
- rb25det swap
- 1971 240z build
- (and 4 more)
Looking at https://www.wiringspecialties.com/rb25det3.html?sort=featured&page=2 May answer some of my questions. I think this is a wastegate connector or the speed sensor? Wastegate: https://www.wiringspecialties.com/connectorj.html Speed: https://www.wiringspecialties.com/rbspseco.html And that's about it ha. ANy confirmation on this?
- 5 replies
- unknown plugs on engine harness
- rb25det
(and 1 more)
Tagged with:
It is time to get caught back up for good! I figure I'll start where I left off. So before sending this off we went over all that I wanted done to the car cage wise and gave him (my boi Thomas Meiser with Fabn801) a good idea of my goals. Once he got there I worked even more along with him via pictures and drawing things out ha. Ghetto but it worked pretty well! Here are our "blueprints". From here, things started taking shape. He started with the main hoop as it was the most important part. He bent them perfectly around the interior to really hug the walls, nailed it perfect. But after closer inspection of the rules we realized the bends probably exceeded the amount fo bends we could have. Total of 180 degrees between it all. So he was super cool and tore it out and redid it for me. Things beginning to take shape and working through it together: The final outcome before it was shipped back home. Looking super sick!! Man, Thomas really killed it and I couldn't be more stoked on the outcome. Can highly recommend him as a builder for anyone in the Utah area. I caught him when he was still young in his career and I can only imagine as he grows his company he will be a huge name. After all was said and done, he went above and beyond what was owed. We initially had the deal for him to gusset things out but he was already over what we agreed on hours wise and so I told him to not worry about these adn I'd fix them up later. And here are some of the highlight pics after getting her home safe and sound! There was a snowstorm on the way home and she got a bit wet so I wiped all the raw metal down but the car was still pretty wet overall. More to come!- 168 replies
- rb25det swap
- 1971 240z build
- (and 4 more)
Hoping someone can help! I'm almost done with swapping the RB25 in and I'm at a loss for a few of the plugs on the harness. My guess is they go to things that I don't have connected but I'm hoping for clarification!Here are the pics:First: this is coming off the alternator, my guess was maybe the fans or something? There's s 3 way split where the MAF and the Exhaust sensor lines split off with this last guy. This 6 hole plug close to where the harness comes out of the firewall. Before the injector plug. This 8 hole plug that comes directly from the firewall split. These two cylinder shaped pieces, not sure. Any insights? Eventually I plan on taking the harness out and removing things like this that aren't needed but I want to get it running first. I'm guessing one of these go to the transmission as there are a few plugs down there that I'm not sure where they end up.
- 5 replies
- rb25det
(and 1 more)
Tagged with:
Man I need to update this, I am so much farther along than this shows ha. I'll get on that. For now, hoping someone can help! I'm almost done with swapping the RB25 in and I'm at a loss for a few of the plugs on the harness. My guess is they go to things that I don't have connected but I'm hoping for clarification! Here are the pics: First: this is coming off the alternator, my guess was maybe the fans or something? There's s 3 way split where the MAF and the Exhaust sensor lines split off with this last guy. These two cylinder shaped pieces, not sure. This 6 hole plug close to where the harness comes out of the firewall. This 8 hole plug that comes directly from the firewall split. Any insights? Eventually I plan on taking the harness out and removing things like this that aren't needed but I want to get it running first. I'm guessing one of these go to the transmission as there are a few plugs down there that I'm not sure where they end up.- 168 replies
- rb25det swap
- 1971 240z build
- (and 4 more)
A musician's therapist (The $300 Z)
Jboogsthethug replied to Zetsaz's topic in S30 Series - 240z, 260z, 280z
Man this is looking better every day. So stoked to see how much progress you've made since you got it running! I guess that indeed is where the motivation comes from. Having a car that drives that you can tinker on rather than a non running car. I need to get my act in gear! -
Hey Omar! Any more updates since this?? -
Man, I love your updates! Hopefully with winter here we'll see more of them!
Leveling Out an RB25 Engine Before Fabbing Mounts
Jboogsthethug replied to Jboogsthethug's topic in Nissan RB Forum
The sad truth. I keep at it because I like to share the knowledge I've gained in a way that hopefully helps but it definitely isn't the way to win a popularity contest haha.- 21 replies
No problem Boosted! I was hoping it would be a valuable thread to people moving forward.- 21 replies
Every time I look at your posts you feel me with envy for your talents! Those look AWESOME!
Dude those look awesome! When are you installing them?? -
Holy balls that looks good! I also wouldn't mind coming to check it out! -
Dang that looks sick!! Did he polish those pieces up or did they come out of paint like that?
