marinez
  • Location
    Salem, Or
Recent Profile Visitors
3571 profile views
marinez's Achievements
Newbie
  1. I suggest Remflex gaskets, matched to your heads. They should work fairly well as long as your flanges aren't warped.
  2. Here's what's there so far. Clutch and bellhousing now installed
  3. Everything is already there. I am just removing the existing th350 and swapping to the t5. It looks like the left side exhaust may need adjusted. So far, I have plenty of room for the shaft.
  4. Heads up. Might be pestering you later.
  5. Augh. Finally got stuff in one place, need to move exhaust on drivers side. I'm using stock manifolds. If I post pics, you guys want to weigh in on best location?
  6. Depending on what you're doing for a transmission, the stock one, modified for length and of course the correct u-joint.
  7. Jesus that sucks. My driveshaft seems ok lengthwise. I will send the flywheel out when I get it.
  8. The car was previously converted to a 327. Just changing to manual.
  9. Woohoo!!!! Thanks so much! The bellhousing has the pivot, and I'm off and building!!!
  10. Hi guys. Survived my final deployment and subsequent duty at 13 Area, Camp Pendleton. 25 years is enough. Anyway....onward. My Z is nearly done. I have the early v8 Camaro t5, the bellhousing, driveline, and such. I need to remember which flywheel works..(I have the staggered bolt starter) and I keep hearing noises about a Jeep master cylinder and slave combo. I don't start receiving my checks until July, and I am just getting back to civilian work because SCREW SITTING AROUND. Hence...as inexpensive as realistically possible...help! If anyone has part numbers or pics of what you did...Id appreciate it. I'm still navigating this new fangled phone my girl got me...so forgive me if I haven't pored through the forums yet. Semper Fidelis Ssgt
  11. Ok..so I tried this myself. Wanted to share with you all.
  12. Ok..so I tried this myself. Wanted to share with you all.
  13. Cool! Am mid way through my 327 build. Good luck!!
  14. Ok...I just need to establish if the tach has power. I have signal from the hei.
