Hi guys, as you can see, this is my first post, but I have taken the time to read around a bit to prevent myself from asking a question that has been butchered before *I HOPE*. By the way, really excellent site. I was using the Sydney Z club Engine Builder yesterday to figure out the largest bore/stroke combination i could possibly run on the street, on pump gas, using the L24 block and the E88 head that I already have in my possession. Please understand, this is all rather new to me, and is an excercise in learning. If the combination turns out to be relatively free from catastrophic flaws, I have the funds to actually make this setup happen.
Now, from what I understand from a bit of research, the L24 uses the same main journal size of the L28, and the blocks are essentially the same except for the 3mm difference in bores. The combination that I ended up with after a bit of tweaking and changing parts to get the numbers i wanted was:
- L24 block (stock deck height) bored out 3mm, yielding 86mm
- unmilled E88 heads with 44.7cc
- HKS 2mm gasket
- LD28 diesel crank (83mm stroke)
- L26/L28 connecting rods (130.3mm rod length)
- L28 style flat top pistons, fly cut 1mm
The important final numbers I came up with were:
- 2893cc with 10.47:1 static compression
- 83mm stoke and 86mm bore, yielding .97 stroke/bore and 1.57 rod/stroke ratios
The only number that bothered me was:
- 1.030 deck height (I assume this means the piston is sticking out of the hole)
The questions that I have come down to what are basically reality checks:
- will there be valve interferance with the -1mm deck height?
- will there be problems with the top piston ring actually coming out of the bore?
- can the L24 block even be overbored .120"?
- will the L24 block have any internal clearance issues with the larger stroke?
Almost forgot... I do realize that this would be greatly simplified by using a L28 block, as it will also yield a larger displacement, and can apparently be bored to 89mm. I would just really appreciate knowing if this would work, and I'm having fun learning. Thanks.
If I happened to leave out any critical information I’m sure someone will let me know.
