JLuis
Donating Members-
Everything posted by JLuis
This engine piston kit from ITM Engine Components is the perfect replacement for your 75-83 Nissan 280z/zx 2.8L L6. The kit includes a piston ring set, wrist pin, and all necessary components for a seamless installation. Designed with OE/OEM part number RY6134, this kit is made with top-quality materials for reliable and long-lasting performance. Whether you're restoring your vintage Nissan or simply need to replace damaged engine parts, this piston kit is a great choice. From the trusted brand ITM Engine Components, you can trust that this kit will exceed your expectations. Upgrade your engine with this high-quality piston kit today. I have a few sets available and to my recollection, these have been out of stock for quite some time. I had a business plan which I am deviating from, therefore, I will be posting more items as I begin to liquidate most of my inventory. Price is $375 plus shipping. (Depending on the location, I’d say that the average shipping cost will be around $25, give or take.) If you have any questions or would like to purchase a set, please send me a direct message or reply to this thread. Keywords: Datsun Nissan 240z 260z 280z 280zx S30 S130 Fairlady Z Nissan Z Z31 Z32 HLS30 Skyline L24 L26 L28 3.0L 3.1L LD28 Maxima L6-Series L6 N42 F54 RY6134
Engine was rebuilt by Robert from RPM Motorsport. Some of his latest engine builds can be found on social media Instagram @robsperformancemotorsport (https://www.instagram.com/robsperformancemotorsport/) F54 Block Block prepped, hot tanked, holes re-tapped, primed and painted with ceramic engine red color paint L28 Crankshaft (polished and chamfered oil journals) 280zx L28 Connecting Rods with 9mm ARP Rod Bolts OEM Nissan Flat Top Pistons 86mm Bore New Crankshaft Main and Connecting Rod bearings New Cloyes Timing Chain Kit New Complete Fel-Pro Gasket Kit New Upgraded Oil Pump (280zx Automatic Turbocharged - polished) New Water Pump (polished) NEW OEM Nissan Water Inlet and Outlet Upper/Lower Thermostat Housing (polished) Includes thermostat Timing Chain Cover (polished) Oil Pan is gloss black (powder coated) Refurbished OEM Motor Mount brackets (cadmium plated) Refurbished OEM exterior hardware such as bolts and brackets (cadmium plated) Refurbished OEM Nissan Harmonic Balancer Damper (professionally rebuilt) NEW OEM Nissan Oil Dipstick (not shown in picture) N42 Cylinder Head Refurbished OEM Nissan stock size Intake/Exhaust valves ISKY 490 Lift Camshaft Springs Kit OEM Nissan Rocker Arms ARP Head Studs Refurbished OEM Nissan Head plate, Fuel Block Off plate, Alternator Bracket and Adjuster, and Water Pump Pulley (cadmium plated) Valve Cover (polished) New NGK BPR6ES-11 (7133) Spark Plug Set New Engine Heater Hose Elbow Water Connector (located on the side of the cylinder head) NEW OEM Nissan Exhaust Studs with Washers and Nuts Estimated compression ratio is roughly about 10:1 Price is $6,500 Local installation may be available for an additional cost. Subject to availability of known resources. Location in Los Angeles, CALIFORNIA
R200 3.54. 3.70 close ratio 5 speed, z32 5 speed
JLuis replied to Willflow's topic in Parts for Sale
PM'd -
I need a set of center caps for my 280z wheels. Even if it is a single one, that is fine. Eventually, I'd like to complete a set. See attached pictures for reference as to the center caps I need. Thank you!
Would you happen to have the rear speaker brackets?
Thanks for the pics. I was hoping it would be a hollow cam. Sorry, should’ve specified in the description. This one appears to be a solid cam.
Please send me some pics. Thanks!
Looking for a 280z or 280zx NA camshaft. Please PM for price and details. Thank you!
I’m looking for a set of 280z wheel center caps. I have attached a picture for reference of the exact type I’m looking for. If you have only one, I’m still interested, figured I’ll eventually obtain a full set “one at a time” please PM me with price. Thank you!
Hi, I'm looking for the driver side door window rail guide. Mine is bent and does not allow the window to fully go down. Please see the attached pictures.
Thanks for checking. I also sent you a PM.
I’m looking for a T5 Driveshaft. Please send me a PM. Thank you!
I seem to have misplaced my set of 240z rods. If any one one has a complete spare set, please send me a PM with price. I’m located in California. Thank you!
PM’d you Nelsonian
