mrk3cobra
Everything posted by mrk3cobra
Yesturday was the first shake down of the 240Z. I put about 20 miles on the car, this is by far the fastest car I have ever owned. Faster then the Cobra kit I built that had a 302 with a supercharger. Faster then the twin turbo Nissan 300zx. The T56 came from a 2006 with the LS2. Make sure you don't forget the brake pedal Clevis pin retaining clip. I forgot and pedal went almost to the floor.
Finally finished the car. Just finished passenger seat, and front windshield install. After reading issues with after market windshield seal, I went with Nissan seal and the install of the windshield went great the seal fits perfect. More pictures to come when the weather gets better. Next up maybe a supercharger and electric power steering.
thanks Daniel, thanks for fresh air duct. Looks great. Pete
Hi Daniel, I sent you a text, let me know if you have the driver side and how much you for it. Pete
Thermostat not opening solved. I installed a 180 thermostat. The new thermostat opens at 186, the old one was opening at 203, the problem is the computer measures the temperature at the cylinder head. There is a difference between the cylinder head and the temperature at the thermostat housing. I was seeing the thermostat housing 14 degrees less measured with a inferred temperature gun. So with the 180 thermostat it opens when the temperature at the cylinder head gets to 200 degrees. I have the first fan programmed to come on at 210 and the second fan programmed to come on at 217. I think I will lower the first fan to come on at 202. If I would have let the temperature at the computer sensor reach around 218 I think the original thermostat would have opened.
Looking to buy driver side 240Z fresh air duct. This is located in the engine compartment near the inner fender.
I tried adding water to the upper hose, this filled the radiator up above the top hose fitting. I vented the steam vent. I ran the car at idle for around 15 minutes both fans turned on. I measured both sides of the thermostat with inferred and there was 40 degrees different. I have a computer hooked up to the OBD-II port and I can watch the temperature rise.
Plug and play wiring harness
mrk3cobra replied to DAT240Z's topic in Gen III & IV Chevy V8Z Tech Board
front sway bar hitting frame rail
mrk3cobra replied to mrk3cobra's topic in Gen III & IV Chevy V8Z Tech Board
JHM, who sells bump steer spacers for OEM outer tie rods?
